Question about Cuisinart DCC-2200 14-Cup Coffee Maker
Leaks water from the bottom
I notice every morning that the coffee maker has leaked about a half cup worth of water. I have the 14 cup cuisinart.
  • heridea Jan 08, 2009
    .My Cusinart DCC-2200 leaks from the bottom. What if you don't have the warranty?
Under warranty. Cuisinart will resolve. Thank you.
Posted on Dec 09, 2008
Cuisinart dcc2800 Perfec Temp 14-Cup Programmable Coffeemaker
cuisinart DCC-2800 leaks water from under side, after 5 months the lid spring lock broke'.. then only after about a year and a half, and just out of warranty!!!!!!!, it must have sat on the store shelf over a year before we purchased it new. bad design for such a costly coffee maker and Cuisinart was not much help either when we called, I called several months earlier to get the problem fixed but was told to call back because there system was down for maintenance, so now when I had the chance to call back they tell me they did not want to fix it and only offered me a discount on a new one, why would I want to buy another when I spent sooo much on this one only to have water leaking all over my counter, table, chairs and floor'? never again, next one will be all stainless so it wont leak. so do not have to worry about asking for help again on such a expensive coffee maker.
May 03, 2013 | Cuisinart Dcc-2800 Coffee Maker, 14 Cup...
How to fix the leak from the bottom of my cuisinart dgb-900bc
Re: Cuisinart grind and brew model DGB900BC leaking from the bottom. Finally fixed it before buying a new one. Remove the 4 torq screws (#10 bit check auto stores) from the bottom and remove the bottom. You will see a horse shoe shaped metal coil that heats the water from the resevoir. I found that the coil had a small hole in it. Cleaned it well and applied a coat of epoxy paste to the leaking area ( I used a product called PC11 from Ace) So far, no leaks, and the coffee maker is working like new.
Aug 10, 2012 | Cuisinart Dgb-900BC Grind & Brew Thermal...
Our cuisinart kcup coffee maker is leaking out the top of the machine. When it brews instead of a stream coming out of the pour spout, the machine leaks water all over the main brewing piece (where the k...
Take out the used kcup and GENTLY explore the holder fitting. There should be a sharp point in the bottom that punctures the bottom of the kcup to allow the brew to flow out the spigot and into your cup. There also needs to be a sharp point on the top to punch a vent hole for the water to enter. It they aren't both open, coffee and grounds will spray everywhere. Take it apart and clean thoroughly as well.
Nov 02, 2017 | Cuisinart Keurig B50 Single Cup Coffee...
I love my Cuisinart 10 cup coffee maker, but I hate my pot. Every time I pour a cup of coffee the pot leaks. I have tried removing the lid and the pot still leaks. Please help I am getting tired of...
Be careful! The top will soon disconnect from the bottom! I've had the same problem for the last few months. This morning (11/19/10) the top of the pot seperated when I poured a cup of coffee and half a pot of piping hot coffee spilled down my right leg. I'm on hold with their customer service department as I type this. Has anybody else had the same issue?
Regards,
Harry B.
Nov 11, 2010 | Cuisinart Grind and Brew 10 Cup Coffee...
The coffee maker just quit midway through brewing this morning with half a resoviour of water left in it. I cleaned the screen at the bottom and determined there is no clog. Perhaps the heating element...
That has happened to me, and I ran a full 10 or 12 cups of vinegar and then 3 more times of water thru the coffee water resoviour and it took care of the problem. It is probably overdue for a cleaning.
Jan 11, 2010 | Cuisinart DGB-600BC 10-Cup Coffee Maker
Won't brew all the water comes out the bottom of the maker
Cuisinart – leaking from bottom
There is a tube inside that is melted, damaged - cannot get this part from manufacturer. I would call Cuisinart to see if you are still in warranty.
Here is the basic troubleshooting for the Cuisinart coffee makers:
Make sure all baskets are in proper place – especially if unit is beeping.
Do not use a paper and a gold-tone or other permanent filter at the same time.
Unplug for LONGER THAN 15 full minutes to reset.
Clean by brewing 2 oz of distilled white vinegar/2 oz water.
If these methods fail, the unit probably requires replacement – call Cuisinart as they have a longer-than-standard warranty.
-Tha Mp3 Doctor
Oct 20, 2008 | Cuisinart DCC-1200 Coffee Maker
Cuisinart Grind and Brew 10 cup coffee maker warm water leaks from bottom during brewing.
Replacement time. a certain percentage of thse have this problem. There is a small, non-replaceable tube in the inside toward the bottom that has become melted/damaged.
Oct 12, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Water leaking from bottom of coffee maker
The water hose on the bottom of the coffee maker is worn, due to the heat. It needs to be replaced. this is the second time for mine.
Mar 24, 2008 | Cuisinart DCC-1200 Coffee Maker
Leaks water
no b ut I have the same problem
Oct 22, 2007 | Cuisinart Brew Central DCC-1200W, 12-Cup...
Cuisinart DCC-2200 14-Cup Coffee Maker Logo
649 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
