Question about One For All URC-3021 Remote Control
I need a code to enable my tv box to pick up all sky channels-
    Problem Solver:
  • 3 Answers
Hi need Tv Name brand
Posted on Dec 08, 2008
Proline LVD TV and DVD player problem. Hi, I can't get a picture using the RF option. I'm not sure what input I should select for this but I've tried them all and no joy in seeing the sky picture from the...
Hi Greg, i think your missing something simple.
Pick a channel number you want the Sky on, then in the tv set up
manually tune that channel to 68, or if it's showing lots of numbers for the frequency then just search towards the end and it should pick up. On the Sky box leave a menu showing so it's easier to spot when it gets to picking it up.
Nov 10, 2014 | Televison & Video
Hi, what is the sky remote code for Toshiba TV model 32BV500B? Thanks.
I've found two codes that work fine on a revision 8 Sky remote control and a revision 8r remote:
0056 (LG/Goldstar)
981 (General reset)
Both codes enable volume, channel selection and power on/off.
Nov 11, 2010 | Toshiba Televison & Video
We have loads of codes for sky remote control. Do you know which code will enable us to switch the tv off and do the sound control. At present we have to use two controls. TV remote to switch on and...
OK,
This really depends on which brand/model of TV you have and which Sky remote version. The code you need is specific to the brand/model of TV.
The Sky remote version is printed on a sticker inside the battery compartment. The older Sky remotes will have "RC1600/00" on the sticker. Newer versions will also have either "Rev 4", "Rev 6", or "Rev 8" on the sticker.
If you have a new TV and an older Sky remote (i.e. before Rev 8) your remote may not work with your TV and you will need to buy a new Sky remote if you want to operate TV and Sky box with one remote.
Please post back with your Sky remote version number and your TV brand and EXACT model number. I will then be able to provide codes for your remote and programming instructions.
Thanks.
Nov 03, 2010 | Televison & Video
Good evening i have just purchased the Samsung
you have to use an antenna or cable feed to your tv to enable to watch tv on tv mode.
Jun 10, 2010 | Televison & Video
Panasonic TX P50V10B Plasma TV
In order to get any of the Freesat channels, you need to connect a Satellite dish to your TV. If you have a Sky dish, you simply need to run an extra Cable from the LNB from the dish and connect to your socket on the back of your TV.
In order to get Freeview channels and Analogue channels, you need to connect a aerial to the back of the TV.
There is a menu option for the TV to start straight to the AV input (your Sky HD box). It is Menu > Setup > Other Settings > Power on Preference. Select 'AV' for your TV to start on Sky HD.
Also even if you have your TV to start on TV, when you turn on your Sky HD box, it should automatically switch to the Sky box.
Oct 28, 2009 | Panasonic Televison & Video
Tuning to pick up sky feed
Sounds like from discription the sky feed is set up for analog channel 6. With my TV-HVR-1600 card, there is an option in the wintv application when you click the menu button in the application that says channel suite. If you select this option, you should find and option for analog source. Select analog source in this screen and you should be able to manually add channel 6 in the box at the top of the analog souce screen. Also if you have the sky feed connected and you you click the scan button on this screen, it should detect automatically is the sky feed is on.
Aug 20, 2008 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
Probem getting sky to work with a new TV
An HD TV connects in the same way as a standard TV.
Connect a scart lead from the TV scart of the Sky box to the TV.
When you switch on the Sky box it should automatically switch the TV to the correct external input.
May 19, 2008 | Televison & Video
One For All URC-3021 Remote Control Logo
27 people viewed this question
Top One For All Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
