Question about Sony VAIO VGN-TXN15P/B Notebook
Ethernet port jumps off and on
When this vaio vgn-txn15p laptop is connect to a particuler network connection, the adapter gains the loses connectivity back and forth repeatedly. It does not happen on other connection, just this one. This connection worrks fine on other PCs.
  • 117 Answers
Visit support site and download latest network driver for your model.
Posted on Dec 10, 2008
Wireless problems
go in the internet [OPEN NETWORK AND SHARING SYSTEM] then go in [CHANGE ADAPTER SETTINGS] then disable the Ethernet and restart your laptop and after restarting go to same settings and enable your Ethernet. hope it works
Jul 16, 2013 | Sony VAIO VGN-N170G/T PC Notebook
Unable to connect to internet despite connection confirmed
Improve the FixYa experience for everyone by voting.
I'm going to provide you with some generic approaches in an attempt to solve your problem.
First: Microsoft will perform a complete systems check for you in three clicks with their FixIt app. CLICK HERE and Microsoft will fix (repair) any Windows related problems that might be causing your problem.
Second: It is important to connect the modem to the router before you configure the modem in order to verify communication between them. If the cabling is incorrect, the rest of the process fails.
As a rule, external modems are built with a female data communications equipment (DCE) DB-25 port for connection to a controlling device such as a PC or a router
Connecting the modem using the network cable to the wrong port of the router (other than the WAN port) is easy to identify. You can easily troubleshoot the problem. In some cases, you may correctly setup the wireless router connection but you use the wrong cable type in connecting the modem to the router. Cross type UTP cable must be used in connecting the Ethernet port of the modem to the WAN port of the router. But this is not always true. Today, many types of wireless routers (and any LAN Switches) embedded their Ethernet ports (either WAN or LAN ports) with Auto-sensing type port (auto-MDIX LAN). It means that you can use either cross-type or straight-through-type network cable for the Ethernet port connections. The system will detect the cable type and automatically adjust the ports signal accordingly.
Apr 28, 2012 | Sony Vaio VGN CR353 Laptop Universal AC...
The volume buttons on the outside of the laptop stopped working. The mute and wireless switch still work though. it is a sony vaio VGN-TXN15P
What operating system do you have on the Vaio? Check if there is some options in Control Panel - Sound menu...
Sep 19, 2011 | Sony VAIO VGN-TXN15P/B Notebook
I pruchased a Sony VAIO VGN-TXN15 Notebook from a guy on ebay who said the notebook worked well. Unfortionatly It does not connect to the internet wireless or with the eithernet cord. I took it for a...
Did you tried cable connection to your router to see if this works?
which windows its runing on?
If wireless connection drops its not all the time your laptop issue... its router transmitted channel conflict with laptop wireless card channel....
You might fix this by changing the router wireless setting by changing the transmission channel on it.and then re connect the laptop or it may auto reconnect with it and hopefully signal will not drop.
one is network card for cable connection to internet
one is wireless card for wireless connection to your router(with internet connection)
I will write more after I get your reply. As I am in the middle of my own issue now... ;)
May 08, 2011 | Sony VAIO VGN-TXN15P/B Notebook
My "sony vaio vgn txn15p"
if your Sony is older then 3 yrs I urge you to get a new battery. Make it last longer by draining the battery and charging it up everyday. This gives it a work out and helps it not get lazy.
May 02, 2011 | Sony VAIO VGN-TXN15P/W Notebook
Cannot connect laptop with the eithernet cord
If you cannot connect your laptop using an Ethernet cable, make sure the laptop's wireless ethernet is disabled. To disable it in window xp, click the Start button and open the Control Panel. Double-click Network Connections. Right-click Wireless Network Connection and select Disable from the drop-down list.
04e3ee0.png If you are using a laptop with Windows Vista, click the Start Button and type Network and Sharing into the Start Search box. Select Network and Sharing Center from the Programs list. Select Manage Network Connections from the left pane of the window. The Network Connections window will open. Click on Wireless Network Connection. Select Disable this Network Device at the top of the window.
9a7c8c6.png Troubleshoot the Network
After disabling the laptop's wireless connection, be sure to restart the computer before trying to connect with the Ethernet cable again. If you still cannot connect the laptop to the network with an Ethernet cable after rebooting, check to make sure there is not a problem with the network itself. If there are others nearby connected to the same network, such as in your office, dorm or another public location, ask them whether they are currently able to connect to the network. If no one else is using the network, contact the system administrator or your Internet service provider to see if there may be an outage. This step can save you plenty of time troubleshooting if there is an outage in your area!
Troubleshoot the Ethernet Cable
If there is no problem with the network itself, the reason that you cannot connect the laptop may be the ethernet cable. Make sure that the Ethernet Cable is securely connected to both the laptop and the wall outlet. If possible, try connecting the Ethernet cable into another wall jack or port on the router, and then try using a different Ethernet cable. The Ethernet cable you are using may be damaged.
8686681.png Troubleshoot Network Settings
If the Ethernet cable does not seem to be the reason why you cannot connect to the network, check the laptop's network settings. In Windows XP, open the Control Panel and select Network Connections. Open Local Area Connection and check the status of the connection.
In Windows Vista, go to the Network and Sharing Center and select Diagnose and Repair from the left pane and wait for the results.
If the Local Area Connection is listed as Disabled, right-click it and choose Enable.
If it says that the network adapter is unplugged and you have ruled out a problem with the Ethernet cable and port, the laptop's network adapter may have failed. Try using the same Ethernet cable on another computer. If you are able to connect to the network on another computer using the same Ethernet cord, contact the laptop's manufacturer, a computer repair technician or replace the network adapter yourself.
fc4831a.png If the Local Area Connection is listed as Disabled, right-click it and choose Enable.
Oct 28, 2009 | HP Pavilion dv6000z Notebook
Sony vaio vgn-fs630/w. the ethernet port and usb ports not workin
The best thing you can try is a Static discharge.
Please remove all the external devices. Unplug the power adaptor.Remove the battery. There should be no electricity connected.
Then press the power button and keep your finger on it for about 30 seconds to release any build up electricity.
Plug in the adaptor and battery again and see if there is still a problem.
Maybe is a good idea to get a surge protector in the future.
Regards,
Purito
Oct 17, 2009 | Sony VAIO VGN-FS630/W Notebook
I reformatted the hard drive and reinstalled Windows Xp on my Sony N-TXN15p laptop. Now my CD/DVD drive isn't being recognized. What can I do?
You will need the drivers for the drive. When you look at the devices in device manager (devmgmt.msc) do you see any drives under DVD/CD-ROM drives?
Mar 06, 2009 | Sony VAIO VGN-TXN15P/B Notebook
I don't have ethernet controller drivers to connect network
plz download the drivers from the manufacture website
Feb 04, 2009 | Sony VAIO VGN-N365E/B Notebook
Sony VAIO VGN-TXN15P/B Notebook Logo
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
