Question about GPX PD708B Portable DVD Player
No audio Why does my DVD player have a great picture but no audio?
  • Anonymous Mar 03, 2009
    SAME HERE,,,,,, NO SOUND
  • 4 Answers
On mine I can plug a set of computer speakers into the a/v out port and have sound you can also plug in some earbuds for portability but cannot adjust the volume, it is at a comfortable listening level though. be sure to use the a/v out and not the earphone jacks.
Posted on Mar 30, 2009
C14 was leak and resistor R2 burn out, I replace C14 with 0.1 uF and R2 with a chip fuse, sound after that was great at the speakers.
A.S.
Posted on May 30, 2009
    President:
  • 2,992 Answers
Looks like several people have this problem. I downloaded a copy of the manual to see if it had any hidden secrets, but no luck (I don't have one of these).
This thing has a couple of modes (DVD or A/V input) that you switch between by pressing and holding the STOP/DVD/AV button in until it switches. Try switching the mode a couple of times. Maybe the thing is expecting external audio.
Other than that there doesn't seem to be any cause other than a defective unit. These things are made in such quantity and at such low cost that there will always be duds. If they are still within the return period where you bought them, then take them back for exchange and test them at the store. If you can't do that, contact GPX at the phone number or website about replacing it.
(I personally don't buy GPX for the simple reason that their stuff has problems sometimes. I went through 3 CD boomboxes once and swore never again for this brand.)
Posted on Dec 08, 2008
There is no sound on my Sony SLV-D350P DVD Player / VCR Combo. The only section that works great is the VCR, but the DVD player sound just went out for some reason. I've changed the RCA cables, and...
Hi, As long as you have the picture it means that DVD's Laser Eye is Ok.. Pls Check your connections to make sure the audio and video cables of both VCR and DVD are properly hooked up to the television. Color coded cables should be matched with the jacks of equal color. Yellow corresponds to video while red and white are both audio.
Ensure the DVD is in standby mode if you are not getting picture from the VCR. The DVD cannot be running at the same time as the VCR is playing when you want to see the VCR picture.
Connections with combo units are often inconvenient, forcing you to use separate video hookups for each section (DVD, VCR), a problem for older TVs. This player has it figured out: a single RF or composite-video connection to a television will display either the DVD or the VCR signal, depending on which format you're viewing. If you want to view DVDs in S-video or in component-video (either interlaced or progressive-scan), you will need to use two inputs. though: any component- or S-video-equipped TV will offer sufficient inputs for both of the SLV-D350P's formats.
It's a different arrangement for audio: you can listen through a single set of stereo analog-audio cables for each component or--if you want to enjoy DVDs in discrete 5.1-channel surround sound--you can send the DVD's audio to a compatible audio/video receiver and a multichannel speaker system through a digital-audio interconnect (either optical or coaxial,). The unit also comes with an RF cable that will transmit DVD/VHS audio and video to your TV.
In conclusion,for a best tech solution I prpose you to connect DVD audio directly to your Stereo and listen as separate audio source.while Video goes to TV as usual. Hope this helps! if you need more help pls contact me..Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
Jul 02, 2011 | Sony SLV-D350P DVD Player/VCR
Only audio works. No video. Worked fine last time. Tried new cables. Tried video 1 and 2 inputs to tv, still sounds great but no picture. T.V has no problem with video camera in either...
if the camera works, and you tried new cables.. it sounds like the problem is in your dvd player. make sure you have the video cable plugged into the correct slot on the dvd player.
Mar 01, 2010 | Oritron Televison & Video
Installed Directed TV DVD player in Honda Odyssey
did you plug in the atenna to the back of the head unit?
Mar 20, 2009 | Sony XAV-C1 Car DVD Player
Hook this dvd player to an hdtv
You are confused regarding how to connect your DVD player to your Samsung TV. There is no such thing as "5 composit hookups". Your DVD player most likely has right audio (commonly red), left audio (commonly white), and video (commonly yellow) outputs which should be connected to corresponding inputs on the rear of your TV.
Dec 15, 2017 | GE 5803P Multi-disc DVD Player
No audio from new dvd player/recorder
make sure all your cable connections are in the correct sockets and secure, if this dosent work check the disc/discs
Dec 21, 2008 | Televison & Video
How do you hook up a dvd player to the panasonic 10801 hd tv
the easy way is RCA cables..Plug the video out of the dvd into the video input of the t/v...then plug the audio -right & left out of the dvd into the audio input of the t/v...For a great picture use an S-video cable from the dvd to the t/v BUT thats just for the picture not the sound. you still need rca cables for sound
Dec 19, 2008 | Televison & Video
Sound on my emerson dvd player
YOU MAY HAVE HAD A CHANEL GO OUT,, OR CHECK THE MENU ,,IT COULD OF BEEN PUT ON DIGITAL INSTEAD OF ANALOG,,,,,UNLESS YOUVE HOOKED IT UP WITH COMPONENT JACKS ,,RED,GREEN ,BLUE ,,JACKS ,,IF THATS THE CASE ,,THATS FOR VIDEO ONLY,,HOOK UP SOME RCA JACKS WITH IT IN THE RED AND WHITE AUDIO JACKS,,,GOOD LUCK
Sep 04, 2008 | Emerson EWD2204 DVD Player/VCR
Hooked up dvd and vhs player good picture no sound please help
look carefully whether you jacked the audio out from DVD and audio in into the TV
> the TV is having a Audio out and in jacks
>if you jack a the audio out from DVD into Audio Out in TV you wont have audio
May 08, 2008 | NEC MultiSync LCD4010 40 in. Television
GPX PD708B Portable DVD Player Logo
562 people viewed this question
Top GPX Televison & Video Experts
Jaime Hernandez
Are you a GPX Televison and Video Expert? Answer questions, earn points and help others
