Question about ASUS WL-500g Premium Router
ASUS WL 500 G Premium Connection dropouts.
I have two laptops that use wifi and a desktop connected by LAN. About once per hour the wifi disconnects and then reconnects after a while, 5- 10 minutes. Both laptops have this same condition. Neither one sees the wifi. The desktop remains connected. I've wiggled all connectors, attached and reattached the antenna. Is this unit junk? Should I send it back under warranty or am I missing an auto disconnect "Feature".
Any suggestions would be apprecited. Thanks.
  • Lupinsan Jan 03, 2009
    I fixed it! The problem was interference with my AMWUC797 2.4 GHz Digital Cordless Telephone. We noticed that the computers disconnected whenever someone was talking on the phone. Tthis would happen even if they are in a different room. The router is in the basement about 8 meters from the computers. The cordless phone base is on the same floor as the computers and only 2 meters away.
    I switched to an old 900 MHz phone and now everything is great.
    Has anyone else seen this?
    was talking on the phone. This would happen even if they are in a
  • 1,602 Answers
HERE IS ANOTHER WIFI ISSUE U MY NOT UNDERSTAND BUT YOU MY BE SHARE YOUR INTERNET SERVICE WITH SOME ELSE YOU DIDNT KNOW THEY ARE STILLING YOUR MINUTES AND INFORMATION FRTOM YOUR COMPUTER
ROD
Posted on Feb 01, 2009
I can't have wifi connection
Make a LAN connection and get drivers from here or you can download driver finder program.
Jan 20, 2013 | ASUS Eee PC 1001PX 10.1 Netbook 1.66GHz...
I do not want wireless router to assign ip addresses for lan
not sure if you are doing it right
your wireless router has 2 "sides" one is it's upload, it's wan network and that is where you should set DHCP - so that the router itself gets an ip from your LAN
other side is behind your wireless router and there DHCP should also be off. it would be best if you could put your router in bridged mode - just to extend your network over WIFI
Mar 08, 2012 | ASUS WL-500g Wireless-G Router + WL-100gE...
I have asus router WL 500 g premium , when i conect my router to the power , all led form lan it open bu no lan it is on router . router not conect , pls help me .
Have you tried to reset the router? Most routers have a reset button in the back of the router (where the LAN ports are located) that you can hold in for ~30 seconds to reset the router to factory defaults which could also resolve the issue you're having as well. Although if you have a computer connected using a patch cable (CAT5) to a computer that is turned on and your not getting a link indicator light on your router then try another port to see if the led is visible then, if not try another patch cable or try connecting it to another machine.
Mar 01, 2011 | ASUS WL-500g Premium Router
WL-520GC... wifi signal very good; but no internet connection...
login to the router page and you need to configure your router settings as per your internet service provider then save the settings and reboot your router and check it
Jun 29, 2010 | ASUS EZ N Wireless Router up to 150Mbps...
Connection problems with ASUS WL-167 G
Try going to "network and sharing centre" click "internet options" then click "connections tab" then "lan settings" check if it is set to "automatically detect settings". If this is clicked then maybe look through the guide or contact microsoft (if using windows that is!!)
Feb 02, 2010 | ASUS (WL-167G) 802.11g/b (wl167g) Wireless...
I am not able to properly set up my network with an ASUS Wl-500B
Both routers need to be on the same IP scheme and subnet i.e. 192.168.0.X subnet 255.255.255.0. First, unplug the Asus router. Next, make sure you have connection to the internet by hooking directly to the Apple router. Once you've established a connection to the internet plug the Asus router into the Apple router but go LAN port to LAN port.
Mar 23, 2009 | ASUS WL-500B Wireless Router
ASUS EEE PC 900 wireless lan doesn't appear on network connection
please if u have a switch for the wifi connection on your laptop please put it on and should see the wifi on your taskbar also please check in controll panel then go to my network connections and see the wifi resides there if yes just right click and enable if not ther check device manager and check for nework devices if the wifi is enable and installed ...if not please installed by right clicking on it and using reinstall..
please let me know what happens
thanks
Jan 24, 2009 | ASUS Eee PC 900 Notebook
Connecting 2 routers (ASUS WL-500W and D-Link DSL-G604T Wireless)
This will give you a "Double NAT" setup. Meaning, Your D-Link router is connected to the external internet address assigned to you by your internet service provider. More than likely this is a DHCP address you do not control. Your D-Link router is then translating the address to the 192.168.1.x network. This is the first NAT translation. You are then connecting the ASUS router to DLINK, causing a second NAT translation. (Internet ADSL --> D-Link WAN Port --> D-Link Lan Port --> ASUS WAN Port --> ASUS Lan Port to computer/server/etc. ) If both of your routers are giving out DHCP addresses, then this is all that is required.
Nov 22, 2008 | ASUS WL-500W Router (WL500W)
Intermittent WiFi with ASUS WL-500W
I had the same problem. The problem is interferance from other devices. Solution, Change the channel from auto to a fixed one. That worked for me. No more droped connections, and a very strong signal now.
May 16, 2008 | ASUS WL-500W Router (WL500W)
ASUS WL-520g wireless router and hutchison broadband connection problem
You need to contact your ISP if the internet connection is not there....
Nov 06, 2007 | ASUS WL-500g Wireless Router (WL500GDLX)
ASUS WL-500g Premium Router Logo
457 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
