Question about Compaq Presario 700 470024-192 Notebook
Keeps restaring... Hey guys! Im not so good at this so bare with me please, everytime i try to start my Presario 700, it says " were sorry for the incovenience, but windows did not start succesfully." then it gives me list of things to why this might have happened. Then it gives me options to how i want to start windows : safe mode, safe mode with networking... etc and start windows normally. I have tried all of the options given to me , it goes to windows xp screen and then goes right back to the compaq screen. Then it just goes back to "were sorry" part.Same thing over and over again. Does anyone know how i can fix this problem? Thank you!
  • 1 more comment
  • Vicki nottellin Feb 22, 2007
    Yea i did it just does the same thing all over again :(
  • Vicki nottellin Feb 24, 2007
    OK thank u very much ill let you know if it helps ! thanks again!
  • Imraan Dec 31, 2007
    I have the same problem. was the solution with the cmos battery helpfull and did it slve the issue?
The cmos battery is inside the laptop itself , you have to remove the keyboard and then remove the heatsink , then you will see it on the top right hand corner.
Posted on Sep 09, 2007
    President:
  • 2,961 Answers
Did you try last known good configuration?
Posted on Feb 22, 2007
  • andrew pester
    andrew pester Feb 23, 2007
    Ok you seem to be stuck in a loop, it could be that the bios is corrupt and cannot start the first 640kb of memory to get into windows.
    You will need to locate your cmos battery inside, and remove, check to see if flat and replace if neccassary,but where it is anybody's guess, you will have to remove the covers underneath.
SOURCE:
I wanna reset to factory settings on my compaq presario 700
You should look for the cd´s that came with the laptop and keep in mind that the cd´s will erase everything on the computer. Im presuming that your talking about the operating system of course...
Nov 19, 2009 | Compaq Presario 700 470024-192 Notebook
The sound on my pc is barely audible.
Did you go to 'Control Panel', sounds, and change which kind of speakers you have, or change the main volume in 'Advanced Volume Controls'? Please give us some more information that we can help you with...
Jun 13, 2009 | Compaq Presario 700 470024-192 Notebook
Xp install stalling at 79% on compaq presario 700
Insert Xp Disc-> Format C: only install the OS its that easy
Feb 02, 2009 | Compaq Presario 700 470024-192 Notebook
1998 plymouth breeze
If you keep popping fuses everytime you try to start the car, you have a bare hot wire grounding out somewhere. That will cause the fuse to pop everytime you turn the key on. the best way to fix it is if you know someone who is good with electrical wires. Have them pull the fuse panel out and follow the wire until they find where the wire is bare. Have them fix that bad spot and that should fix your problem.
Aug 04, 2008 | 1998 Plymouth Breeze
Compaq Presario 700 wont stay on...
Hi ,
this is problem with battery backup if your battery backup is not sufficeint for laptop it goes standby mode .....
please do one disconnect battery from laptop connect power Adapter to laptop & turn on laptop thrugh adapter supply check it out if your laptop is not getting standby you need to be replaed battey ...
If this Information is useful for you please rate me as you wish......
Jun 10, 2008 | Compaq Presario 700 470024-192 Notebook
Automatic detection of lcd projectors to my hp compaq presario c700
try to set your resolution on your laptop, it have an option for proyektor setting, i've done it but now it displyed not horizontally but vertically, do you have any solution??
Jun 05, 2008 | Compaq Presario 700 470024-192 Notebook
Presario c733tu
you will need to go to the manufactures website and then into their support link, then driver downloads, you will need to select your model laptop. once you are at the correct driver downlaod area, download the drivers you need. BPCS
Dec 25, 2007 | Compaq Presario 700 470024-192 Notebook
Presario 700
Hey check the following link for compaq presario 700 manual:
http://www.geocities.com/hpmsgs/700xx/
Nov 18, 2007 | Compaq PRESARIO 700 SERIES 14.1 LCD Hinge...
Compaq Presario 700 470024-192 Notebook Logo
104 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
