Question about SanDisk 2GB microSD Memory Card
Memory card full but computer cant read it
My computer is not reading one of my memory cards but it can read other memory cards that I have
    Problem Solver:
  • 19 Answers
Maybe the pins in the memory card are broken or there may be dust lodged in the memory card :D
Posted on Dec 08, 2008
2 Suggested Answers
firesnake09
  • 2923 Answers
SOURCE: memory card cant be read
Are you using a card reader? If yes, you need to isolate the problem. Please follow the steps below:
1. Try connecting your memory card reader into different USB port of the computer.
2. Try using different card reader to see if there's a problem with the card or with the reader.
3. Connect it into different computer.
4. Remove and reinsert the MicroSD in the card reader and make sure that the card is properly seated.
5. If the card reader and the computer are working but still unable to detect the MicroSD, try to reformat the card.
6. If same problem persist, return it to the store and have it replaced.
Have a great day!
Posted on May 27, 2009
How can i switch a memory card from read only to open
You didn't specify the type of memory card so I'm assuming it's a Secure Digital card.
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Nov 13, 2014 | Electronics - Others
Cannot add,edit,delete any files on my micro sd card,error shows it is a read-only memory card,
click start click to open on my computer you should see your SD card E: right click select properties there will be an array of options select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
click start right click on my computer select open
Right click the of your SD card (It should be E:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
hope this helps you
Feb 21, 2012 | Electronics - Others
My pc cant read my 2 GB SD memory card. I tried for thousand times... plz help
Hi divine_chord,
If the memory card is working perfectly in your device , then you need to check if the the memory card has a password to it, if it does then you will not be able to read it in your computer , so all you need to do , is remove the password on the memory card and then try connecting the memory card to your PC.
Sometimes different card reader can read it so it would be good to give it a try.
Hope this helps ..:)
Sep 04, 2011 | SanDisk 2GB microSD Memory Card
I cant format my memory card and my cellphone cant read it to what should i do .
Get a Multimedia card reader for yourself. Plugin in the card reader in computer and insert the SD card in it. Once you see the SD Card in My computer that means your card reader is able to read the SD card that you have inserted. You can right click on the icon and click format. Do a quick format and choose file system as FAT32.
or
You can use SD Card Formatter and can follow their manual. I think that will also work for you. http://www.sdcard.org/consumers/formatter_3/
Jun 21, 2011 | SanDisk 2GB microSD Memory Card
Error message Built in memory full. Also won't read memory card.
You need to format the internal memory with no card in the camera. Then, you need to format the memory card in the camera.
Feb 17, 2010 | Pentax Optio S5i Digital Camera
MEMORY CARD
hi check the memory card memory status is full or what and if its over load it take time to read and confirm that is it in the right format.
Sep 29, 2009 | Motorola Mobility RAZR V3
MY COMPuter doesnt read the memory card, i cant
The hardware may not be connect.Go in control and press hardware then you reinstall memory card drive.See if that works
Aug 27, 2009 | Cameras
New sd cards reads memory full
Try to format the card. If possible, use an external card reader attached to a computer.
Make sure the card is unlocked (with the switch on the side of the card).
Have you managed to have other cards working on the camera?
May 07, 2009 | Kodak EasyShare C330 Digital Camera
I have a 256MB SD memory card (SanDisk). The case has split and my camera and my computer cannot read the card. Is there anything I can do? My Samsung L201 Camera and other cameras cannot read the my...
Try to check your memory card with at least 5 different computers. if they have card readers much better. memory cards have to be given at least 8MB for processing. It may have been used up even the space for processing. If haven't save the files before you kept it. It was really damaged. It needs to be formatted to make it function. There could be other reason why your memory card couldn't be detected. I'll just tell you next solution if you have tried this one. For now just do my suggestions for confirmation coz your pc has no support format for your memory card.
Please rate this solution for me to check any update.
Thanks....
jonags
Nov 30, 2008 | Samsung L200 Digital Camera
Sigmatel s4 says mscd read error when i put my memory card
no your memory card innearly full.connect yourmmemory card to computer tyheh remove some data.
Nov 10, 2008 | Handmark Software MobileLists (950142) for...
SanDisk 2GB microSD Memory Card Logo
192 people viewed this question
Top SanDisk Electronics - Others Experts
Piyal Perera
Piyal Perera
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
