Question about Neff U1421 Double circotherm Electric Oven
Replacement bulb I need to replace the bulb in the main oven of my U1421NOGB/06 (neff double oven buit in cooker). Which bulb do I need? I do not have the manual to hand. Thanks
  • Neff Master
  • 3,463 Answers
There are more than one type of bulb for these ovens, the most important thing is that you get one that is rated to withstand temperature of 300oC, or they will shatter with the heat.
Plz rate my solution.
Posted on Jan 15, 2009
Neff double oven u1442, main oven thermostat light does not work even though oven heats up. Is there a fix?
If the oven is heating up o/k, then I would suggest that the oven pilot bulb has failed, I have come across this on several occasions, it usually just means replacing the oven pilot light.
Mar 18, 2011 | Neff U1452 Double circotherm plus Electric...
We have a hotpoint cooker UY46, our electric tripped the cooker off and , now the nob and grill works but the bottem/main oven is turning on and the fan is circulating but not getting hot ? please help ;(
You need to replace the element. Very easy job remove the back plate from inside the oven (4 screws) and you will see a circular element held in place by one screw in the centre of the fixing plate. Remove the fixing screw then remove two wires and refit new element job done.
Regards Neville
Jul 16, 2009 | Neff U1721 Double circotherm Electric Oven
Apart from the main supply to the cooker terminals
So long as the earth is connected to the earth terminal, then there is no prob for you to worry about.
The normal twin and earth cable is adequate.
Please rate my comments.
Mar 05, 2009 | Neff U1661 Double circotherm super...
Neff cooker not heating up
Hi, it feels like your oven element has gone.
switch it off from the mains, open the door and remove the screws fixing the back panel. You will find a round two turn element. Unscrew the element fixings and check the element for burnt marks, corrosion. If you have a multi meter, turn it to buzzer and use the meter leads to test the element connections. If it doesn't buzz, it's dead. Just needs replacing.
Feb 15, 2009 | Neff U1721 Double circotherm Electric Oven
Fitting neff double oven cooker purchased from display at mfi
Go to this site here.
You need to register the oven under My Apliance to get the manual
Good Luck
Please rate FixYa!
Dec 19, 2008 | Neff U1721 Double circotherm Electric Oven
Trying to replace main oven bulb: cover jammed
Try heating it up with a hair dryer or similar if that does not work then you will probably have to break the glass cover.
Nov 17, 2008 | Neff U1461 Double circotherm plus Electric...
Neff cooker model b1422nogb bulb replace
Unscrew glass cover anti-clockise, likewise unscrew bulb, and replace.
Apr 28, 2008 | Neff B1421 Electric Single Oven
Change Bulbs in Neff U1661 Oven
You don't need to slide the oven out, just remove the glass covers with a flat bladed screwdriver and then unscrew the old bulbs. Replacement is the opposite.
Bulbs available from Homebase, Wickes, BandQ etc etc.
Apr 27, 2008 | Neff U1661 Double circotherm super...
Duco4ss main oven not heating on fan setting
put test bulb on the two wires going to fan heating element,that will tell all,if bulb lights,its the fan element that needs to be replaced!good luck!!
Dec 17, 2007 | Ovens
Neff U1421 Double circotherm Electric Oven Logo
258 people viewed this question
Top Neff Ovens Experts
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Neff Oven Expert? Answer questions, earn points and help others
