Question about Bushnell Trophy 3-9x40 Rifle Scope, Matte Finish Rifle Scopes
Lost manual for trophy scope 3-9x40 rifle
Need manual for scope adjustment , so I don't have to waste ammo
  • 99 Answers
There is no manual for elevation and windage adjustments. (at least not one that comes with your scope; all your scopes manual will say is whether its FFP or SFP (First Focal Plane or Second Focal Plane, the scale used on your scope for mil dots)(you can get this info by finding a store that sells this scope and asking a sales rep)
To adjust for elevation and windage you have to take into account the daily factors (unless your shooting in the same indoor environmental controlled shooting range each day you SNOB! jk
The formula takes alot of variables into account and is known as Exterior Ballistics
!) Environmental Factors - First thing you account for.
A) Elevation from sea level plays a large part into your environmental adjustments. Your elevation from sea level determines largely the Barometirc Pressure but it also varies slightly with Temp and Humidity (Major Factor)
B) Temperature - The temperature can affect the density of the air. The hotter it is the thinner it is and therefore less resistance and a higher bullet trajectory (Minor Factor)
C) Humidity - This again will affect the densify of the air infront of your bullet (Minor Factor)
D) Barometric Pressure - The other large factor in air density this is the base stat that the others modify
These all combined create a ratio that you apply to standard MOA (windage and elevation adjustments) to obtain the shooting information for that particular environment)
2) Bullet Factors (Listed on the Box you buy) - There are a few bullet factors to take into account.
A) Speed - the bullets feet per second can vary as much or more than 500 feet per second with the
same caliber ammunition.
B) Grain - The Grain of an ammunition is a measure fo its "Sectional Density" or weight to volume
ratio
C) Ballistic Co Efficient - This number is the measure of the bullets ability to maintain its speed
during flight. This also varies from Grain to Grain
These factors are complex and a pain for the best of shooters to determine. adding to that confusion. there are many ways to determine a bullets ballistics coefficient and each one gets a different number. In this case bullet data is best retieved from the manufactuerers box and take their word for it.
3) Lastly you account for shot factors.
A) Range - by referencing your standard elevation MOA adjustments and mutliplying by the ratio for environment the Elevation MOA is achieved.
B) Windage - Windage is done in inches per mile per hour then is multiplied by the Mph of the wind.
In order to be precise the windage is done in inches instead of MOA. it needs to be converted heres and example.
You Ballistics Cheat Sheet for the day says the windage at 900 yards is 5.2 Inches per mph of wind.
you apply the ratio for your environment .90 (all example numbers. this number would represent a shooting environment with an air density lower than standard/ the cheat sheet's known MOA adjustments). the 5.2 inches is multiplied by .9to acheive 4.68?? idk the point is you mulitply that by the wind of 10 mph to achieve a total of 46.8" of wind drift to the target.
now for the conversion to MOA. 1 MOA is eqaul to 1.047" per 100 yards. meaning for every 1 moa you adjust the bullet will move 1.047" per 100 yards (our target is 900 yards; meaning that each MOA for this target is 9*1.047" = 9.423" per MOA adjustment. so take that number and divide our total wind drift by it. ie 46.8 / 9.423 = MOA Windage Change of 4.9665... now you need to know whethere your scope is 1/4 minute clicks or 1/8 minutes (how many spaces between large numbers?) you would adjust to 5 MOA for a 1/4 minutes scope equaling 20 clicks on an 1/8th minute scope it would be 40 clicks.
This is the math of shooting. to learn how go to
WWW.shooterready.com they are an excellent sight to get the math down WITHOUT wasting ammo. Once you have the math you an transfer it to your gun. waste a few rounds checking it out and youll be hitting targets @ 1800 yards in no time
I like to take the simple way after i learned how to do the hard way
There is software tha will do the exterior calcualtions for you.
if your interested i use Sierra Infinity V6 Ballistics Software
GL
Posted on Apr 08, 2009
  • 2,100 Answers
I have the same scope, but I don't have the manual. If you are shooting a bolt action, take out the bolt, rest the rifle in a cardboard box, sighting down the bore at the target, put the crosshairs on the same target without moving the gun, it will hit its mark at 100 yrds.
Posted on Dec 10, 2008
Tip
Sight in your scope
I have given this tip to a dozen people this week. It will save you a ton of ammo. If you don't have a bore sighter of access to one, get a big cardboard box, cut V's in the top that the rifle will sit in nicely, remove the bolt. Find a target, 100 yards away, sight down the bore, tilt box, rifle to target, make sure it doesn't move, adjust scope to the same target. check to see if the rifle is still on, then check the scope again. This will put you on paper at 100 yards.
on Feb 17, 2010 | Optics
Has president obama issued any orders to prohibit .223 rifle ammo ?
Yes and no as it is the m855 .223 ammo that they are going to reclassify not the fmj and other hunting and target rounds
As m855 is used if the target is wearing body armour and the majority of body armour wearing targets are government employees he believes that Joe blogs has no need for them
Hope that helps
Feb 28, 2015 | Optics
How to set scope up by yd lines in scope,
dont even trust them,,,,if you use them with one make of ammo they will be off with another make of ammo,,,,,so test fire it,,
Nov 21, 2010 | Pentax Gameseeker Rifle Scope Warranty...
I DON'T KNOW WHAT YARDAGE THE DOTS REPRESENT
it dont really matter what they are,,if you use one make of ammo it will not shoot the same when you use another make of ammo,,,the best thing to do is test fire the rifle and work it out? with the type of ammo you will use all year long?
Nov 21, 2010 | Bushnell Trophy Series RiflescopesChoose...
Sks jams,using wolf ammo
Wolf is a cheap ammo you dont pay much but you dont get quality ammo either. Make sure your gun is clean and the extractor spring isnt worn thats about all you can do in this situation.
Jun 12, 2009 | SKS Rifle High-profile See-thru Scope...
Windage and elevation adjustment all over the place
Sounds like you want to "re-sight" in your rifle. Make sure mounts are okay and tight. Look down barrel and then thru scope and eyeball windage and elevation adjustments so the scope seems to be fairly in line.
Clean barrel if it needs it.
For basic sight in, start at 25 yards with a large(3 to 4 feet) cardboard or wood backdrop around target (bullseye). Fire at target. Once done, look through scope and position rifle such that the shot mark you created is dead zero. Hold rifle very steady and you or buddy move windage and elevation adjustments until scope moves dead zero back toward original target (bullseye). Fine tune from there. Air cool rifle between rounds. Once dead eye, fire another round or two to check grouping. Check your ballistics (sometimes on ammo box) to see how height at 25 yards affects your desired dead on target (100 yards, 150 yards, 250 yards etc.). Adjust accordingly. Example: you may need to sight in at an inch high at 25 yards, depending on your dead on target distance..
Always remove sling from barrel when sighting in.
Try to sight in at similar temperature as you intended shooting temperatures, if possible.
If not black powder, avoid cleaning barrel between sight in and hunt/competition unless you note bad buildup inside.
If you change ammo, understand that that may affect performance. Once a preferred ammo is found, some even try to buy a decent quantity with the same lot number on the boxes if storage allows for such.
May 02, 2009 | Optics
How to sight scope in /what scope do i have ?
Real simple Scott.
You can 'Zero' your scope/rifle even if you don't have a laser bore-scope device.
All this is assuming that your used rifle has not had the barrel shot out and that the head-space is still within specs for that rifle. Have all this checked by a gunsmith first. You can dress up a piece of poop and it will be pretty, but still be poop. Make sure yours isn't to begin with. As for the scope, it's hard to tell unless there's obvious damage or it's an antique past it's prime. Try to get as good a quality scope as possible to start with. You would not put one ply tube tires on your mustang and expect to get the best performance, so...
Most rifles are capable of shooting quite accurately, and all things being equal, it's the shooters job of making it happen.
Ammunition should be considered as well. Toss your old military ball ammo and junk from overseas, both of'em. If you want to shoot accurately and consistently, you must spend the bucks for the best ammo you can afford.
You MUST KNOW what the BALLISTICS are for the Cal./type/weight ammo you will be shooting and the corresponding distance it will be shot from.
Make sure your rifle is CLEAN inside and out. A clean rifle is a happy rifle.
Make sure that your rifle 'fits' your body's frame and that you are familiar and practice good rifle shooting techniques.
'Zeroing' is best done from the prone position as that is the most steady position to shoot from.
Do you have a bi-pod attached? Whether you do or not, sandbag your rifle securely but still able to make small adjustments to the rifle position itself.
Set up a target with a 1" black dot at 50rds.
Remove the bolt.
Lay down with your rifle but stay OFF of it, touch it as little as possible at this point.
With out disturbing the rifle look through the bore downrange to your target. Locate the black dot and if necessary adjust your rifle from the **** end until you can see the dot through the bore. Keep making minor adjustments until the dot appears to be centered in the bore. Make sure rifle is secure and steady at this point.
Then without moving or touching the rifle, look through the scope using the correct eye relief distance and locate the black dot. Now using the Vertical(Elevation) and Horizontal(Windage) adjustment knobs, move the reticles(crosshairs) until they both are centered on the dot.
Again look through the bore to make sure that you have not moved the rifle and that the dot is still centered in the bore. If not, adjust the rifle again to center the dot, then go back to the scope and adjust as necessary to move the RETICLES to the center of the dot. It may be necessary to repeat this a few times before you have achieved this particular goal.
You do not mention brand/model of your scope. It probably adjusts the reticle or crosshairs in 1/4minute increments (1/4 inch increments with each individual click movement of the turret knobs at 100 yard distance). IT IS CRITICAL for you to know how your own scope adjusts.
Now, bolt back in and load 3 rounds of quality ammo.
You are going to shoot 3 rounds in succession without getting off the rifle or making any adjustments to the rifle or scope. You are looking for a 3 shot group to determine a rough average of how far and where the rounds are impacting initially. Use good shooting techniques, breath control, relax, sight picture, squeeeeeeze the trigger, follow through the scope, there is no need to take your eye off the scope while doing this, hold your shooting position for all 3 shots.
You will now have to make adjustments of the scope unless you are hitting the black dot already which is quite possible.
Remember that if your scope is a 1/4" adjustment at 100yds, it means that for each 'click' that you adjust either Vertically or Horizontally at 100rds, the reticle/crosshairs will move accordingly 1/4 of an inch Vertically or Horizontally. At 200yds, one click will move it 1/2 inch, at 300yrd it will move it 3/4 of an inch, at 400yrd, it will be 1 inch.
Right now you are at 50yrds distance from your target. Each click from here will move the RETICLES about 1/8 of an inch so estimate the distance that your most central shot of the 3 you fired, is from the black dot and adjust accordingly. You're not moving the RIFLE here, you are simply moving the scope RETICLES so that your point of aim and point of impact coincides.
Now load 3 more rounds of ammo and repeat as above. You should only have to use about 9 rounds to get on target, the black dot.
Once you are hitting the black dot at the 50yrd line, move back to the 100yrd line. Put a fresh black dot on your target and repeat the steps from above. Your first 3 shots from the 100yrd line should be about 1/2 to 1 inch low. Don't follow the bullet strikes! Keep your point of aim and the crosshairs ON the black dot no matter where the bullets are striking on the target. Remember, now at 100yrds your RETICLES will move 1/4inch with each 'click' of adjustment of the turret knobs.
Adjust the scope as needed at this point. Once you are 'ON TARGET'(hitting the black dot), you now have your 100yrd. 'ZERO'.
Now that you have this 100yrd ZERO, you must loosen the turret knobs , both the Vertical(Elevation) and the Horizontal(Windage) turrets and align the '0' on the knobs with the '0' on the scope at the base of each knob. Now tighten the set screws and you are set to go. If you want to know your 200yrd 'ZERO', simply move back to the 200yrd line, your 'come-up' or elevation adjustment should be about 7-9 clicks, at least for .308 168grn HPBT, but you will figure it out for the Cal./brand/wght ammo you are using. WHATEVER the 'come-up' you need to make at 200, 300,400yrds or wherever, be sure to make note of the number of clicks you used to find the Zero for that distance. Use a fine point endelible marker and actually write the ZERO info on thestock of your rifle. You don't need to mark anything for the 100yrd ZERO, it's a given already. Write; 200/9, 300/18 and so on. You should also get your ZERO for the intermidiate, 150yrd, 250yrds etc, distances as well.
Remember that weather conditions, source and intesity of light conditions, your own body condition at any particular moment or day can have an affecf on how you and/or your rifle shoot. Good luck.
Mar 21, 2009 | Tasco ® Silver Antler® 3-9x40 mm Scope...
Scope
Follow these steps
1) Mount your scope.
2) Use a bean bag or rifle mount and make sure that your rifle doesnt move much from its original position throughout this process.
3) Aim with the scope and shoot at a large backstop which will allow you to see where your shot lands, where ever that may be, it doesnt matter at this point. Again, make sure your rifle doesnt move much when firing.
4) With the rifle in the same position, look through the scope and adjust the crosshairs over to where your shot landed.
5) The scope now sighted in with the rifle. Minimal adjustment may still be required but at least your well within the ball park.
Happy Shooting
Nov 13, 2007 | Bushnell Trophy Multi-Reticle Red Dot...
Bushnell Trophy 3-9x40 Rifle Scope, Matte Finish Rifle Scopes Logo
598 people viewed this question
Top Bushnell Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
