Question about Kenmore 72982 Gas Dryer
Kenmore gas dryer 97273100 was drying, but making a loud noise
Took the back off the dryer as it has been making a loud squealing noise like a car fan belt then dry stopped working. When you hit the on button it makes a noise but the wheel blower will no longer turn.
    President:
  • 2,992 Answers
You need a belt. Here's a link to a site with a good set of instructions if you want to try repairing it yourself. (You should DIY. You can save a bunch on the service call and the belt is only about $20.)
http://repair2000.com/wpoolbelt.htm
Posted on Dec 08, 2008
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
I have a Kenmore Residential Dryer Model # 97273100 (11097273100?). The dryer starts but does not spin. I assume it is the belt, but how do I access it?
I smell gas and can't find where the door panel is on my Kenmore You : Model:97273100 serial: MB3313988
Jan 16, 2011 | Dryers
Loud noise as the tumbler is drying
Front or rear? Rear is probably center bearing. Fornt is front tub wheel or glide worn out. If noise is in front remove front and inspect.
Jul 19, 2010 | Maytag Atlantis MDG7400AW Gas Dryer
Hoover Maxi 6 TC50 Tumble Dryer making squealing noise
Have you fixed this problem? I also have a Hoover condenser dryer, only a few months old, and has started to make a squeal/whistle. I'm thinking it might be the front fan needing some WD40, OR too much water vapour around the belt that moves the drum causing the sounds.
If it's the fan, lubricating the shaft and its components should fix the problem, if a wet fan then I'd think maybe fully cleaning the condenser filter, reservoir ect will fix the problem.
The problem seems to go away though "mostly" 15 or so minutes after you start the dryer, so that makes me think ones it gets warm something is expanding to allow more "give" so maybe the belt.
Aug 26, 2009 | Hoover Dryers
Maytag gas dryer squealing
Hi, this is a belt issue. make sure the tension on the belt/motor is sufficient. adjust to specs. if the belt is fine, this will be bad bearings in the roller assembly.
Replace the rollers in this case.
May 21, 2009 | Maytag Dryers
Loud Noise While Drying
Your rear drum bearing is dried up and need to be re-gresed with high temp grease
Jan 05, 2009 | Kenmore 60172 Electric Commercial Dryer
We have an electric Kenmore 70 series dryer that is making very loud noises - still drying well otherwise. Husband just took off front and top, and took out drum - still makes same noise when just motor is...
check yopur blower wheel and blower wheel housing...turn with hand to check motor bearing,,if motor bearing tell husband a little bit of wd 40,,or white grease at each end
Dec 28, 2008 | Kenmore 63942 Dryer
No heat in kenmore 97273100 72731 front load gas cloths dryer
check the ignitor under the door panel on the left side of the burner if it gets red when you turn the dryer on.if yes than see if gas shoots out and yes than how long it stays on if in few minutes it turns off than need thermal fuse checked so let me know up to this point if it works or not .
Nov 02, 2008 | Kenmore 73952 Gas Dryer
Dryer
Today my whirlpool dryer started making a loud noise. it is drying the clothes but the noise is loud.
Jul 06, 2008 | Kenmore Dryers
Kenmore 72982 Gas Dryer Logo
319 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
