Question about Sony VAIO VGN-NR220E/S Notebook PC
Hard disk when i open my computer. it show's as this much memory used of 179 gb..... wanted to confirm how many hard disk options were available in this model.... was it only 160gb or are ther more options available???
Usb speed 900kbps
you might have to many programs running at the same time putting to much strain on the CPU central processing unit
try uninstalling a few unnecessary programs This tool deletes unnecessary or temporary files on your hard disk so you can increase the amount of storage space you have. Delete the files using Disk Cleanup If you want to reduce the number of unnecessary files on your hard disk to free up disk space and help your computer run faster, use Disk Cleanup. It removes temporary files, empties the Recycle Bin, and removes a variety of system files and other items that you no longer need. Open Disk Cleanup by clicking start all programs accessories system tools and then clicking Disk Cleanup. In the Disk Cleanup Options dialog box, choose whether you want to clean up your own files only or all of the files on the computer. If you are prompted for an administrator password or confirmation, type the password or provide confirmation. If the Disk Cleanup Drive Selection dialog box appears, select the hard disk drive that you want to clean up, and then click OK. Click the Disk Cleanup tab, and then select the check boxes for the files you want to delete. When you finish selecting the files you want to delete, click OK, and then click Delete files to confirm the operation. Disk Cleanup proceeds to remove all unnecessary files from your computer. This tool deletes unnecessary or temporary files on your hard disk so you can increase the amount of storage space you have. Delete the files using Disk Cleanup If you want to reduce the number of unnecessary files on your hard disk to free up disk space and help your computer run faster, use Disk Cleanup. It removes temporary files, empties the Recycle Bin, and removes a variety of system files and other items that you no longer need. Watch the demo (1:00) this should speed up your computer
Mar 12, 2013 | Computers & Internet
Was using my 1TB and then all memory (pictures) dissapeared. Still shows memory used/available, just all the files are gone.
Those files are hidden folders.
For that connect it to computer then open my computer go to tools menu->folder option.
then click view tab enable "show hidden files and folders" and disable check box of "hide system files" then apply then you can see your files as hidden folder.
then open it then copy all files to local drive also scan computer and harddrive with updated antivirus because it (harddrive) is infected of virus.
Let me know if you need further assistance.
Thanks for using FixYa.
Jan 09, 2011 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Want directions on how to backup to western digial external hard drive. We use microsoft vista and we have a 500gb external drive.
This may vary, depending on the software you use, but if it's Vista backup and restore, follow the steps below:
  1. Open Backup and Restore Center by clicking the 'Start' button, clicking 'Control Panel', clicking 'System and Maintenance', and then clicking 'Backup and Restore Center'.
  2. Click 'Back up files', and then follow the steps in the wizard (during this process, you will be given an option to select the destination for your backup - Browse for the WD drive in my computer and select it). You will also be given the option to select which files you would like to backup - You can either select everything or you can select specific folders (an option for browsing will be available), you may want backed up. If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
Hope this helps.
Jan 23, 2010 | Western Digital 500GB ELEMENTS 500 GB USB...
CD Disk Drive E doesn't want to open
Right click on "My Computer" and press "Device Manager". See if your CD drive appears in there. If it does, delete it and re-boot. The PC should find the CD as a new device and re-install standard drivers for it. Hope this helps. Ian.
Sep 27, 2009 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
Using windows xp but want install windows 2007
the message might be either about your hard disk or mostly about your RAM size. for windows 2007 these are the basic requirements
  • 1 GHz 32-bit (x86) or 64-bit (x64) processor
  • 512 MB of system memory
  • 20 GB hard drive with at least 15 GB of available space
  • Support for DirectX 9 graphics and 32 MB of graphics memory
    if your system does'nt meet the req then upgrade it and then install the operating system
Aug 29, 2009 | Microsoft Windows XP Home Edition
Memory space
acer laptops have 2 memory hole. you can use 2 x 2gb total 4 gb. but in XP you can see only 3 gb with Service pack 2. in vista you can see all 4 gb.  hope its you need. pls rate
May 28, 2009 | Acer Aspire 5735 Notebook
HDD Partition help
Important If you follow these steps on a hard disk that is not empty, all the data on that hard disk is permanently deleted. We recommend that you back up your hard disk before you follow these steps.
To partition and format your hard disk by using the Windows XP Setup program:
1. Insert the Windows XP CD-ROM into your CD-ROM drive or DVD-ROM drive, or insert the first Windows XP Setup disk into the floppy disk drive, and then restart the computer.
Note To start your computer from the Windows XP CD-ROM (or from the startup disk), your computer must be configured to start from the CD-ROM drive, the DVD-ROM drive, or the floppy disk drive. In some cases, you may have to modify your computer's BIOS settings to set this configuration. For information about how to configure your computer to start from the CD-ROM drive, the DVD-ROM drive, or the floppy disk drive, see the documentation that is included with your computer, or contact the computer manufacturer.
2. If you are starting the computer from the Windows XP CD-ROM, select any options that are required to start the computer from the CD-ROM drive if you are prompted to do this.
Note If your hard disk controller requires a third-party original equipment manufacturer (OEM) driver, press F6 to specify the driver.
For additional information about how to use F6 to supply a third-party OEM device driver while the Windows Setup program is running, click the following article number to view the article in the Microsoft Knowledge Base:
314859 Limited OEM driver support is available with F6 during Windows XP Setup If you are starting from the Windows XP Setup disks, insert each of the additional disks when you are prompted, and then press ENTER to continue after you insert each disk.
3. At the Welcome to Setup page, press ENTER.
4. Press F8 to accept the Windows XP Licensing Agreement.
5. If an existing Windows XP installation is detected, you are prompted to repair it. To bypass the repair, press ESC.
6. All the existing partitions and the unpartitioned spaces are listed for each physical hard disk. Use the ARROW keys to select the partition or the unpartitioned space where you want to create a new partition. Press D to delete an existing partition, or press C to create a new partition by using unpartitioned space. If you press D to delete an existing partition, you must then press L (or press ENTER, and then press L if it is the System partition) to confirm that you want to delete the partition. Repeat this step for each of the existing partitions that you want to use for the new partition. When all the partitions are deleted, select the remaining unpartitioned space, and then press C to create the new partition.
Note If you want to create a partition where one or more partitions already exist, you must first delete the existing partition or partitions, and then create the new partition.
7. Type the size in megabytes (MB) that you want to use for the new partition, and then press ENTER, or just press ENTER to create the partition with the maximum size.
8. Repeat Steps 4 and 5 to create additional partitions if you want them.
9. If you want to install Windows XP, use the ARROW keys to select the partition where you want to install Windows XP, and then press ENTER. If you do not want to format the partition and install Windows XP, press F3 two times to quit the Windows Setup program, and then do not follow the remaining steps. In this case, you must use a different utility to format the partition.
10. Select the format option that you want to use for the partition, and then press ENTER. You have the following options:
Format the partition by using the NTFS file system (Quick)
Format the partition by using the FAT file system (Quick)
Leave the current file system intact (no changes)
The option to leave the current file system intact is not available if the selected partition is a new partition. The FAT file system option is not available if the selected partition is more than 32 gigabytes (GB). If the partition is larger than 2 GB, the Windows Setup program uses the FAT32 file system (you must press ENTER to confirm). If the partition is smaller than 2 GB, the Windows Setup program uses the FAT16 file system.
Note If you deleted and created a new System partition, but you are installing Windows XP on a different partition, you will be prompted to select a file system for both the System and startup partitions. 11. After the Windows Setup program formats the partition, follow the instructions that appear on the screen to continue. After the Windows Setup program is completed, you can use the Disk Management tools in Windows XP to create or format more partitions.
For additional information about how to use the Windows XP Disk Management tools to partition and format your hard disk, click the following article number to view the article in the Microsoft Knowledge Base:
Oct 19, 2008 | Computers & Internet
Maxtor 3200
Jeena you can just connect the hard drive to the mac it will recognize it & it will install the drivers automatically.
Before using it you have to format the drive using the Apple's disk utility.
First, locate the 10.2 CD and start up the iMac using the CD (insert CD, restart computer, immediately hold down C key).
Do not click on the installer screen. Instead go to the Installer Menu (or Options) and select Disk Utility.
When that opens, click on the second icon at the top left, then click on Repair Disk. Watch the activity screen. If it does any repairs, you will need to click on the Repair Disk button a second time. This is to make sure it finds all the problems and repairs them. You want to see no reference to repairs made - which may mean you have to click on that button three or four times.
How much memory is installed on the computer? To find this, just go to the Apple menu at the top far left and select About This Mac. The window that opens will give you the amount of memory installed, processor speed and exactly what OS version you are running.
How much empty available space is on the hard drive? To find this, just open a window. At the very bottom you should see how many items and how much available space.
You can use the SMART to run the diag on your had drive from
http://www.apple.com/downloads/macosx/system_disk_utilities/smartutility.html
The additional tasks which can be performed by using disk tility can be found :
http://www.macworld.com/article/51199/2006/06/julyworkingmac.html
This will solve your problem.
Good Luck.
Live, Love, Laugh.
Apr 08, 2008 | Maxtor Personal Storage 3200 (U01E200) 200...
Sony VAIO VGN-NR220E/S Notebook PC Logo
56 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
