Question about Asrock 775i65GV Motherboard
When choosing a memory for your PC
Hi I just want to know what are the keys or requirements in choosing a compatible memory for your PC?
    Scholar:
  • 162 Answers
You computer motherboard memory specification is
- Dual Channel DDR memory technology
- Supports DDR400/333/266 non-ECC, un-buffered memory
- DIMM slots: 2
- Max. capacity of system memory: 2GB
you can choose the memory according to specification.
Posted on Dec 08, 2008
    Problem Solver:
  • 19 Answers
Try this website, input the manufacturer etc of your computer and it will scan it and tell you what is compatible http://www.crucial.com/ :D
    President:
  • 1,073 Answers
In the manual of your motherboard you can see what memosticks suported and compatible on the motherboard
If you dont have the manual but know the name of the motherboard you can find same info on the producers site
If you want me to link you you need to tell me name on your motherboard
Good luck
Installing adobe acrobat pro 6 to windows 7
This is an old version of Acrobat that was written for NT, Win2K and XP. Due to changes in the OS, it's hard to get the program to install in Windows 7.
Which version of Win7 do you have? (32-bit or 64-bit and Home Premium, Pro or one of the other variants) Since you indicated this under the Dell Dimension E521 with 1 GB of memory, I'll guess Win7 Pro 64-bit. (This uses the 64 bit CPU) You can check by clicking Start > Control Panel > System and Security > System. If the Windows version ends with x64, it is the 64-bit version. Otherwise, you have the 32-bit version.
Under the 64-bit OS, you need one of the following workarounds: a second computer, a dual boot computer or a virtual computer running an older version of Windows. If your hardware supports virtualization, this might be a good bet if you can add memory to computer. With Win7 Pro or Ultimate, you can download and install Virtual PC and XP mode from Microsoft and run XP for free. Then install Acrobat in XP mode as if it were your only machine. (Note: the Virtual PC requires a share of your total memory and doesn't give it back to the main computer while it is running.)
The other methods listed require a licensed version of an older Windows OS.
If you have the 32-bit version of Windows 7, you can try the compatibility mode. Right click on the installer and choose Properties. In the compatibility tab, check always run in the compatibility mode and select an older version of Windows. Then click Apply to save the changes and then click OK. Then right click again and choose Run As Administrator. You may have to repeat the compatibility mode changes for the program itself.
You may want to consider upgrading to a Windows 7 compatible version of Acrobat. The current version is Version X.
I hope this helps.
Dec 26, 2011 | Dell Dimension E521 AMD Athlon 64 X2...
Can windows 7 run GTA IV.
Running GTA 4 on windows 7 should not be a problem. You just have to run the installer using compatibility mode. Right click on the "setup.exe" then choose Properties. Go to Compatibility tab and tick "run this program in compatibility mode for", choose windows xp sp 3. That should allow you to install GTA 4 on windows 7. Bear in mind that you have to install GfW Live and the C++ 2005 files seperately which can be found in the disk as well. More importantly, make sure that your computer meets the system requirements for the game.
Here it is: System Requirements
Minimum System Requirements
OS: Windows Vista - Service Pack 1 / XP - Service Pack 3 Processor: Intel Core 2 Duo 1.8Ghz, AMD Athlon X2 64 2.4Ghz Memory: 1.5GB, 16GB Free Hard Drive Space Video Card: 256MB NVIDIA 7900 / 256MB ATI X1900
Recommended System Requirements
OS: Windows Vista - Service Pack 1 / XP - Service Pack 3 Processor: Intel Core 2 Quad 2.4Ghz, AMD Phenom X3 2.1Ghz Memory: 2 GB (Windows XP) 2.5 GB (Windows Vista) 18 GB Free Hard Drive Space Video Card: 512MB NVIDIA 8600 / 512MB ATI 3870
After installing the game and you're not able to run it, Try running the main executable file of the game in compatibility mode as well.
Hope this helps.
Apr 21, 2011 | Rockstar Games GTA IV
I have memory craft 950.computer crashed and had to relace- now have windows 7 and can not install my cstomiser 10000 plus (ver1.0
There are software updates for the Customizer 10000. See: http://content.janome.com/index.cfm/LearningCenter/Software_Updates . Drivers and installers have changed over time.
I do not know the limitations of the update software.
I hope this helps.
(The other thing to try is the compatibility mode. This may work directly - right click on the installer and choose Properties. Then choose the compatibility tab and set the Program to always run as compatible with XP. Then right click again and choose Run as Administrator. If this doesn't work, another option is to run a second computer with an older version of Windows. You can use a true second computer, a dual boot computer or a virtual computer (which takes a portion of memory from the main computer but doesn't require a restart). If you have Windows 7 Pro or Ultimate, you can create a virtual XP computer for free. Download and install Virtual PC and XP mode from Microsoft. The other options require a valid Windows license for the older OS. Install your Customizer in the older OS as you would normally install the software.)
Mar 10, 2011 | Janome Memory Craft 10000
Can i buy and install my own memory upgrade? if so what are size and compatibility issues to avoid? thanks
Toshiba Satellite A135-S2356 has a maximum of 2GB which can be installed in the maximum 2 memory Slots in the memory compartment: 2 X 1GB PC2-4200 DDR2 SODIMM (200 pins) memory stick.
Note that in general, especially for older laptops, that you should not mix different size/brand of memory stick as the unit may even fail to boot or can behave erractically (reboots or system freezes).
Hope it helps.
Jul 14, 2010 | Toshiba Satellite A135-S2356 Notebook
It won't open at all
100% PC Compatible
Pentium 266 MHz or higher
32 MB RAM
50 MB free hard disk
8x Speed required
Microsoft compatible mouse
16-bit High Color 3D graphics
3D graphics card with 16 MB RAM
16-bit sound card Windows compatible
You can identify the hardware in your computer using the Directx Diagnostic tool:
  • Click on the Start button and choose Run
  • Type "dxdiag" without the quotes then press ok
If you receive a message related to checking for whql signatures, choose Yes.
On the first tab, system, you can find the following information pertinent to game requirements:
  • Operating System
  • Processor
  • Memory
On the display tab (Under 'Device' on the left):
  • Name - The name given to the card by the manufacturer, this will usually, but not always contain information on the chip type it uses
  • Manufacturer - The company who manufactured the card
  • Chip type - The information in this section needs to match the videocard type specified on the game's minimum specification found on the packaging
  • Approx total memory - The amount of video memory. With onboard videocards, this may be shared with the system memory
On the display tab (Under 'Driver' on the right):
  • Version - The software installed controlling the videocard
  • Date - This gives an indication of how up to date your videocard software is. A more current date is more beneficial in running games on a PC
On the sound tab:
  • Version - The software installed controlling the soundcard
  • Date - This gives an indication of how up to date your soundcard software is. A more current date is more beneficial in running games on a PC
hope this works for you, update drivers and see if you can run this on your own PC
Jan 10, 2009 | Global Star Software Age Of Sail 2:...
Installing memory
HI 1008 ,
It is very important to know which branded machine you have ; whether it's Dell , HP etc. I would also require to know the model number and whether you have a Desktop machine or a Notebook.
Anyways , here's a generic guide for your help...
http://www.helpwithpcs.com/upgrading/installing_dimm_memory_ram.htm
Goodluck :-)
Jun 05, 2008 | Acer Aspire™ T180 PC Desktop
PNY memory
Hi
Dell Dimension 5150 supports DDR2 400MHz (PC2-3200) and DDR2 533MHz (PC2-4300) unbuffered SDRAM Memory (DIMM). You may install a total of four DIMMs in capacities of 256MB, 512MB, or 1GB. The maximum memory supported is 4GB.
From your query, I think the obvious question is; What is specification of the PNY DIMM and/or does the PNY DIMM meet the requirements for Dimension 5150?
Check for memory configuration and installation procedures for Dimension 5150 - http://support.dell.com/support/edocs/systems/dim5150/en/sm/parts1.htm#wp1364711
The Chipset used on Dimension 5150 is Intel 945G Express. I am not aware of specific compatibility issues regarding the Intel 945G and PNY Memory modules. However, there may really be known issues that I am not aware of.
To proceed, ensure that the PNY Memory is compatible with Dimension 5150. If not, install compatible (memory type, speed, capacity) DIMMs.
Let me know if further help is needed.
Mike
Jun 05, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Which type of memory?
Not required to put the same memory. Any card will do as long as it fits right :)
May 13, 2008 | ASUS A8V-VM SE (MB-A8VVMSE) Motherboard
Asrock 775i65GV Motherboard Logo
62 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
