Question about SanDisk Sansa m230 MP3 Player
Sansa m230 Help Please!!!!!!!!!!!
I was dropping songs in my mp3 folder and i had just downloaded a large file which was an entire cd which i have never done before. Then as i pulled out my mp3 cord it said please wait while rebuilding folder it took a lot longer than usual but its obvious it was the the large file that contained an entire cd so i pulled the battery out because i thought something was wrong and know every time i insert my mp3 2 the usb port it says intializing on the mp3 and the computer doesnt recognize it
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 26, 2008
SOURCE:
How can I put music on Sansa MP3 player from Macbook Pro?
Not to sure about a mac but I think mac's use a mp4 format when it rips a cd, and the Sansa will use a mp3 file. You can download a free program to convert these files but again, I know where for a PC but not a mac. Look for free mp4 to mp3 converter program for Mac..
Jan 28, 2010 | SanDisk Sansa m230 MP3 Player
Sansa m230 not syncing music files or downloading them. Process leaves the Sansa m230 with 0 files and i am finding it impossible to load new file(s) ?
Try reflashing the firmware for your device you can find the latest firmware and flashing utilities from the manufacturer?s website. Make sure that you back your music up first because when you do this you are setting it back to factory settings. Then add music this way and see if it is works: 1. Free a USB port on your desktop computer. Now, grab the USB cable for your SanDisk Sansa MP3 player and connect the player to your computer. 2. Wait for your computer to find and recognize the player. This may take a few moments. Once you receive a confirmation message, open your computer and scan the icons for the SanDisk MP3 player. 3. Open the SanDisk Sansa MP3 player on your computer. The music files that you currently have saved to the player?s memory are displayed. 4. Open a folder containing music files that is stored in your desktop computer?s memory. Scan the files for songs that you want to transfer to the SanDisk Sansa MP3 player. 5. Left-click on a song file and drag to the SanDisk Sansa window. Drop the file and let your computer complete the transfer. The transferred file appears at the bottom of your music list. 6. Unplug your SanDisk Sansa player from your computer. Turn the player on and allow the file transfer to update to the internal memory of the MP3 player.
Oct 01, 2009 | SanDisk Sansa m230 MP3 Player
Sansa m230
When connected to your computer, go to your My Computer folder, and right click on your Mp3 player. You should see "Format Device". This wipes the entire thing. All music will be gone, but it might reset it.
Jun 02, 2009 | SanDisk Sansa m230 MP3 Player
Sansa mp3 player m230...
have you tried opening the files in a music player? it sounds like you are just accessing the file folders. try opening it with windows media player or something like that.
Aug 27, 2008 | SanDisk Sansa m230 MP3 Player
Songs appear but don't play
I'm pretty sure m230 is supposed to play WMA files, but I don't use that format. Drop a MP3 file in the Audible folder and make sure it plays. xlthim.
Jul 21, 2008 | SanDisk Sansa m230 MP3 Player
Sreeki
As long as the USB setting is set to MSC, you should be able to drag and drop songs into the Audible folder without using a disk. xlthim.
Jul 17, 2008 | SanDisk Sansa m230 MP3 Player
Cannot see m230 songs from My Computer
Check your WMP configuration, so that it will display Mp3 files
Oct 16, 2007 | SanDisk Sansa m230 MP3 Player
How do you download songs??
Read the manual
Use the install CD that came with it
Oct 11, 2007 | SanDisk Sansa m230 MP3 Player
Sandisc m230
I dont usually mess around with real player when you dl or put your music on your computer put a shared folder in there and put all your music in there and then when you connect your mp3 player go to your shared folder and right click on the song when it comes up go to send to and it will give you a list it will say what ever you mp3 player is named and if you click that it will put your music on your mp3 player and if you couyld upgrade to at least a widows xp ~Grim
Apr 17, 2007 | SanDisk Sansa m230 MP3 Player
SanDisk Sansa m230 MP3 Player Logo
245 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Gyula Lacz
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
