Question about HEWLETT-PACKARD HP G72-B62US Notebook
Cd/dvd drive device driver missing when installing windows 7 ony my HP G72-B62US notebook
  • 23 Answers
I'll recommend you to directly try Driver Detective and let the software have a free scan to automatically detect & update the missing drivers. This way things can be much easier & efficient. Also you don't have to risk install wrong drivers which might cause severe system issues.
best regards & good luck!
Posted on Aug 25, 2012
  • 702 Answers
Normally the CD/DVD device drivers are part of the chipset drivers, since they include support for the IDE/ATA interface of the computer (to which the CD/DVD generally also connects). Same it it is a SATA controller.
In some cases additional drivers are required for non-standard interface controllers. You could try using a program to run a driver check and see if anything is missing.
Posted on Jul 06, 2012
2 Suggested Answers
SOURCE:
  • 13 Answers
SOURCE: presario cq60 missing dvd drivers
Does the Windows Installation complete and have you tried skipping when it asks for them? Also make sure your install disc hasn't got a big thumb print or scratch on it.
Posted on Jun 24, 2012
A required cd/dvd drive device driver is missing
why windows 7 when 10 is heaps better and is a free uprade to windows 10 from windows 8 just go to settings update and do it for free. i'm in the insider program for windows. as all ways install all exe's as admin then you have no problems.
Apr 21, 2016 | Computers & Internet
Base system device
Things which you should know and do before upgrade:
1. HP may demand you to reinstall back Vista if you will have any hardware problems to troubleshoot them.
2. HP will not help you if you will have any software problems because this models are not officially supported
with Windows 7.
3. Before you will upgrade to Windows 7 please make Vista Recovery CD/DVD. How to do it all informations here.
4. All Vista drivers and pre-installed software by HP for your model are in C:\swsetup folder.
If you still have it on your HDD then copy this folder to CD/DVD. You may need them someday.
5. Users with nVidia graphic card should check temperature of this device before upgrade.
This way you will know is it working ok in Windows 7 too.
How you may check your notebook CPU (processor), GPU (graphic card), motherboard or HDD temperature?
To do that use HWMonitor (free and recommended) or Aida64.
How to find out which model you've got and specifications for it:
1. Click on Support & Drivers link. (Upper part of this page.)
2. In search box type your laptop product number (p/n).
Resource:
How to Locate the Notebook p/n
3. Under notebook picture you will find your notebook model name (example: HP Pavilion dv6205eu Notebook PC).
4. On the same page click on Product Information -> Product Specifications and you will find all informations about
your notebook hardaware.
How to install Windows 7 and what you should know while upgrading:
1. Guide: How to Do a Clean Installation with Windows 7
2. All Windows 7 drivers you will find in next post below.
3. Some drivers have comment then they are originaly made for Vista system.
When normal installation will fail, then try to run unsuccessfully installed file in Compatibility Mode (Windows Vista,
Windows Vista Service Pack 1 and Windows Vista Service Pack 2).
Resources:
Make older programs run in this version of Windows
How to Run a Program in Compatibility Mode in Windows 7
Sep 11, 2017 | Toshiba Satellite Computers & Internet
I pressed f11 at startup but nothing happened
You haven't said why you pressed F11. Did you want to enter the setup? For HP computers, it is usually F10.
Nov 01, 2011 | HEWLETT-PACKARD HP G72-B62US Notebook
I have Windows 7, & can't use the DVD/CD device.I get this message: "cannot load the device driver for for this hardware. The driver may be corrupted or missing.(code39).
You have the incorrect drivers installed for the CD/DVD drive. Ensure that the drive is compatible with Windows 7 and got to the manufacturers website for the drivers written for Windows 7
Jul 27, 2011 | Computers & Internet
Dell Inspiron 1420 dvd icon missing, what had happen
Try the following *Check weather required driver for your DVD drive is installed or not(in Windows 7 it automatically installs drivers) if yes.......try this.....
*If you are using Windows operating system Go to Start>Control Panel>Hardware and Sound>Device Manager>select DVD/CD drivers>Right click on your name(Name appears after clicking arrow beside DVD/CD drivers option)Ridht click on your device name>Select enable
Thank you Don,t forget to rate
Jan 28, 2011 | Dell Inspiron 1420 Notebook
Hp 9910dv doesn't recognise dvd/cd drive What
This issue could be due to corrupt or missing CD/DVD drive drivers or corrupt registry keys. To resolve this issue, perform the following:
Remove and reseat the CD/DVD Drive of the notebook by referring the service manual provided below:
http://h10032.www1.hp.com/ctg/Manual/c01951704.pdf
Refer page no: 59 & 60.
NOTE: PDF manuals require the Adobe Acrobat Reader for viewing and printing.
If issue persists, Run Microsoft Fix it to remove drive limits. You can find Microsoft Fix it in the web link below:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00678214&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=3740565&lang=en
Further, reinstall CD/DVD drivers from Device Manager by following the steps listed below:
1. Click Start, Control Panel, Device Manager.
2. This opens Device Manager window.
3. Click "+" beside CD/DVD Device Category.
4. Right-click the listed CD/DVD/RW and select Uninstall.
5. Follow onscreen instructions to complete the uninstallation.
6. Now restart the system.
Windows will redetect the device on restart and reinstalls the drivers automatically. Now check for the issue.
May 21, 2010 | HP Pavilion DV9910US Notebook
After installing windows 7, the LG DVD drive doesn't work and windows says it cant install the driver
Many older ICH7 chipset drivers as well as generic derivers has been removed from the winodws Latest Built, for you it it seems the cd/dvd rom drivers are missing.
I here give the link uploaded by me, which contains the driver for CD/DVD ROM fro windows 7, Please open device manager and manually locate the CD/DVD rom and select the .inf file to install the driver
http://rapidshare.com/files/297330669/CD_ROM_Drive.rar.html
Please leave me comment, if you need further assistance
Rnj VINODKUMAR
Rename CD-ROM Drive.txt to CD-ROM Drive.rar!
@ADDeveloper
Try the Intel package(link posted before), that's an Intel mobo.
Oct 24, 2009 | Computers & Internet
Installing Windows 7 - CD/DVD driver missing message.
windows 7 will still be released next month. are you using the beta version?
Sep 12, 2009 | HP Compaq Presario V2000 Notebook
My cd/dvd driver is not working on my hp notebook
Go to HP's support website, find your laptop, and get the missing driver, or find out what brand your cd/dvd drive is and go to the manufacturers website to get the driver. I hope this helps!
Jul 24, 2009 | HP Pavilion dv9000z Notebook
HEWLETT-PACKARD HP G72-B62US Notebook Logo
513 people viewed this question
Top HEWLETT-PACKARD Computers & Internet Experts
Davit Mamyan
Davit Mamyan
Marvin
Marvin
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
