Refill lexmark 2550 cartbridge black 28 - Office Equipment & Supplies
    Guru:
  • 389 Answers
Printer is fuelled simply syringe of same type of the ink Inwardly cartridge is found porous material, which holds filling an ink.
Posted on Sep 21, 2009
Changing ink cartridge
  • Here is an instruction set I found at http://www.ehow.com/how_4488808_replace-ink-cartridges-lexmark-x2500.html
  • Step 1 Press the "Power" button to turn on your Lexmark X2500 3-in-1 printer.
  • Step 2 Open the top portion of the printer to reveal the ink cartridges.
  • Step 3 Lift the gray plastic cover on the left. Remove the empty black #28 ink cartridge. Next, lift the purple plastic cover on the right and remove the empty color #29 ink cartridge.
  • Step 4 Remove the new black #28 ink refill cartridge from its packaging. Tear the protective strip of paper from the cartridge's sensor. Now, remove the new color #29 ink refill cartridge from its packaging and tear the protective strip of paper from the cartridge's sensor.
  • Step 5 Turn the cartridges so that you can read the label. This is the way the cartridges should face when being put into the printer.
  • Step 6 Slide the black #28 cartridge into the slot on the left side and push it down. Slide the color #29 cartridge into the slot on the right side and push down.
  • Step 7 Push the gray plastic cover down over the #28 cartridge until it clicks closed. Push the purple plastic cover down over the #29 cartridge until it clicks closed.
  • Step 8 Close the top portion of the printer. Your new ink cartridges are installed, and your printer is ready to use.
  • Read more: How to Replace Ink Cartridges in a Lexmark X2500 Printer | eHow.com http://www.ehow.com/how_4488808_replace-ink-cartridges-lexmark-x2500.html#ixzz0uMXO4kIN
    Jul 21, 2010 | Lexmark X2500 All-In-One Printer
    My lexmark X5410 will not accept the black and colored refilled ink cartridges from walgreens. It keeps reporting that the right cartridge is missing.
    If you have refilled the cartridges 28 and 29, it's pretty normal that your printer won't print. Those cartridges are not for refill (they can be refilled, but won't work once the printer says they are empty). If you have refilled a 28A and 29A and it doesn't recognize the one of the cartridges, try removing them and clean the electric contacts with a dry cloth. Put them back in. If that doesn't help, I suggest you buy a new cartridge.
    Apr 11, 2010 | Lexmark X4530 InkJet Printer
    Where do you insert the ink cartridges on lexmark x4650
    These are the instructions for X2500 Printer
    1.Press the "Power" button to turn on your Lexmark X2500 3-in-1 printer.
    2.Open the top portion of the printer to reveal the ink cartridges.
    3.Lift the gray plastic cover on the left. Remove the empty black #28 ink cartridge. Next, lift the purple plastic cover on the right and remove the empty color #29 ink cartridge.
    4.Remove the new black #28 ink refill cartridge from its packaging. Tear the protective strip of paper from the cartridge's sensor. Now, remove the new color #29 ink refill cartridge from its packaging and tear the protective strip of paper from the cartridge's sensor.
    5.Turn the cartridges so that you can read the label. This is the way the cartridges should face when being put into the printer.
    6.Slide the black #28 cartridge into the slot on the left side and push it down. Slide the color #29 cartridge into the slot on the right side and push down.
    7.Push the gray plastic cover down over the #28 cartridge until it clicks closed. Push the purple plastic cover down over the #29 cartridge until it clicks closed.
    8.Close the top portion of the printer. Your new ink cartridges are installed, and your printer is ready to use.
    Oct 25, 2009 | Lexmark X2500 All-In-One Printer
    Using refill cartridges
    That is because they cannot e refilled. The ones you get with your printer ( 28 & 29) are what Lexmark calls "return program cartridges", which means they are for one use only.
    I suggest you buy other cartridges that can be refilled. Those are either 28A or 34 (black cartridge) and 29A or 35 (color cartridge).
    Here is a link to Lexmark's site, where you can see the list of cartridges that are compatible with your printer.
    http://lexmark-cartridges.com/cfv2/printer.php?lang=uk&partner=&productName=Lexmark+Z845
    Hope that helps!
    Jun 05, 2008 | Lexmark Z845 InkJet Printer
    Lexmark Black cartridge 28
    You cannot refill a 28 that has been through a refill program. Look at the box dose it say refill program cartrage ?? then you can't refill it, it will always say empty.
    You can however refill a 28A.
    May 13, 2008 | Lexmark X2500 All-In-One Printer
    Refilled color cartridge for lexmark Z845
    The only work around to this is to use two catridges(2 color and 2 black and white). The reason is the printer has a mechanism to check if the same catridge is being used again. SO when you have two cartridges when one is finished refill the other and use and vice-versa. This way you will be able to refill and use for ever without any problems..
    Regards,
    Eagle338.
    Mar 13, 2008 | Lexmark Z845 InkJet Printer
    The black cartbridge is not printing and won't align
    Dies this model have a separate print head? Or is the head part of the cartridge? If it is the latter then it seems to be a data transfer problem- which means possibly the contacts in the machine that mate with the contacts on the cartridge are dirty or damaged. In the first instance try gentle rubbing with a moist tissue the in machine contacts then try. Also try the Lexmark website Tech Support Team.
    May 20, 2007 | Lexmark X6170 All-In-One InkJet Printer
    63 people viewed this question
    jasbo
    jasbo
