Question about Samsung HCM4215W 42" Rear Projection Television
Red Convergence out on right side of the screen only
Hello, I recently got a Samsung HCM4215W 42" TV, and have found that almost immediately after turning on the set, the red convergence goes out. However, it's fine when the set is first turned on, and it's only on the right side of the screen (as you are facing it). Is this a convergence board problem, or something I can adjust?
  • collin_mcgre Dec 15, 2008
    I replaced both ICs, convergence can be perfectly adjusted now.
  • Samsung Master
  • 3,459 Answers
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see moreRed Convergence out on right side of the screen on - bb0cf99.pngnd find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Mar 25, 2010
Samsung 42'' HCM4215W image looks like it's in #D
Ill have to look up the part numbers , but it is a common problem caused by the convergence board at the back of the device. replace the TDA*** for the color that is faulty and the problem should be solved.
After replacing the TDA*** you need to adjust the convergence again and perform an auto-fucus and convergense adjust again
Jul 08, 2009 | Samsung Televison & Video
Samsung 42" rear projection HD tv issue
pico fuses are those small on board fuses, usually soldered into place, that protect important parts of the board.
Feb 26, 2008 | Samsung HCM4215W 42" Rear Projection...
Blinking power light after replacing convergance board.
Your chips are most likely bad or you bridged the soldering.
For all others with similar convergence problems
This is a common problem.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Red/Orange looking video
You can see some examples and find a fix here...
Jun 06, 2009 | Samsung HCM4215W 42" Rear Projection...
Cannot not line up the red and blue lines on my samsung projection tv. it is a 2002 samsung tv
Needs new convergence amps and possibly a few low ohm resistors.
Those Samsung amps usually run hot to the touch and sometimes only last 4 to 5 years depending on usage.
Apr 20, 2009 | Samsung HCM4215W 42" Rear Projection...
Samsung HCM4215w has wavy red lines and bowtie effect
Are you saying that after installing a new convergence board, you still have the same issue? If that's the case, another new board isn't going to resolve this. Also, you can't do a factory reset. Doing that would lose all the convergence and geometry data in the TV and would require a qualified technician hours of work to restore the settings. If you've installed a new board and have the same problem, suspect a problem in the TV's power supply. All convergence circuits require 2 voltages to operate. There will be a postive and a negative voltage of the same value. If you're missing either of these voltages, your convergence will never work properly.
michtech
Feb 17, 2009 | Samsung HCM4215W 42" Rear Projection...
No picture on samsung hlp5063wx/xaa
to test this set
unpug the 4 pin conector labeld + and _ 20v on the cg convergence module
if set turns on, the problem is that modual
repaie
replace bolth convergence IC'c stk392-040
also check all 3.9 ohm resistors and both pico fuses.
regards,
daniel.
Jan 16, 2009 | Samsung HCM4215W 42" Rear Projection...
Red Convergence Issue( Samsung HCM4215W)
Bad chips or faulty soldering.
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
Example Photo:
Symptoms
Example Photo:
You can see more examples and find a fix here...
Dec 23, 2008 | Samsung HCM4215W 42" Rear Projection...
Samsung HCM4215W
Unplug the power.
Remove largest plug from convergence board. Plug in TV, see if it starts. If it does, then a convergence IC is are shorted.
Repair convergence
easyab
Jul 28, 2008 | Samsung HCM4215W 42" Rear Projection...
Tv wouldn't turn on, unplugged convergence board, turned on, replaced STKs, still have convergence problem
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 07, 2008 | Samsung HCM4215W 42" Rear Projection...
Samsung hcm4215w Convergence board problem
Use PANASONIC STK's.They are expensive,but they hold up!Safe,durable repairs require OEM or BETTER quality replacement parts.
Sep 27, 2007 | Samsung HCM4215W 42" Rear Projection...
Samsung HCM4215W 42" Rear Projection Television Logo
94 people viewed this question
Henry  Thomas
Henry Thomas
