I just brought a hp printer and i tried to install it but the on screen information told me that i didn't have enough rams on the computer to use this hp printer so what can i do because i need this printer/i have a dell computer/w window xp. please help
  • Dan
    Dan May 11, 2010
    How much ram do you have installed?
    Most likely, your error has to do with how much free ram your system had at that moment.
    Reboot, and try to install the printer again.
    Post back your results.
  • 69 Answers
Easiest thing to do would be to buy a RAM upgrade from Dell.com; you can look it up under the Service Tag for your machine if you haven't created an account yet.
If you already have a Dell.com account, after you login to Your Account, look for "My Systems and Peripherals" on the right, and there should be a link called "Find More Parts for Your [Computer Description]" and then you can select the "Memory" category.
512 MB should be enough, and the Dell brand memory at that size goes for under $20.
Posted on Dec 08, 2008
  • 80 Answers
You have to increase your rams by 128megabites
Upgrade BIOS to see if it will resolve hardware issue with new stick of RAM
Hi Szusza,
The new RAM module you purchased may be faulty, it is definitely possible that either due to a fault of the new RAM or on the slot you are trying to install it to cause the computer to not fully boot.
Have you tried to boot the computer with the new module only?
If not please try this:
Replace the original RAM module with the new one (make sure you insert the new RAM in the same slot you took the old one out)
If the PC boots you know the new RAM is fine.
If this does not work I would suggest getting your new RAM tested.
If it does work, put the original RAM back in the computer (in a new slot) if it does not boot after that then, there is possibly a problem with the RAM slot on the motherboard.
Dec 16, 2013 | HEWLETT-PACKARD Compaq Presario CQ5302F...
I CAN'T INSTALL MY PRINTER HP DESKJET D2400
Hi mpc 124!
You didn't gave enough details on your problem so I will have to do a rundown of some of the details. Pleas bear with me....
In installing your printer, you will need the cd driver. The cd driver comes along with the printer. Once you plug the printer into the computer, it will automatically detects the printer. However, you will not be able to use it immediately until you load the driver.
If you don't have the cd driver, here's the link: http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=3317536&lang=en&cc=us&taskId=135&prodTypeId=18972&prodSeriesId=2510721
If you have the cd driver, all you need to do is load it in your cd/dvd reader and follow the on-screen instructions.
Hope I have been of help.
Jul 20, 2011 | Computers & Internet
My computer will not start after the toshiba screen comes up. The screen is black with a blinking cursor
That might be caused with a lot things maybe RAM, maybe a corrupted OS, or might be a loose connection of the hard drive, maybe a virus or a malware. If you can go safe mode( by pressing f8 during boot up)run your anti virus from there if that didn't work try your system restore. If that didn't work try removing your RAM and replace it (you must have a back up RAM at least for testing purposes). If that didn't work also try removing your Hard Drive. Remove it carefully then carefully re install it.(Remember to pull out the battery and the charger before removing your Hard Drive and RAM for safety precautions) If neither of the above worked, then clean installing your OS is your last option.
Good Day.
Jul 09, 2011 | Computers & Internet
Do the computer have eny problems
Sorry mate all computers can develope problems either by downloading or installing too much software. Viruses and infections can be a night mare and hackers can steel valuable information.A hard drive doesnt really lose the information when you delete it it can be brought back by the right person it sold on. Then theres internal problems theres a lot of technical software inside a system always take care of what you have get a good security software and youll be safe. For a new computer to develope a fault is exstreamly rare and they all have a system called backup. so if you lose a system just go to backup and your system you lost will be recovered.
Nov 16, 2010 | HP Compaq dc7100 Small Form Factor PC...
SOFTWARE CANNOT BE INSTALLED USING THE RUN AS COMMAND I have brought a new Compaq laptop & I'm now trying to install my HP psc 1315 all-in-one printer/scanner/copier. I'm loading the Windows CD &...
try restarting the system, after a few seconds BEFORE windows load press F8 continuously until a selection screen appears, select safe mode, wait for it to load, select ADMINISTRATOR ACCOUNT not your name or your account log in, install printer driver, restart. Your driver is installed.
Jul 02, 2010 | HP PSC 1315 All-In-One InkJet Printer
Canon ip4500 printer driver won't install
check the canon website to see if they vista drivers for this printer. It might not be compatible with vista.
Jul 31, 2009 | Canon PIXMA MP980 All-In-One InkJet...
Im trying to install my printer to my laptop and its telling me that the system does not meet one of more of the requirements needed to install this product.
Those printers need lots of RAM memory and enough hard drive space. You should have at least 512 to 1024 MB RAM memory and ewnouigh hard drive space otherwise it wont install.
Jul 06, 2009 | HP Photosmart C3180 All-In-One InkJet...
Tried to replace/upgrade memory ram; now computer
It sounds like they installed bad RAM or wrong RAM..did it ever work after brought it back from the store?
Apr 13, 2009 | HP ze5478CL (dk567a) PC Notebook
The computer will not recognize the printer
A-hem, didn’t se that you already told me you printer model,
- Sorry, always in a hurry.
the driver for this printer is to be found at this site:
Select your operating system, download and install.
plz, let me know the result.
/Teis
Happy New Year
Dec 29, 2008 | HP DeskJet 5150 InkJet Printer
Blue Screen while installing drivers for DELL wireless Photo966 printer. I have a DELL INSPIRION E1505 Laptop, running windows XP, 1.66GHZ, 1GIG RAM, 68.4 GIG harddrive (51.9 available). I have installed...
You have an hardware compatibility issue between some of your devices (maybe the printer or RAM)and windows, this cause the fatal exception in question. This is usually not a big problem, but is difficult to troubleshoot it from here in few lines. A way to fix it is doing a fresh Windows installation after you do a backup of all your stuff. If you have some spare RAM you can also try replacing them to test it. Faulty RAM causes similar phoenomena.
regards
Mar 02, 2008 | Office Equipment & Supplies
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
