Question about Intertherm Heating & Cooling
My black tank inside the condenser is broke and I would like to kmow what would be cheaper for me, to buy a new condenser or just to buy this black tank.
  • 85 Answers
What do you mean by black tank, the compressor or expansion tank? If it's the compressor, then buy a new unit. Or if your doing it yourself, buy a compressor. Get two different quotes from your contractor and see what is the better deal?
Posted on Dec 08, 2008
Broke small black connector between fuel line to side of carburetor. Flat bottomed funnel shape fits in to side of carb. Has filter inside. I believe it feeds the primer.
That is a fuel tank vent kit. Most models have a vent in the fuel cap but that model uses a separate line with a Duck bill vent (usually a green rubber inside that piece in picture). Part number for that is 574859301 . Your blower should run ok with out it but could leak fuel. If you are going to order any parts for your blower do so using Model # PPBP30 Your parts will be cheaper. That particular model has exchanged hands between MTD/Mcculloch/Bolens and Husqvarna/Poulan over the years. The parts are cheaper when you use the Husqvarna/Poulan model # PPBP30. Only noticeable difference will be a yellow starter housing if you buy a starter assembly.
Dec 17, 2015 | McCulloch ASB3206 - Blowers - 30cc Gas...
My kyocera hydro sim card spit the metal that you keeps it inside broke how can I fix it
sadly you can not do it yourself. has to go in to repair shop . might be cheaper to buy a new one .
Oct 21, 2015 | Kyocera Cell Phones
Steam buggy not heating up
heating element has gone or the temp sensor, element gone cheaper to buy a new one temp sensor cheap to replace sits on the tank inside has 2 weirs un plug the wire and the 2 screws that hold it to the tank, 10 min job to replace.
Aug 22, 2014 | Vacuums
My charging doc has broken
The only way to repair would be to solder a new connector to the mainboard. It would be much cheaper to buy a new tablet.
Mar 28, 2014 | Kocaso M1052S 10.1" Android 4.0 Tablet PC
Vicks warm air humidifier replacement part
Does this help you? http://www.appliancefactoryparts.com/humidifiers/vicks/v5100ns.html
My OX husband trod upon his new humidifier LOL...broke the tank and I cannot stop leaking. Anyone have a site where I can buy just a Vicks tank?
Feb 18, 2013 | Vicks Warm Mist V745A 1 Gallon Humidifier
The overflow pipe broke off when I was installing a new fill valve. I bought a new flush valve that came with a thick, pink gasket. When I used this gasket, the tank doesn't sit close enough onto the...
I haven't seen a pink one, but the new gasket should fit over the nut on the new overflow. Keep tightening down the bolts slowly a little bit at a time on each one until the tank doesn't rock. Check on it for a week or two to make sure it doesn't leak. If you don't like the seal that came with the kit, you can buy a different one for a few bucks at the hardware store.
Jan 30, 2011 | Fluidmaster INC #B1F09 9" Faucet Connector
Let my tank freeze and crack on the perfecta model EZ33 959. Where can I order a new one
If the tank froze and broke it is highly likely the toilet itself may have a crack somewhere inside. You may buy the tank and find out later on the toilet itself it cracked. You have then wasted your money. Buying the tank and paying the shipping is more than likely about as much as a whole new toilet. My advice is to buy a new toilet.
Jan 08, 2010 | Jacuzzi Bath Perfecta EZ33 959 White round...
MY RADIATOR NOZEL BROKE OFF THE ON ON THE DRIVERS SIDE CAN THIS BE REPAIRED
If you are talking about any part of plastic tank then yes/kinda. Your gonna need to pull it out and take it to a radiator shop. They can clean it and put a new tank on it. But to be honest with you by the time you have all of the work done on it, most of the time it's cheaper to buy a new radiator.
Dec 09, 2009 | 1996 Chevrolet Suburban
I have a 25cc weedeater leaf blower that will not idle. I found that the fuel line broke off at the filter inside the tank. Do I need to replace the line and filter or the tank assembly?
Order a new fuel filter and fit it on the existing line...unless the line is brittle and breaks easy in which case you would replace the line. The fuel lines pass through the tank and are fairly easy to replace plus they ahve the added advantage of being cheaper than a new fuel tank.
Oct 19, 2009 | Garden
Heating & Cooling Logo
35 people viewed this question
Top Intertherm Heating & Cooling Experts
Dennis Boxerman
Dan Webster
Dan Webster
Bill Long
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
