Question about Sony KP-53HS30 53" Rear Projection HDTV-Ready Television
Sony KP53HS30 standby & stereo lights on no picture or sound. The only way to turn it off is by pulling the plug. It started a couple of days ago when it took about an hour or more to have a clear picture but yesterday I lost picture while watching TV. Today I lost both sound and picture.
  • hector97 Dec 11, 2008
    I tried the solution given but I still have the same problem.
  • 75 Answers
May be there will be problem in power supply section in your tv...which also leads to damage the other parts like picture and sound...so check the power supply section in your tv...
Posted on Dec 11, 2008
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, pls determine the error codes. This would refer to the number and sequence the blink. The interpretation of the codes maybe found here.
Depending on the code and the area/component it may refer to, the unit has to be opened up for a look and see.This of course would require opening the unit, perform voltage measurements,determine faulty component and subsequent part(s) replacment. further, a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron would be required. It would be to your added advantage access to a service manual (Sony Chassis RA6) or at the very least a schematic diagram with voltage readings.Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Good luck and Thank you for using FixYa. Happy Holidays.
  • Louie  Role
    Louie Role Dec 12, 2008
    Hi again,
    Any updates or developments so far?
  • 3,037 Answers
What color is the stand by light when you try to turn it on? Is it blinking? If so, how many times, should be a pattern. Also, If I were to have you attempt to have you check certain components, what are your electronic skills like? If you don't know what is dangerous or not in this tv, then you should not attempt to repair it and should have a local shop take it. Please answer the above questions and I will post back further information
  • 10,594 Answers
Let me know do you want to repair it at own and have service manual?
I can guide you in this.
    Master:
  • 416 Answers
What about self-test system. How many red blinks you have in stand by mode. If its seven its board or power supply. High voltage shutdown. Check power supply
If its six ---no horizontal (H STOP), no raster, goes to the blinking selfdiagnosis function immediately.
Good Luck
    Master:
  • 479 Answers
There is a short tracking on the main board which needs to be repaired.every time it tracks short it creates a problem there by damaging the device more n more.the main board needs to be repaired by a qualified technician to solve this problem.dont try things that can spoil ur device further.
  • 734 Answers
First, try the unplug AC; wait 5 minutes; plug back in; try again method. Obviously, if the service menu comes back up when entered, then use Gregg's method. Also try connecting devices to the various inputs including the "Component" inputs (Red, Blue, Green). A DVD player might have these or as a last resort connect a yellow (composite) cable to the Green connector.
Second [Danger mode]: turn set off; enter code to go into service menu (TV should turn on with no picture); press "8" then "enter" [/Danger Mode] This resets TV to last saved mode. Probably won't work but worth trying.
Third [Danger Will Robinson Mode] Same as the above but with "7" instead of "8" [/Danger Will Robinson Mode]. The manual says to Never do this because it puts the set back into pre factory setup and it will really mess things up, possibly beyond recovery. You would want to be armed with Every possible data value written down. You would probably need to visit the AVS forum thread on "Sony Service Codes" because many, if not, most of the settings are undocumented by the Factory in the service manual.
An absolute last ditch method does require a servicer to install new eeproms (hopefully from a working circuit board) to get the TV into a visible position to allow completion of setup
Posted on Dec 08, 2008
  • Sony Master
  • 6,487 Answers
Try first to reset the unit for about 6 hours being unplug from the power outlet and after that plug it back in and check if you still have the same problem,...
Sony kv36hs500 tv, suddenly no power, no standby lights, no sound
U check the power source?Take the tv aparts,check or replaced the power fuse,might get lucky.Not,than sorry,this tv can't be repair,without replacing electronic's componnents parts.Hire the same shop to do the repair.Ur tv power ICS inverter are dead.
Jun 15, 2010 | Sony FD Trinitron WEGA KV-36HS500 36" TV
No picture or sound, flashing standby light, will not turn on
sounds like powwersupply issue. repair is usually reasonable from reputable repair shop. id say around 150 - 250
Jun 02, 2009 | Sony FD Trinitron WEGA KV-36HS500 36" TV
STANDBY LIGHT KEEPS BLINKING BUT NO PICTURE OR SOUND
just try unplugging it for a little bit and see how that works.
Feb 01, 2009 | Sony FD Trinitron KD-34XBR960 34" TV
Sony KP53HS30 Stuck in Sleep Stand by
I don't believe it is stuck in the sleep standby mode, rather it has shutdown with an error. Is there a pattern to the flashing? Does it flash a set number of times?
Oct 19, 2008 | Sony KP-53HS30 53" Rear Projection...
Standby/stereo light blinking no picture or sound
My picture would go out after several minutes but I still had sound. I took the rear cover off and blew all the dust off with compresed air.I did this for a few times over several days nothing happened.I also took off the rear circuit board that attaches to the tube with a round pin socket and blew that with compressed air and put it back on. The TV has now worked for two days without the picture going out. It worked!!!!!!!!!!!!!! My TV is 9 years old.
Aug 31, 2008 | Sony KV-36FS100 36" TV
Sony Wega kv27FV310 standby flashes 2 times with no picture or sound
3 years ago, i had the same problem with a samsung 36", when i switched it on it would stay on for around half an hour, i tried to switch on straight away, but it wouldnt, i had to leave it for an hour or so, then it would stay on for about 5 minutes. And the same thing the next day (half an hour then 5 minutes). I left it into the repair shop, it had to get a circuit board replaced at a cost of £315, dont know how much it will cost to get fixed now, as i could buy the same tv for a little over that now.
Apr 14, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
standby button blinks no picture no sound have tried to reset and restart nothing has worked to get tv to back on
Mar 15, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony 57 inch WEGA Projection TV
Hi, this is a very common failure, you need to replace 2 IC chips on your power supply board, marked on the top of the IC`s is this number: MCZ3001D you can purchase them here if you are very proficient at soldering & un-soldering, and the board has to come out of the tv to do this, you might want to call a tv man for this one, but it will fix your set, happy holidays, BMW Rider
Nov 29, 2007 | Sony Grand WEGA KDP-57XBR2 57" Rear...
Sound, but no picture. Standby light blinking 5 times
A few weeks ago my set started flashing to a black screen. Now a couple of weeks later, i have no picture, but the set turns on and i have sound. The standby light is flashing. I purchased the set in 2000 so it is seven years old. This is the first problem. Could it be all three of the bulbs? Could it be all three of the bulbs? no as you say that sound is ok that means your power supply &high voltage section is ok. please check chroma ic luminance section or system control section stand by ckt ihanks
Sep 11, 2007 | Sony KP-53HS10 TV
Sony KP-53HS30 53" Rear Projection HDTV-Ready Television Logo
23 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
