E001 continously show on my ir400
My machine not enter in service mode, what can i do to remove this error
  • Anonymous Feb 01, 2009
    I am not able to enter in service mode IR 400
  • 76 Answers
You can enter in service mode by doing this
press * 2 then 8 then * then go to function clear
Posted on Dec 08, 2008
Tip
How to resolve Cannon ir400 Error e004
<span>Hi,<br /><br />For error code E004-001 or E004-002<br /><br />Cause:<br />The SSR has a short circuit.<br />&bull; The SSR has an error.<br />&bull; The DC controller PCB has a fault.<br />The heater relay has an error.<br />&bull; The heater relay has an error.<br />&bull; The DC controller PCB has a fault.<br /><br />Description:<br />&bull; The fixing heater remains<br />on.<br />&bull; The fixing temperature has<br />increased abnormally.<br />The heater relay remains on.<br /><br />FIRST TRY TO CLEAR ERROR:<br />Resetting Errors<br />1. The following error codes cannot be reset by merely turning off and then on the main power.<br />They require resetting in service mode:<br />E000, E001, E002, E003, E004, E032, E717<br />1) Start service mode, and select COPIER&gt;FUNCTION&gt;CLEAR&gt;ERR.<br />2) Press the OK key.<br />3) Turn off and then on the main power.<br />2. Error codes other than the above may be reset by turning off and then on the main power.<br />n Detail Code<br />Some error codes offer detail codes, which may be checked in service mode:<br />COPIER&gt;DISPLAY&gt;ERR (3rd block from the right)<br /><br />SERVICE MODE: <br />1) Press the asterisk key ' * ' on the control panel.<br />2) Press '2' and '8' on the keypad at the same time.<br />3) Press the asterisk key ' * ' on the control panel.<br /><br /><br />If these doesnt helps, you need to call service to locate the fault, which is probably bad thermistor.<br /><br />Hope that helps!<br /></span>
on Feb 06, 2011 | Cannon i70 Printer
How to fix the Canon Image Class Printer 4750 error code e001-0000
Canon IR2270/IR2870/IR3570/IR4570/IR5070/IR5570/IR6070/IR6570
Enter the service mode (Press "Additional Function" key, Press "2" and "8" simultaneously, press "Additional Function" key again).
Go to COPIER----FUNCTIONS-----CLEAR----ERR. Here you can reset all error codes on by one.
for more details : www.mytechtime.com/2011/10/canon-error-e001e002-e003-e007.html
Jan 04, 2015 | Canon Office Equipment & Supplies
My canon C3170i shows error E000001-0010
Product : imageRUNNER 5070 / 5570 / 6570 Title : Fuser noise and intermittent E001 code Error
The upper fuser roller section makes a noise and intermittently error code E001 occurs Workaround : In this case, the UFR Shutter inside the upper fuser roller was installed reversed (180 degrees out of postion). Installing the UFR Shutter in the proper orientation corrected the problem. Note: the UFR shutter installed in the reversed position will cause a noise and block the Main Thermistor when the shutter should block the Sub Thermistor. In turn, the shutter will block the Sub Thermistor when the shutter should block the Main thermistor. This will cause improper temperature for the Upper Fuser roller and cause the error code. suggested to go in service mode and reset the error, and see if it will solve the problem. If the problem presist, a code will appear and that will be the one we should work on. So we did clear the error, and the machine is functioning.
Entering service mode: press Additional Function > press 2 & 8 at the same time > press Additional Function again Clearing the Error: press Copier > press Functions > press clear > press Err > press Ok. Restarting the Machine:Power off then On.
Oct 12, 2011 | Canon Office Equipment & Supplies
My Canon iR 2020 Photocopier machine is giving me message - system eror E001. How do I reset the machine for that eror message to cease?
to reset the error:
Enter the service mode:
press asterix key ( add. functions ) "*"
press 2
press 8
With right arrow, go to CLEAR, press OK, with arrow choose ERR and OK.
Turn off and on.
If these doesn't helps, you need to replace fixing heater.
Jun 13, 2011 | Office Equipment & Supplies
Respected sir my ir400 canon xerox mashin masage is switch main power off and on.e001 i have machin switch main power off and on but problem not a solve pls discription this probem and solve. thanking...
it is related to fing unit.
you can go in service mode by pressing (additional function +2 +8 + additional finction)
touch on copier then go in function after that touch on clear
Err -then press ok
dcon then press ok
rcon then press ok
if then after problem not solved you have to replace fixing unit thermistar
because it is related to fixing temperature.
Apr 12, 2011 | Office Equipment & Supplies
My Canon copier, Model IR 400s, Shows the error code : E 604. What is the problem ? How can I Solve it ?
My Canon copier, model IR 400s, Shows the error code : E604. What is the problem? How can I solve it ?
Sep 25, 2010 | Canon imageRUNNER 400S Copier
E001 error code on canon ir400
the fixing assy is faulty the halagon lamp has blown. this would have to be replaced and the error to be reset in service mode this requires a technician.
Sep 21, 2010 | Office Equipment & Supplies
E001 switch off the machine and on again
E001 is a fixing assy fault you have to clear the error in service mode after correcting the fault of course. I would try clearing the error code in service mode 1st. press *28* function tab clear tab error ok then restart copier
Sep 09, 2009 | Canon imageRUNNER 400S Copier
Canon iR2016
most times eoo1 can be reset in service mode if there is no damage to fixing unit. 1) Enter service mode.
Press the operation panel user mode key, 2 key, 8 key and user mode key in this order.
2) scroll to "clear" and press ok then scroll to "err" and press ok.
if that does not work you can go back into service mode as above and instead of scrolling to "err" scroll to "all" and press ok. power off then on. doing this will clear settings service techs might have made but i've done quite a few and had no probs
Mar 29, 2008 | Office Equipment & Supplies
188 people viewed this question
jasbo
jasbo
