Lyngby DK 8.12.2008 After I print a page the printer prints one page with prints one page with the message 12345X@PJL @PJL USTATUS TIMED 30. Rather annoying. Please advise regards Claus Alsted
SOURCE: Unable to print 30
the encoder strip is out of position. The strip is the foil which runs paralell to ph direction (and gives the ph the position info).
You have to open the printer and set it back into the ph carrier.
http://www.hstt.net/refill-faq/inside.html#Brother_mfc215c
(use google for translation)
Posted on Apr 04, 2008
SOURCE: Printer ERROR "Unable to Print 50! Unable to Print 30!" ???
WONT PRINT UNABLE TO PRINT , PAPER JAM
CLEANED PAPER JAM, CANT SEEM TO FIND ANY THING MORE TO DO TO IT
Posted on Oct 02, 2008
SOURCE: My printer (MFC-490-CW)print status is offline change online
If you want to make it online, than make sure it is on and connected to your computer, Once you are sure about this than
Go to control panel than Printers and Faxes
There You need to right click on printer and than Use printer online
IT will Put you printer back online.
Posted on Nov 10, 2009
SOURCE: Ghost printing
You have a worn image drum. The drum is the part of the printer that the print image is created on before it transfers the toner to the paper. This part is coated with a very thin layer of Teflon so the toner does not stick. When it gets worn the toner starts to stick and that produces the shadow or ghost image approximately 3 inches down the page because the diameter of the drum roller is 3 inches. You will need to get the part DR-350, Office Depot has them as well as many places on the internet.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
Posted on May 14, 2010
Testimonial: "I really appreciate the answer! I will go buy a new drum. Thanks again for your help! I appreciate it very much! "
SOURCE: My Brother 5240 laser printer has a red status
It may some paper jam inside your printer . open the front cover pull out the cartridge and look any jammed paper is there or not. if not the the problem may came from your toner drum.
Posted on Jul 18, 2010
Aug 31, 2011 | HP Photosmart C6280 Printer
Aug 17, 2008 | HP Photosmart C6180 All-In-One InkJet...
Press and hold the "left arrow" key.
Press the "Setup" key and release both keys.
Display should say "Enter Special Key Combo"
Press and release the "OK" button
1. Press and release the right arrow button until the display says "System Configuration Menu".
2. Press and release the "OK" button.
3. Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status",
4. Press and release the "OK" button.
5. Display should say "Hardware failure status: Clear. Press OK to clear".
6. Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
7. Press
and release the "CANCEL" button as many times as necessary, so that,
either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
8. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
9. Wait
30 seconds for the power to get discharged and then plug the power
cable into the wall outlet first and then into the back of the printer
10. Turn
the unit on. The printer may display message "USE POWER BUTTON TO
SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK.
11. If the printer has already initialized, then go to the next step. If not, the printer will start the "ONE TIME INK
INITIALIZATION PROCESS". Allow this process to complete and do not
interrupt. Once the initialization process is complete, the printer will
print out a Diagnostic Page.
12. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use.
NOTE: If the error is still there, or reoccurs replace the unit.
Aug 23, 2011 | HP Photosmart C6180 All-In-One InkJet...
Jul 06, 2011 | HP Photosmart C7180 All-In-One InkJet...
May 04, 2011 | Computers & Internet
A. - Press and Hold the "Print Photos" & "Red Eye Removal" buttons. Release both buttons. Display should say "Enter Special Key Combo" 1. Press and release the right arrow button until the display says "System Configuration Menu". (on C8100 use Touch Screen) 2. Press and release the "OK" button. 3. Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status", 4. Press and release the "OK" button. 5. Display should say "Hardware failure status: Clear. Press OK to clear". 6. Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue". 7. Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE. 8. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet. 9. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer 10. Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK. 11. If the printer has already initialized, then go to the next step. If not, the printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page. 12. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
B. - Press and release in sequence "Red Eye Removal", "Print Photos", "Red Eye Removal"
Oct 31, 2010 | HP - HP Photosmart 8250 printer
Jul 28, 2010 | Office Equipment & Supplies
Jun 03, 2010 | HP Photosmart C6280 Printer
Apr 21, 2010 | Office Equipment & Supplies
Aug 21, 2009 | HP Photosmart C6180 All-In-One InkJet...
Aug 10, 2014 | Brother MFC-7820N Printer
438 people viewed this question
DOES ANYONE KNOW HOW TO FIX THE PROBLEM WITH HAVING A BLACK MARGIN PRINT TO THE RIGHT SIDE OF THE PAPER? DON'T KNOW HOW TO RESET THE SETTING?
