I'm trying to tripod-record a continuous several minutes without standing at the camera, but the recording automatically stops after about a minute. It's presently mounted in a car, and I'm wondering if it's the increased vibration at speed that's causing the recording to consistently stop prematurely without any other input.
Is there an auto recording shut off point that can be extended? Or if it's a vibration thing, any solution (obviously aside from adding a damper)?
Use a lower resolution. According to page 36 of the manual, you can record up to 4GB in a single clip, and 4GB will hold about 11 minutes of full HD video.
Digital cameras costs above several hundred dollars depending on the brand names and featuree functions. Brand names like sony, philips, panasonic, fuji, samsung digital cameras with features picture video, lenses, storages spaces cost above $500 least considering warantees, and peripheral compartment. Tripod stands, camera batteries, recording chips, carry cases, charger kits, costs differently depenign on the brands names, availability at retain and buyers choice of expensive devices prefered. Recorder camera chips at most affordable with least storage spaces starts at $49 dependign on the type of cameras to suit. camera tripods stands usually would cost depending of the size either as domestic or outdoor setup costs in above couple hundred dollars. $149. Cameras that perform on backup power sources with several hours least requiring recharging are couple hundred dollars and above dependign on the extensive lastings capacity of battery supply at assigments. Consult with an electronic store retailers expert to ascertain the available sale prices. For example, the types of retail stores predict the prices avilable for each device at purchase. for example, products acquired from luxurous retailers requrie guarantee, warrantee acquisition also to make the experince acheievable. Usually more expensive camera devices have more expensive warantee costs at purchase. For example, buying a camera that cost $500 as base price after store taxes of 8% sums much differently. Warrantee may usually become couple hundred, where &149 dollars for basic warantee to several hundred dollars to full extensive years of warantees arragment with either the retails store or manufacturer.
The possibility of this varies from handycam to handycam but it is most likely related to the type of disk you are using.some disks can only record one session. it is important to read the instructions that came with the disk.generally disks marked 'DVD-R' can only record one session whereas disks marked DVD-RW can record several sessions and can even be erased and recorded on again as new.
pse reply if this helps you
Luwangula
I have a sony 14E and suddenly it stopped playing and recording. With vertical lines on the screen I knew to clean the heads. No effect on the recording/playing malfunction.
However I persevered and it seems to have worked in it is now recording and playing back. The steps I suggest, with PERSEVERANCE, are :
1. Clean the heads (I did it 3 times in all, with about 1 hour between each session);
2. Leave the camera open (tape section) for about 2 hours and put the camera (with or without tape) in a warm place. (I also had condensation messages).
3. Once it is warm put in a recorded tape and attempt to view it. At first I had "dirty" vertical lines for a few seconds but it cleared and played normally.
4. If Step 3 still does not work repeat 1 and 2. As I said PERSEVERE.
If Step 3 works then try to record. It should work hopefully. If not, repeat 1 and 2 (shortening the "Warm Up" time).
Good luck. I hope mine continues to work OK now. It is to do with dirty heads and coldness I think.
One of my friends had the same problem, I told him to change the memory card with a fast one and it works.
I think it hapen when the camera buffer compilitly fulled becouse of low speed memory cards.
I hope this helps.
Hi
i would say try other cd recordable media but it sounds like your player has a tracking/laser pick-up problem or a laser mechanism fault,i would suggest you take it to the nearest repair agent to get them to look at it for you.
regards.
paul.
