Question about Panasonic SC-HT690 System
Hi. I have a SB-WA840 Sub hoover box with speaker set. Do u have a wiring diagram to connect RCA plugs for stereo to the input connector at the back as it also supplies power to the DVD player. I only want to connect RCA's for stereo sound through all the speakers and sub Can u please help me ?
  • Anonymous Dec 12, 2008
    I'm also looking for the plug that gives RCA out put.
3 Suggested Answers
SOURCE: Panasonic Sub Woofer
I Have the sub woofer SB wa 340, but I need the remote control if posible bussines send me the information 7862873227
Posted on Aug 03, 2010
  • 5 Answers
SOURCE: Can i connect sub wooferSB-wa840 dirrect to panason TH-42P67A TV
could you clarify the question.
Posted on Jan 21, 2010
I have my Vizio hooked up to my computer. I have a sub-woofer and speakers. How do I get the speakers to work w/tv mode. They work when I am using computer mode. I have comcast cable and box.
Good day sir, Hi, you see, the TV produces its own sound, you need to feed this sound to your PC. here are options were you need to choose.
  1. You need a separate sub/speaker system for your TV. feed the sub/speaker with the sound line out from the TV. you also need an RCA to stereo baby plug adaptor for your sub/speaker.
  2. If you want to use your PC speakers, feed the line out of the TV sound to the line in of the PC, usually the line in is the blue port, you need an RCA to stereo baby plug. then activate the line in function from the mixer volume properties. This requires that you turn on your PC when in TV mode.
  3. Simply disconnect the sub/speaker baby plud input from the PC and connect it to the line out of your TV using an RCA to baby jack adaptor. (re connect again if you want it on your PC. this is very complicated)
  4. Does your sub has extra input? like aux, or cd, or tuner? feed the TV line out to one of these extra port. use the input selector switch from TV and PC. you need an RCA to stereo baby plug connector.
I forgot to ask, Does your TV has line out? if no, you are stuck with the built-in speakers.
Dec 16, 2009 | Vizio L37 Television
Connect stereo amplifier to powered sub
You can y out from the main out to the sub.This output is post volume control. set level on sub to desired balance of lows feq to highs
Nov 20, 2009 | Yamaha YST-SW015 Subwoofer
Hi i have fusion sub woofer can u help me to install just let me know how to install many wires so dotn know who to install in my car
  1. Batt + or B+ or Positive.
    This is the connection directly to your automobiles battery. It should be a fused connection rated to about 15% higher than the fuse installed in your amplifier.
  2. Negative or '-' or Ground.
    This wire should be just as thick as the 'Batt + or B+ or Positive' wire. This wire can attach to any solid clean metal connation in the vehicle. Usually a trunk latch.
  3. Remote or amp startup wire.
    This wire is a thin 12V wire that will come from the deck. It's a signal wire that tells the amplifier to turn on.
  4. Inputs
    Low level inputs are in the form of RCA connectors and will require that your deck or head unit has low level or RCA outputs. High-level inputs are used for stereos that don't have low level or RCA outputs. They work by taking an audio signal directly from the vehicles speakers and then amplifying it as necessary.
  5. Speaker connection.
    Match the + and - these with the appropriate connectors on the speaker box. Red means + and Black means -.
    I hope this helps.
Jul 06, 2009 | Fusion FEW12PK Car Subwoofer
Dayton sub-100 connection
You have it upon one of several truly odd "standards" in the AV industry but the answer is simple if not quite logical. You will use an RCA type cable from the Sub out or LFE on the receiver to just one of the two inputs on the subwoofer. I usually use the one on the right but it really doesn't matter. The other connectors would be for a system with out a sub out where the speaker wire would be run first to the subwoofer and then out to the speakers. This will not be used at all in your case.
Enjy!
Feb 27, 2009 | Bose 151SE Main / Stereo Speaker
Need a hookup diagram for yamaha rx-v461 plus yamaha yst-sw216 please
Here you can find the manual for your subwoofer. Looking at its back side, it has 2 RCA plug input for stereo. Receiver has just mono sub output, but as low frequencies are not easily locatable, mono is perfectly OK.
Just connect receiver SUB-OUTPUT with RCA cable to your subwoofer's RCA LEFT input. Then adjust volume to match rest of your speakers.
Feb 21, 2009 | Yamaha RX-V461 AV Receiver
How to connect unpowered subwoofer to receiver with RCA sub out?
In order for this to work, you will need an external amplifier. Your receiver is set up to use a "powered" sub. With only speaker connections on the sub, it is a "passive" sub requiring a separate amp.
Dan
Dec 16, 2008 | Yamaha YST-MSW10 Computer Speakers
Connect powered subwoofer
  • If your receiver has a dedicated subwoofer line level output, we recommend connecting your subwoofer to this jack. Most receivers will have just one (mono) subwoofer output, while quite a few subs require two inputs. You can use an RCA "Y" adapter cord , which is a cable with one female RCA jack at one end, and two male RCA plugs at the other. Some receivers require menu settings (such as "sub-on" or "front speakers-small") that must be made before the sub output will be active.
  • Nov 22, 2008 | Audio Players & Recorders
    Subwoofer.......
    Please check your model number, I can not find it on the JVC service website.
    This is a powered sub-woofer I think. You need to have a thick black cord that connects the sub to the head unit. Then the satellite speakers get connected to the speaker jacks on the sub-woofer box. The sub-woofer should also be plugged into an A/C outlet on the wall.
    The speaker outputs are labeled right there where you connect the speaker wires. You should see a red and black connector for each speaker and they are labeled "front right" "front left" "center" "rear right" "rear left".
    If you do not have the thick black cord you need to connect the head unit with the sub-woofer, you can not use this system.
    If you look at the head unit and give me the model number on it, I may be able to find the part you need. But I must have a good model number to work with, preferably from the head unit.
    Dave
    Nov 10, 2008 | JVC SPPWA670 Subwoofer
    Subwoofer connection
    if this is ao powered sub, that plugs into the wall, there should be no problems, if it is powered solely by the reciever it may work fine but be sure you dont exceed amperage on the subwoofer.
    Jan 28, 2008 | Bose 151SE Main / Stereo Speaker
    OEM gm stereo
    If your amplifier has what they call High level inputs (basically inputs on the amp that you run the speaker wires from your radio into), you can splice wires from where the connectors are on your rear speaker(s), still leaving the speaker hooked up, and use those as an input into the amp. If your amplifier does not have high level inputs, a convertor is available to turn an audio signal from your radio output speaker wires ( spliced in just as above, leaving the speaker hooked up), into an rca output jack. Or the best thing to do would be to buy another say 2-4 channel amp w/high level inputs and rca inputs and outputs, and run your rear speaker wires into the amp. Then you'll be able to run the rca cables out of that amp and into the sub amp, and you'll have the new amp to power your rear speakers or rears and fronts. That would be ideal. But, A convertor is your best bet. Got em at best buy, circuit city, etc. Hope this was helpful.
    Nov 25, 2007 | Car Audio & Video
    Panasonic SC-HT690 System Logo
    169 people viewed this question
    Top Panasonic Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
