FixYa.com
Tags:
Katadyn Kata CC-191 Shoulder Case KTCC191 Camcorder
What is the difference between the many video... (by 3 users)
By Green1 - usenet poster
What is the difference between the many video formats?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by Guest, posted on Mar 29, 2008
I HAVE PURCHASED EVERIO GZHD3 60GB AND CANNOT GET MOVIE OFF IN TO MY IMAC COMPUTER 10.4.11 RUNNING TIGER SOFTWARE. HAVE TRIED THE QUICKTIME COMPONENT SUPPLIED WITH CAMERA NO LUCK. TRIED MANY DIFFERENT DOWNLOADS MPEG2,QUICKTIME PRO ETC. CAN GET IT TO PLAY USING VIDEO LAN (VLC) BUT CAN NOT COPY TO MY IMOVIE. TRIED OLD IMOVIE HD RIGHT UP TO THE LATEST IMOVIE 08. NO LUCK SO WILL HAVE TO TAKE CAMERA BACK IF THIS CAN NOT BE RESOLVED ONCE AND FOR ALL. HAS COST ME LOTS OF MONEY INCLUDING LOOSING ALL OF MY DATA AS I RELOADED SOFTWARE THINKING IT COULD BE THAT. RESULTS PLEASE. MY EMAIL IS denysstrongman@bigpond.com
Comment by Guest, posted on Feb 27, 2008
i have a Panasonic camcorder, its recording format is S-VHS-C but i use VHS-C cassets,can i get the S-VHS quality from that cassets? is it bad for the camera? is S-VHS-C cassets are available in the market?
Best Solution
posted on Aug 08, 2005
Helpful (85)
Duke
Duke - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Camcorders come in a wide range of different formats, each format being drastically different from each other. Here's a breakdown of the different formats and what makes them unique:
VHS/VHS-C - The lowest quality camcorder. These camcorders record directly onto a VHS tape, which you can take out of your camcorder and put directly into your VCR. VHS-C is a compact form of VHS. Smaller in cassette size, the VHS-C format is more convenient since you can use an adapter to play a VHS-C tape in your VCR.
S-VHS - Not as widely used as it used to be. The S-VHS or Super VHS format holds more lines of resolution and will give you a better image quality. However, an S-VHS tape will not play in a normal VHS VCR. You need an S-VHS VCR to play an S-VHS tape.
8mm/Hi8/Digital 8 - More inexpensive than DV camcorders, 8mm camcorders record at a high resolution and can usually record up to 2 hours of quality recording on each tape. Sony introduced the Digital 8 series of camcorders which records data digitally onto Hi8 tapes.
DV - DV (or digital video) is the highest level of consumer camcorders. These record at 500+ lines of resolution and can be used with the ultra compact DV-Mini tapes.
Beta/DVCAM - These are the highest formats and are considered television broadcast quality. Generally, these are the formats used by major television stations. Camcorders of these formats can cost anywhere from $15,000 to $50,000 or more.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Aug 05, 2008
Not Rated (0)
elu92
Rating: 0%, 0 votes
i have the same camera, go to the tutorials on the jvc site. i find the easiest way to do it is to change your quality to 1440 cbr insted of xp. this is still great quality and i dont know the differnce between the 2. then you can create a playlist and import via firewire to imovie
This Problem Also Relates To: Panasonic NV-DS65 Mini DV Digital Camcorder Panasonic VDR-D100 DVD Camcorder Panasonic AG-DVX100 Mini DV Digital Camcorder Panasonic AG-DVC60 Mini DV Digital Camcorder Panasonic AG-EZ30 Mini DV Digital Camcorder Panasonic NV-GS11B Mini DV Digital Camcorder Panasonic PV-GS39 Mini DV Digital Camcorder
Can you Help with these Camcorders problems?
Katadyn Kata CC-191 Shoulder Case KTCC191...
sony ccd-trv66 tape will not...
Tape will not eject Answer This...
panasonic vdr-d100 camcorder...
Hi, I'm having loads of trouble... Answer This...
sony trv66 tape will not eject
top does not rise and side... Answer This...
digital video editing
Hello, I own a panasonic sv av... Answer This...
ERROR: please remove the...
I get this message on screen.... Answer This...
Repair Service
Find Camcorder Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
