Question about Plumbing
BOILER PRESSURE Hi guys, I am having trouble with the pressure in my UTICA boiler reaching 30 psi and slightly tripping the valve. I have checked the expansion tank and it appears to be working properly. The pressure rises to just 30psi and causes a large trickle. Do I have air in my pipes? I just performed my winter service (Oct) during which I changed the air vent as well as the pressure relief valve. Can you help? Thanks JohnG
  • 359 Answers
Sounds like the expansion tank does not have enough air for exp in system ,shut off the boiler let cool for 2 hours , drain at least 1 gal of water out of expansion tank ,careful don't get burned ,then open cold water inlet valve , let system take all it will ,should be able to hear quit hissing when filled , let warm again and bleed the rad as close to the end of line as possible , bleed until you sure no more air , if this does not fix repeat process . should take care of problem, only cause 2 little air ,too much air ,circulator pump
Posted on Dec 09, 2008
Alpha cd28c boiler loosing water and pressure through pr valve when heating is on,and when then switched off needs repressuring to use heating obvious pr valve been fitted.pressure
I assume losing pressure through the PR means Pressure Relief Valve (PRV) or temperature pressure (TPR). Open in TPR may mean boiler is overheating/overpressurized. Open in PRV means the Pressure Reducer/Fill Valve in the fill line of the boiler is broken.
House Water Pressure in a home is 30/40 PSI min to 60-80+PSI max.
Boiler PRV/TPR are set at 30 PSI open (SYSTEM PRESSURE) so too high a house water pressure will open the PRV/TPR. Replace the reduction regulator on/in the fill valve assembly
Oct 20, 2014 | Water Heaters
Valve Pressure Reducing or Pressure Reducing Valve
dfef4ee.jpgThe pressure reducing valve on a boiler is the way that the water pressure in the boiler is controlled. The standard pressure for many hot water boilers is considered to be 12 PSI. To keep the boiler pressure at or near the 12 PSI mark a small valve is used for pressure reducing. Most domestic water systems run between 20 and 60 PSI, so the pressure must be reduced for the boiler.
This pressure reducing valve is installed in the pipe that goes from the domestic cold water to somewhere in the piping on the heating system, usually at or near the expansion tank. The valve is mostly maintenance free but will create some problems at times. Some of the things that can go wrong are:
  1. The valve seat can get dirt stuck under it causing water to leak by and increase the pressure in the boiler, causing the relief valve to release water periodically.
  2. The valve can become plugged with dirt causing the boiler to not have enough water pressure, which will cause circulation problems with the boiler pumps.
  3. The valve can leak causing a mess around the boiler area.
Replacement of the pressure reducing valve is not difficult if the installer strategically placed manual valves so that the reducing valve can be isolated from the rest of the system for replacement.
If the water pressure reducing valve fails in any way, it is usually best to just replace the whole valve rather than trying to repair or fix it. I have tried a number of times with only temporary results. These valves are not a high dollar item and the time it takes to fix them is not worth it.
on Dec 23, 2009 | Heating & Cooling
My boiler has a squeeling sound during the warmu up. I think it is coming from the expansion tank?
The squealing sound generally comes from a circulator pump, if it has a drive coupling between motor and impeller housing there is an oil cup/or oil hole, add oil until it is full! If it is a cartridge style circulator you may have to replace it.
Sometimes air in a system will cause this squeal noise as well. Purging the air out of system may be required. If you need to know how to purge a system there is a good pdf file at this link for $8.95 The Basics of Purging Air
From your Forced Hot Water System
Troubleshooting A Leaking Boiler
Relief Valve
Miller Furnace Books Repair
The Expansion tank is factory set to 12 psi and the only way to tell if it remains with 12 psi is to drop the system pressure to zero and check the tank with a pressure gauge. If water comes out the air valvestem when you apply the pressure gauge, the tank is bad, replace it! If there is less then 12 psi on the tank add air to 12 psi and open water valves back up to normal operating pressure. Usually the feed valve will automatically stop at the preset setting.If the boiler is leaking water out any relieve valve drains, the feed valve, relief valve and or expansion tank may need to be replaced.
Oct 09, 2014 | Amtrol EX-30 Diaphragm Expansion Tank...
What is the normal PSI of the operating system?
As with any hot water or heating appliance, a hot water boiler system requires a constant pressure flow to maintain the optimum temperature. Hot water boiler systems are equipped with a pressure gauge and an automatic pressure reducing valve that will add water to the system if the pressure drops. Despite the pressure reducing valve, owners should be familiar with the standard PSI of their hot water boiler system and should check the pressure reading regularly.
OBD Tools 365 Days Shop
Sep 29, 2014 | Cars & Trucks
When boiler heats water the pressure increases to the point that the pressure relief valve( 30 psi) releases water from the system.What causes the pressure to increase? The system includes an expansion...
You did not mention what pressure the boiler displays when not on. It should be between 12 and 15 psi. You could have a bad feed valve, bad expantion tank (tap lower 1/2 to see if hollow).
Mar 15, 2011 | Heating & Cooling
Loss of pressure in boiler, no obvious leaks, water pressure switch changed plus pressure release valve
Check that your make up water is on.
Make sure your fill valve is working but it sounds like it is not. Your min pressure should be 15 psig. on the boiler. Fill valve will maintain a15 psig on the boiler. Water and pressure does get out of the boiler when radiators are bleed. When fill valve is not working people will keep bleeding the radiators trying to get heat but only lowering the boiler pressure with no water make up.
Make sure your boiler is getting water and has pressure when running.
If it isn't...SHUT DOWN and have a professional look at it.
Pressure relief valve is factory set ta 30 psig and opens when pressure is above 30 psig. This is a safety valve.
Feb 17, 2011 | Heating & Cooling
No hot rads down stairs boiler comes on 3 miniutes then of again
By your post im guessing you have a 2 story house.
Have a look at the boiler,water pressure guage.Should be between 12 and 15 psi 140 to180.f when running.
If its above or close to 30 psi the relief valve will open to let off the pressure,we do not want this to happen normally.
If you have high water pressure at the boiler you will need to go to the highest radiator or any one on the second floor and open the bleeder.Looks like this
Carefully open it slow into a bucket,let air out until you get a steady stream of water.Do this to all of the radiators,idealy using a bleeder key or needle nose pliers.This may take some time.
Once we can assume all the air is out,check your water pressure again should be 15 to 20 psi.If you have no pressure then your auto fill valve is bad.If you have 15 to 20 then proceed.
Raise the temp of the t stat to start the boiler.6 degrees above whatever the room temp is.
If you still are having problems your t stat may be faulty.If your boiler is at 15 to 20 psi 140 to 180.f and it still shuts down after 3 min your return pump may be bad.
Hope this is helpfull
Dec 21, 2010 | Heating & Cooling
Boiler leak
Hi, it appears you have a defected relief valve. you can try one solution. lift the handle on the relief valve and let some water out. sometimes that can flush out materials thats blocking the stem in the valve. if it's still leaking it must be replace.
If this doesn’t work for you please write back. Thanks,
Nov 23, 2008 | Watts 3/4 Pressure Relief Valve
Hydronic Boiler relief valve problem?
Check the pressure guage. Typically the pressure in a water boiler should not be more than 20 psi. If you are approaching 30, the relief valve is doing it's job. I would replace or adjust the automatic water feed if the pressure is high. Always replace the boiler relief valve. Tap on the expansion tank, it should sound hollow. Replace it if it is full of water. If you have one of the old expansion tank that has no bladder in it, drain it.
Dec 03, 2007 | Heating & Cooling
Plumbing Logo
224 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
