Question about Reddy R155D Utility Heater
Reddy Heater 155,000 BTU
Won't start. Igniter fires, fuels drips and shoots out other end where it should be hot. Unit is very new.
  • rockford11 Dec 08, 2008
    Motor starts and blows fine.
  • 232 Answers
Question- "won't start" sounds like you have motor problems.
Posted on Dec 08, 2008
  • Jerry Magee
    Jerry Magee Dec 09, 2008
    I want to help you, please understand this. but I need descriptive information to go on. "Fuel drips" does not tell me much. Drips from where?
    Here is what I need to know:
    1. Is a fog of fuel being sprayed from the nozzle?
    2. Is the ignitor glowing red at start up?
    I can only advise if you will troubleshoot. You must troubleshoot to find out whether you have a fuel delivery problem or an electronics problem.
    Read these troubleshooting tips.
I have a propane 155,000 btu forced air heater. when it runs the air burns my eyes
Your mixture is too rich. Go to http://www.reddyparts.com which has assistance with setting the fuel balance or get a new control valve from them.
Thanks for using FixYa and for the great rating. Please consider a testimonial. Thank you.
hardrocko
Jan 12, 2011 | Reddy Heater-30,000 BTU Propane Forced-Air...
70,000 btu reddy heater, starts right up but smells bad.Instaled new filters , fuel and igniter low hours 100 or so. disassembled tip everything looked perfect.nosecone turns orange from bottom up and...
I hope you are burning K1 kerosene as opposed to off road diesel. Diesel stinks no matter what you do to the heater. A couple things that have happened to me are, fuel selection K1 is it, when storing for the end of the season old fuel can cause water from condensation to build in the tank. When water is in the tank you get ignition and it burns just not hot enough to burn the fuel completely, this causes the heavy odor. Old fuel will do the same it is as if the fuel thickens to an oily state and becomes heavier. It just does not burn hot enough to get rid of the odor. You can try increasing pump pressure this changes air fuel mixture and you may get rid of the odor somewhat.
Dec 23, 2010 | Reddy Heater-70,000 BTU Kerosene w/T'stat
L.P. Propane Heater not staying lit Fairly new heater (Reddy) 30,000 BTU Piezo Igniter not functioning use long match and unit fires nice. plug in /turn on blower good once I let go of primer valve button...
Sounds like you have a bad gas hold on valve. I have a tip at http://www.fixya.com/support/r4258201-fix_gas_reddy_heaters_will_not_continue which explains the problem, how to fix it and where to get the parts. Let me know if you need more help.
Thanks for using FixYa and for the generous rating.
hardrocko
Jul 30, 2010 | Reddy HEATER RLP30 30,000-BTU PORTABLE LP...
Propane heater wont stay running
is the sensor for the thermocouple located in the right spot in the flame,remove it and if you have access to a propane torch,heat the end till its red hot and leave it connected to the gas valve,then start the unit and this will tell you if the sensor is properly positioned in the pilot flame on the unit itself,if not you could have a defective new thermocouple or another safety device keeping it from staying lit or the gas valve is faulty
Jul 28, 2010 | Reddy HEATER RLP30 30,000-BTU PORTABLE LP...
Reddy heater 155,000 burning good then rich, any help????
Check your fuel filter,, could be running out of fuel,due to obstruction in fuel delivery system. Either crud in the tank clogging up the pickup,,or maybe even water in your fuel. Your filter might be it,,have you been running diesel?? check it out....
Dec 11, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
100,000 redi heater wont fire just blower fan runs
The igniter is most likely bad.Make sure the igniter is not working,and the pump for the fuel is working,one,or the other is not working,if it is the fuel,order a new pump kit,with impelar,and if it is the igniter,replace it with a new one.
Oct 21, 2009 | Reddy Heater-70,000 BTU Kerosene w/T'stat
Reddy Heater won't stay running
Dear travelinman4, 02-21-2009 18:24 EST (USA)
Re: Reddy Heater "Won't Stay Running"
Model R150A
Old Fuel? Added a Can of Fuel Booster? Used Starter Fluid?
Spark Plug or Igniter?
Gas, Propane, or Kerosene?
jack
Feb 21, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy heater 115 just turns on then shuts off
a new flame sensor is in order, if you have spark and it blows fuel then thats the answer. you can get one thet will fit from Mr. Heater for 3 bucks. the wires are different so just splice the to your old wire harness, there is no wrong way to hook them up.
Jan 15, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy R155D Utility Heater Logo
297 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
