Printer connected to HUB but not functioning
Paper light flashing non stop unable to resolve problem
  • 3 more comments
  • judylinda Dec 08, 2008
    There is paper in both trays no paper jam - the printer was connected to a server once - now connected to the HUB hence the reason why it will not print - it tries to print then returns to flashing paper light
  • judylinda Dec 09, 2008
    Done all of the above still paper light flashes!
  • judylinda Dec 10, 2008
    Thank you for your assistance in this matter. The problem has now been resolved.
  • Dan
    Dan May 11, 2010
    For clarification: Is was connected directly to the server and now it is networked?
    Have you assigned the printer with an IP and remapped the printer connection to this IP?
  • Dan
    Dan May 11, 2010
    Paper light usually means out of paper or paper jam. Have you checked for a paper jam or misfeed?
    Sergeant:
  • 236 Answers
Glad you go *** fixed!
Can you post your solution? It may help someone else with the same problem.
Posted on Dec 10, 2008
Paper light and ink light keep flashing even after ink refilled can't print epson L110
could you make shore the printed circuit on the cartridge/s is not obstructed and clean and shiney copper colour and check the part it connect to the printer any obstructions will stop the printer from reading the cartridge.
Aug 09, 2017 | Epson Office Equipment & Supplies
Trendnet TU3H4 USB3.0 Hub does not work in windows 8. Device manager says it is (not functional)
HelloI have the same problem!I have a message to the support
https://www.trendnet.com/asp/helpdesk/
Kind regards
Feb 03, 2013 | Trendnet Tu3H4 4Port Usb 30 Hub External...
After changing the ink of my printer, (PIXMA ip4500) I experience the following problems: 1) green and the yellow light keep flashing non stop when the printer is turn on. 2) No lights show to...
Replace the applicable ink tank with a new
one, and close the scanning unit (printer
cover).
Printing with a once-empty ink tank can
damage the printer.
To continue printing without replacing the
ink tank(s), press the Resume/Cancel
button for 5 sec. or longer to disable the
function to detect the remaining ink
amount. After the operation, it is recorded
in the printer EEPROM that the function to
detect the remaining ink amount was
disabled.
Aug 23, 2011 | Canon Pixma iP4500 InkJet Printer
I keep getting the Unable to clean message, even after cleaning manually. Is my printer about to go to printer heaven?
Resetting purge counter:
1) Enter machine maintenance mode (on MFC210C all four photo/copy/fax/scan lights flash in maintenance mode). Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
FAX models with numerical keypads: Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the "up arrow" key four times to enter the maintenance mode).
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine's log information list (function code 80).
3) Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
4) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
5) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
6) Press the 9 key twice to return to the standby state.
Mar 31, 2011 | Brother MFC 420CN All-In-One InkJet...
The screen on the printer is flashing e then 3 then 0. I have unplugged the printer, unconnected the cable then started it all back up but it keeps flashing that
If it is a Canon printer:
Clear the EEPROM
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber full
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD over current error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
Nov 16, 2010 | Office Equipment & Supplies
Green clean light wont stop blinking unable to use dishwasher . It is an energy saver. the drain button works ..and when you push start the light comes on but will not run for cleaning
Hi
Thanks for using FixYa. If the clean light flashes, pauses, and then repeats. When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 19, 2010 | Kenmore 16602 / 16604 / 16609 Built-in...
E3 flashing wat does it mean
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
Direct Printing
E22 Carriage error
E29 EEPROM error
3 times for Orange EEPROM reset.
button pressing
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 01, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
No paper light ligted even after paper is loaded
Flashing resume light also can mean:
1. cartridge is missing or an incorrect print cartridge is installed
2. cartridge is out of ink
3. dirty cartridge contacts
4. paper jammed
Check are cartridges firmly snapped into place and not empty. Use water to wash copper on cartridges if contacts are dirty.
Apr 25, 2009 | HP DeskJet 690c InkJet Printer
E3 flashes when turned on
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
prito-i-1
Feb 22, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Unable to print to canon IR 2020 when connected through router.
Try to conect directly with cross utp cable to an pc, if every thing works, its your network problem (maybe privilegies, banns,...) if not ... good luck :-)
Try to reconect the pcb s
Dec 10, 2008 | Canon imageRUNNER 2020 All-In-One Laser...
64 people viewed this question
jasbo
jasbo
