Question about Brother IntelliFAX 2800 Laser Fax
Fax machine will not pick up
Hi there. Our phone line was unplugged and plugged back up this weekend, and since this time the fax machine will not pick up.. any suggestions. Thanks.
    Champion:
  • 320 Answers
First make sure there is a dial tone on the line, next reset up the machine in send and receive mode. if all of this fails, then you have a bad ncu board which is the phone board
Posted on Jan 16, 2009
Brother fax p275
Remove the backup battery and unplug the fax machine and leave overnight. By morning I'am hoping it will wipe everything clean when plugged back in along with the battery. But it will mean you will have to set your date and time again.
Mar 07, 2012 | Brother Office Equipment & Supplies
Hi havent received a fax for a day..just sent myself a fax from elsewhere but not received it...what settings should i check ? thanks .
Pick up the handset and check that you have "dial-tone" on your machine. If you dont, check and make sure you have the phone line plugged in to the "line" jack on the back of your fax machine.
If you still dont have dial tone, plug a phone into the wall outlet for your phone line and make sure it works.
Jan 06, 2011 | Samsung SF360 Plain Paper Inkjet Fax
Can not get a dial tone. Phone appears to be off the hook. How do I trouble shoot it?
Unplug the phone line from the fax machine. Wait at least 1 minute then call the phone number that goes to the fax machine from another line such as a cell phone. Make sure you get a ring and not a busy signal. If you get a ring then hang up the phone. Plug in the fax machine again and call the fax number again. If you get a busy signal then either your phone if off the hook, the switch that is actuated when the phone is placed in the cradle is bad or your modem in the fax machine itself has gone bad. Another thing to try is unplug the fax machines power cord for 30 seconds then plug it back in. I have seen the modems get "locked up" and keep the phone line open. Unplugging will sometimes reset this and get it working again.
Good Luck and Thank You for using Fixya.
Sep 03, 2010 | Brother IntelliFAX 775 Plain Paper Thermal...
Fax Machine vs. Answering Machine
If you are there unplug the phone line from the answering machine. -Carl
Jul 24, 2009 | Brother FAX-575 Plain Paper Thermal
Hi i cant send a fax
First thing is to ensure that you have dial tone by picking up the handset on the fax machine and listening for dial tone.If there is no handset take a standard house phone and plug it into the jack where the fax machine was inserted. If there is dial tone on the phone then I would advise you to turn the power off the fax for two minutes then power back on. If there is no dial tone on the phone line contact your vendor or local phone carrier and report NO DIAL TONE
May 30, 2009 | Lexmark F4270 Plain Paper Inkjet Fax
Need to set up phone/fax instead of just fax
I have a HP Officejet J6480 All-In-One and needed the answering machine and fax to be on at the same time.  I called the help line at HP and they said I needed another phone line into the home but I tried this and it worked.
First I got a different phone number for the fax machine - they do this for no charge at my phone company. This is not another physical line into the home - it is just another phone number with a different ring - it rings 2 fast rings for the fax machine instead of the phones regular one ring. I set the answering machine built into the phone to pick up after 4 rings and I set the fax machine to pick up on 2 rings. Be sure to set it so the fax pick up number of rings are less than the answering machine pick up number of rings.  It worked for me. Hope this works for you too.
Apr 24, 2009 | Brother MFC-260C All-In-One InkJet Printer
CANNOT RECEIVE FAXES ALL OF A SUDDEN
Check the phone line with a basic old phone plug it into the fax line do you get a good dial tone, and no noise on line. Also check the phone line call ATT and have them check the number move the fax machine to different plug. power off the wait tens second power on. check the phone line connector.
Mar 31, 2009 | Minolta Office Equipment & Supplies
Machine does not answer phone
Some things to check-
I know you said it wasn't unplugged but check the phone line is plugged into the line socket. I don't know how many times I had people who people unknown to them (children, cleaners) have knocked out the line cord and plugged it back in the wrong socket.
Hit the on-hook or hook button and check for dial tone. This will check if the line is still working.
Also the fax will have a mode button. If it has been bumped while moving it could be on manual mode (the machine will not automatically pick up)
Jan 29, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
Receiving fax problem
try unplug the phone line and use another phone to call again, then c if it has a fax tone, if it does, there might be another fax machine that picks up the fax before the Dp-190 pick up the fax.
another thing you can try is to change a new phone line that connect between ur machine and the plug.
Dec 19, 2007 | Panasonic DP190 All-In-One Laser Printer
Brother IntelliFAX 2800 Laser Fax Logo
89 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
