posted by Nura on Feb 22, 2007
Mistakly i changed my bios language from english to some other language. how can i change back in to english?
2 Other Users Have The Same Problem
Comment by Guest, posted on Apr 05, 2008
Mistakenly changed lanuage from english to french. Want to know how to change back to english.
Comment by Guest, posted on Mar 29, 2008
Please my phone have change from english to chiness, so I want to change I back to English the language I can understand.
Best Solution
posted on Feb 24, 2007
Hi
Go to the BIOS utility and change the language:
To run the Setup Utility program, use the following procedure.
1. Power-off the computer and wait for a few seconds until all in-use lights go off.
2. Power-on the computer.
3. When the Setup Utility prompt appears on the screen during start-up, press F1. The Setup Utility menu will appear.
4. Follow the instructions on the screen.
5. When finished, select System Summary to verify that any configuration changes have been accepted.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on May 16, 2008
For solving the problem do the following:
1. Switch on the system
2. Press and hold the Del or F2 key to enter into BIOS
3. Select the default load settings
4. Save it by pressing the F10
5. Restart the system
6. Select the safe mode by pressing the F5
7. Select the restore point on the date which the settings had been changed.
8. Save to the point
9. Restart the system by normal mode
Let me know if your problem is solved and rate me as FIXYA!
Suggest a new solution for this problem
Post a New problem for IBM NetVista PC Desktop
Email this problem
Email this problem
Can you Help with these PC Desktops problems?
power supplay of d530 and 5000
Hello! My name is Lev Rosenblum... Answer This...
Moved Computer, 150 miles and...
A close friend was kind enough... Answer This...
Repair Service
Find PC Desktop Repairman Near You:
