Question about Epson Stylus Photo R300 InkJet Printer
The printer will not turn on.
I have tried different cables, tried holding down power, stop and maintenance buttons for 10 seconds, and nothing happens. Prior to this when the power button was pused, printer came on and roller turned continuously - would not stop. Ink carriage did not move 0- could be moved manually. Is printer beyond repair?
  • stevebilling Apr 25, 2009
    i am unable to turn the printer on, tried several cables including new power cable, when press the power button the basic green light flashes for a split second, can anyone help?
    Scholar:
  • 162 Answers
Printer needs service or it's a problem of printer logic card.
check it to nearest service centere .
Good Luck.
Posted on Dec 08, 2008
Turn off printer then press and hold down three butons on the bottem of the small panle under the small screen on tne pinter,, hold the stop btn,,also the maintance btn and the on btn all at the same time,, hold for a few seconds and let go,,, be ready to it off strait away as it will make loud noise.. this will over ride the service message, and will work perfect,, i had the same problem,,
good luck
Posted on Apr 16, 2009
Both of my ink cartridges went out at the same time and i only replaced the black. now it has an error saying it will not print because i need to replace the color ink cartridge. but i'm trying to...
It depends on the model that you have. You can try one of the following to reset the ink counter and the printer will show a full color cartridge.
This is the procedure I used for an MP470. It is basically a modified version of that previously posted for the MP460.
1. Disconnect the power cable.
2. Hold down "On/Off" button.
3. Reconnect the power cable.
4. With the power button still down, press the "Stop/Reset" button twice.
5. Release the "On/Off" button.
6. The printer is now in "factory mode".
- wait until "idle" is displayed.
7. Press the right arrow button (next to the "OK" button) repeatedly until "Shipping Mode 3" is displayed.
8. Press the "OK" Button
9. Wait until "Without Cleaning" is displayed and then presss the "Stop/Reset" button once. (I pressed the ok button after Stop/Reset button on my MP470).
10. A test page should print.
11. Open the cover.
- the cartridges should position themselves at the far left - the cartridge removal location.
12. Disconnect the power cable.
13. Remove both cartridges.
14. Close the cover.
15. Reconnect the power cable.
16. Press the "On/Off" button once.
17. Wait until a "Replace Cartridges" message is displayed.
- insert cartridges.
18. Wait until the printer is operating in its normal mode. The display shows the normal start menu (ie: Copy).
The ink levels have been reset.
- check by going to printer>properties>maintenance>view printer status
this is what i had to do to get it to work with canon mp460
2. Hold down power button
4. With the power button still down, press twice the "Cancel/Stop" red button
5. Release the power button
6. The printer is now in factory mode...(wait about 30 seconds until it says "idle")
7. Press the down arrow (next to the "OK" button) until it says "Shipping Mode 1"
9. Now with it displaying "Without Cleaning" press the power button
11. Now open cover
12. Disconnect the power again
13. Take both cartridges out like normal
14. Close cover
15. Reconnect power cable
16. Press power button
17. Replace cartridges
MP-160 is different from MX300 so I tried my best with it...
The main solution is to reset the entire printer:
2. Connect it while holding down the power button
3. With the power button still down, press twice the "Cancel/Stop" red button
4. Release the power button
5. The printes turns into a kind of factory mode...(wait for about 10 seconds, utils it says "Idle")
6. Press the ">" (next to the "OK" button) once."Shipping Mode 3"
7. Press the "OK" button.
8. Press "OK" again for "Without cleaning"
9. A test page will print..
10. Open the cover, like you are about to change the cartridges.
11. Disconnect the power cable again.
12. Take out both cartridges.
13. Close the cover.
14. Connect the power cable once again.
15. Turn the printer on.
16. Now just put the cartridges back...
1. Press & hold stop/reset button, and then press & hold [ON/OFF] button.
2. When Green power lit, leave stop/reset button & press twice stop/reset (see orange indicator).
3. Leave On/Off button. Printer in actually service mode.
4. Press stop/reset 4 times (see orange indicator) if not blink restart above process from top.
5. After press stop/reset 4 times successful press On/Off button 3 times. printer will off.
6. Press On/Off button
Aug 30, 2011 | Office Equipment & Supplies
I refill the cartridge of my canon mp496 printer.I print images and everithing is ok but the ink lamps are orange .I don't know what to do ! Please ,help me !!
One of these reset methods should fix the problem
11. Open the cover.
11. Now open cover
14. Close cover
Jul 01, 2011 | Office Equipment & Supplies
Replaced ink compatable cartridges in my cannon pixma 350 and now its telling me to replace them cause the ink is empty Help
This will reset your cartridges to full settings. I have found these resets to work on many Canon models. Try the top one first.
11. Open the cover.
11. Now open cover
14. Close cover
Mar 27, 2011 | Canon PIXMA MX350 Wireless All-in-One...
Canon np258 cant operate after refill
You may need to reset the ink counter. Try one of the following solutions.
THis is the procedure I used for an MP470. It is basically a modified version of that previously posted for the MP460.
11. Open the cover.
11. Now open cover
14. Close cover
Mar 27, 2011 | Canon Office Equipment & Supplies
Printer jamed after putting in more paper and accidently pushed the power button off. Will not respond to anything I have tried.
Reset your Printer by following these steps for your Printer Model:
EPSON Stylus Color 900, 980
Pressing and holding LOAD/EJECT and CLEANING buttons, press POWER button, You will see blinking INK OUT led.
Release all buttons.
In 2-3 seconds time press and hold CLEANING button for 10-12 seconds.
EPSON Stylus Color 3000
Pressing and holding PAUSE, LF/FF and DOWN ARROW buttons turn on printer.
EPSON Stylus Photo 785, 895
Pressing and holding Maintenance and Roll Paper buttons, press POWER button, You will see blinking Error led.
In 2-3 seconds time until led is blinking press and hold for 10-12 seconds Roll Paper button, until all leds will blink.
EPSON Stylus Photo 890, 1280, 1290
Pressing and holding Maintenance and Roll Paper buttons, press POWER button, You will see blinking Power led.
Feb 27, 2011 | Epson Stylus Photo 785EPX InkJet Printer
Printer maintenance is in Progress. Scan after it is complete. Code : 2,114,0 I have useing in scan only. That is problem, how to slove this problem, Please help me.
This problem usually occurs when you try to scan a documents and the ink in the cartridges of the printer ran out.
I am assuming your printer is Canon MX300 because its posted under this brand/model.
Even if you successfully refill the ink in the cartridges, you will need to reset the printer so that it will think that the cartridges is fully refilled. Genuine canon cartridges has a special chip that can detect if your cartridge is emptied.
In that way, after resetting it, and the printer recognized the ink.. then that is only the time you can use the Scan command in the printer.
Make sure the cartridges is filled with ink.. then try to reset it.. here is how?
Now.. for some mx300 they cannot apply step no.6 because nothing haappens when they press ">" button....you can bypass that..assuming "idle" appear .... proceed immediately to step no. 10.
There are also times that you will only need to press the STOP/RESET button for at least 10 seconds and wait for it until the printer restart itself.
Just post back if you still have question.
Thank you for using Fixya.
Nov 22, 2010 | Canon MX300 Office All-In-One Printer
IS IT TRUE THAT THE CANON MX 320 IS THE WORST PRINTER IN THE MARKET? BECAUSES THE 5200 ERROR?
Not really!!
You can try two different procedures to clear the error.
1. Turn off your printer
2. Press and hold the STOP/RESET button
3. Press and hold Power ON button
4. While holding the Power ON button, release the STOP/RESET button
5. While holding still the Power ON button, press twice the STOP/RESET button
6. Release the Power ON button
7. Wait until it display an "idle" message. It will take about a minute.
8. When "idle" appear, open the top cover to expose the cartridges.
9. Lift up the cover for cartridge holder and take out both the black and color cartridges
10. Return the cover of cartridge holder and turn off the printer
11. Return the top cover and turn on the printer again
12. After the printer initialize, return the cartridges.
The next procedure is also the key for making the old cartridge reusable after getting reffiled
1. Press and Hold the STOP/RESET button and wait until it self restart.
2. Release the STOP/RESET button the the printer is restarting.
3. Wait for a few seconds
If you bumped in to a different error codes See My
Helpful Tips for this Printer Pixma MX320 and MX328.
If this solve your problem please give some good ratings too as this will help me too. Thanks.
Aug 14, 2010 | Canon PIXMA MX320 Color USB InkJet Printer
How to reset a Photosmart C5180 All-In-One InkJet Printer
The below are different types of reset for your printer.
Power Drain
  • Turn OFF the printer, disconnect the power cable from backside of the printer and from wall outlet.
  • Press and hold the Power button for 60 seconds.
  • Connect the cable and turn ON the printer.
Partial Reset
  • Remove the power cable from back side of the printer while its ON.
  • Press and hold "#" and "3" button, while holding them both insert the power cable and release the button after 10 seconds.
  • If printer turns OFF, press power button to turn it ON.
Semi-Full reset
  • Remove the ink cartridges.
  • Press and hold "#" and "6" button, while holding them both insert the power cable and release the button after 10 seconds.
  • Insert the ink cartridges.
NVM Reset
  • Press and hold "OK" and "Cancel" button, while holding them both insert the power cable and release the button after 10 seconds.
Thanks & Regards,
Rizwan.
Jan 31, 2010 | HP Photosmart C5180 All-In-One InkJet...
The off and on button is on but the screen says it is shutting down, but it will not shut down or let me go on to another stage. I have pluggged and unplugged it. It still comes back to shutting down mode
Hi
Try resetting the printer, follow below steps
Power Drain:
Partial Reset
Semi-Full reset
Regards,
Rizwan
Jan 27, 2010 | HP Officejet J5780 All-In-One InkJet...
The led screen shows genera error
you need to reset your printer try doing this
  • Press and hold “Stop”, “Maintenance”, and “Power” buttons for about 10 seconds. A message will come on the screen saying counter is reset and to turn the printer off. The R200 and others don’t have a screen so just wait until the 10 seconds is up.
  • Turn the printer off, unplug the power cord. Wait about 1 minute and power the printer back up. The counter will be reset. That’s all there is to the reset procedure.
Nov 24, 2008 | Epson Stylus Photo R300 InkJet Printer
Epson Stylus Photo R300 InkJet Printer Logo
164 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
