My washing machine is beeping and displaying PU on indicator
It does not seem to be dumping the water and unsure what PU stands for??
  • Anonymous Mar 19, 2014
    wont pump out water
PU stands for drainage problem and so we our checking the pump!!
Posted on Dec 09, 2008
My washing machine goes fine until half way through wash then comes up with error code PU and beeps until I turn it off...will not drain out the water? Simpson encore 556
simpson encore pu Unsolved Problems - Fixya
www.fixya.com/unsolved_problems/simpson_encore_pu
Unsolved problems for simpson encore pu question. Get free help ... My simpson encore 757 shows PU error code. What is this? ... Simpson encore 556. Aug 22 ...
Sep 10, 2015 | Simpson Washing Machines
Oko 72630. Why is it stuck on rinse cycle?
Could be several reasons:
- Selected the "Night cycle" program (means standing with the drum full of water, reason: too much noise in the spin cycle)
- Set to the "Rinse hold" (means standing with the drum full of water, reason: wrinkles on the clothes)
According to your description I think that this is not a failure otherwise error E20 will be appears on display.
Once the washing programme has come to an end, END illuminates on the programme progress display.
If RINSE HOLD was selected, the display beside the START/ PAUSE button flashes.
1. After a rinse hold, the water must first be pumped out:
- Either press the START/PAUSE button (the water is pumped out and the washing is spun according to the completed programme;
After the START/PAUSE button is pressed again, the spin speed can still also be changed during spinning), or
- Turn the programme selector to PUMP OUT and press the START/PAUSE button (the water is pumped out without spinning),or
- Turn the programme selector to SPIN or SHORT SPIN and press theSTART/PAUSE button (the water is pumped out and the washing is spun or gently spun).
At the end of this programme step, the END indicator will illuminate.
2. Open the door.
As soon as the DOOR indicator lights up green, the door can be opened.
Dado
Aug 15, 2015 | AEG Washing Machines
Washing Machine - Bowl is full of water, won't progress to spin cycle. PU error code displayed.
When all else fails its usually the computer. There's a circuit board that goes bad (mine did after 20+ yrs) and cost around $60. You can usu. see a bulging resistor, capacitor, etc and smells 'burnt' to tell. If you're getting an error code that made be computer declaring itself dead! Sorry. Those beasts are SUCH a pain some times!
Link is just for pics of circuit boards and some info. DON"T go by insane price seen! Not true. WASHING MACHINE CIRCUIT BOARDS
Maybe try Repair Clinic for a video. They MAY have a decent price on your board. Sears has its own site. LG Washing Machine Circuit Board Timer Parts
Jan 11, 2015 | Washing Machines
Is there a special code to direct water to pump, dump bucket or drain
That would be the "Pump" button on the control panel. When you press it, your dehumidifier display should indicate "PUMP", and the unit should start pumping water out that little port at the center rear of the dehumidifier.
Alternatively, you could stand the dehumidifier on a counter and direct your waste water out the larger hose connection into a sink.
I personally carry it (more than five gallons per day) upstairs to the laundry, because it's distilled water - the softest water you can get. Works GREAT in the washing machine. 8) 8) 8)
Jul 30, 2014 | DeLonghi DD50P Dehumidifier
Does not drain, PU warning on display
Is there Bart Dryer? PU Indicates you have a blocked drain. This could be simple as by cleaning the screen filter. Or more involved. First check all your drainage hose(s) and the Bellows below the tub thru and thru the whole length. Be sure water can flow thru it. If it is still not draining then by Now you know if is the drainage pump is bad and needs to be replaced
Jul 26, 2014 | Simpson Washing Machines
My 2005 ford freestar has a high pitched "whistle"
I am having this same issue. I have changed my brakes and now I was going to change the front wheel bearing, but unsure to dump a lot of money out on an unsure fix.
Let me know if anyone has a fix?
Feb 20, 2011 | 2005 Ford Freestar
The machine will not start. Digital display EF. Continual beep.
FE means overflow condition. That means sand or trash has gotten into the tube going from tub to water level switch. So find that hose and blow it out. Remove the standing water and retry.
Jan 03, 2011 | Washing Machines
Our simpson washing machine is not spoinning and the letters PU flash on the electronic display panel.
PU is pump fault. Usually caused by a blockage. Machine will not spin until all water is drained
Thank You
Sep 09, 2010 | Washing Machines
Fills with water then dumps water over & over seems that is all it does
Does seem like the anti flood system (polystireene float and micro switch at base of washer is triggered) this device automaticaly pumps water out when triggered due to water leak. The water leak could be from a small hole in pipe or a pipe clamp. The washer will only take in water and pump out water if the device is triggered. You must clear the water leak and dry the base of the washer before it works through the full cycle.
Jun 01, 2010 | Siemens 24 in. SE25A091 Hi-Line...
Washing Machines Logo
219 people viewed this question
Top Washing Machines Experts
