Question about Maytag PAV2300 Top Load Washer
Loud screaming noise while on spin cycle
While the machine spins it's making a really loud screaming noise.
  • derek_r_king Dec 08, 2008
    Thank you very much! So i have a new belt so whats the fix for a dry transmission? Thanks again for your help!!
  • 51 Answers
Bad belt or the tansmission is dry
Posted on Dec 08, 2008
  • fredcause
    fredcause Dec 09, 2008
    buy a rebuilt one from the web which are readily available after disassembling the agitator and tub the complete source and instructions are available on the web through a couple of suppliers.
    or while its apart see if there is a plug to add oil but chances are the seal is trashed
The spin cycle is very noisy. What could be the problem?
hi robyn.
A washer making a loud noise during spin cycle can also be caused by a faulty drive pulley. The pulley is what the belt (if applicable to yourwasher) rides on to spin your washers tub. The pulley can be made of plastic or metal. It could be simply worn out or just loose.27 Jul 2015
How To Fix A Washing Machine Making Noise During The Spin Cycle ...
https://removeandreplace.com/.../washing-machine-making-noise-during-the-spin-cycle-...
or try this link might help you.
washing machine spin cycle is very loud Google Search
Nov 18, 2017 | Washing Machines
Loud noise during spin cycle now they are stacked
a loud noise comes when you forget to remove shipping bolts after installation or if the shocks are worn out it makes noise thirdly the bearings might be worn out if the washer is more than 6years old
Jan 21, 2013 | LG Cherry Red Steamwasher Wm2487h Front...
Kenmore Elite Oasis HT makes loud noises during spin cycle.
The tub may be unbalanced and wobbling. This may be due to washing heavy items such as rugs, towels, etc. If it is noisy with regular laundry loads, the mechanism that supports the tub may be loose or broken.
Sep 10, 2012 | Kenmore Oasis Agitator 4.5 cu. ft....
My washing machine is making a loud screaming noise..it's still washing my clothes but when it's on the spin cycle it's almost unbareable.
As the washing machine is making a loud noise I think the first thing I would request you to do is lift up the washer from the front, remove the belt and check the pump by rotating the pump pulley manually. If does not move freely then replace the pump.
Let us know if you want any further clarification.
Thanks for contacting fixya.com
Dec 06, 2009 | Estate ETW4400VQ Top Load Washer
Loud noise, then not so loud, but now electrical burning smell and little draining
the smell is your clutch and the lack of draining is a clogged washer drain protector. see these at www.repairclinic.com drain protector is part 541811 and clutch is 2670. go there enter model number and scroll down to the red 100 click it and look for these part numbers.
Mar 02, 2009 | Whirlpool LSR5132PQ Top Load Washer
High pitched noise when spinning or slowing down(cat screaming)
Sounds like you have bad bearings. I suggest you get it fixed before it creates further issues.
Feb 26, 2009 | Ariston Technologies AW125NA 13 lbs. Load...
Frigidaire top-load washer Loud noise during spin
its either the upper spin bearing or lower spin bearing. the upper can be replaced by itself but the lower requires the transmission the be replaced
Nov 20, 2007 | Frigidaire FWS833A Top Load Washer
Loud screaming sound during spin cycle
The screaming noise is probably from a dry bearing in the motor, it will probably come and go and shouldnt cause to much problem, they are supposed to be self lubricating but sometime they run dry.
Oct 18, 2007 | GE Spacemaker WSLP1100D Top Load Washer
Maytag PAV2300 Top Load Washer Logo
237 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
