Question about Motorola Mobility RAZR V3
Phone wont charge
Okay so heres da shimmy yo! I plug my charger in and da phones buttons flash and it wont charge...
  • 62 Answers
Check to see if a pin is bent or dust clogging it or something where the cable goes into your phone, you can also maybe have a bad charger.
Posted on Mar 14, 2007
ALL MY PHONE DOES IS FLASH LG
Try going into the stock recovery and then plugging in the charger. To get into the stock recovery: Pull battery. Hold power button for 30 sec to clear the phone. Hold home + volume down button, then power button (All at the same time) until you see your android recovery screen. Then plug phone into charger for 30min. Unplug charger, then select reboot system. Once rebooted finish charging.
If this doesn't work then you could have a defective battery, cable, or wall plug end.
Mar 23, 2014 | LG Cell Phones
My kobo wont turn on
Try this, it worked for me
Turn off phone
Remove battery
Wait 10 seconds
Plug in charger
Insert battery
Turn on phone
Dec 12, 2017 | iPhone Apps
MY PHONE WONT CHARGE UP AFTER 30 MINS OF CHARGE ITS STILL AT DA SAME CHARGE LEVEL IT WAS WEN U FIRST PLUG IT IN
my i766 phone does not take charge its not the battery nor charger its the phone how can i fix it
Mar 27, 2011 | Motorola Mobility i776 Cell Phone
My battery wont charge on my motorola rival i bought a new battery and it still wont charge.
If your phone does not seem to charge. It is as a result of either the charger or the charging port.
To test if it is the charger;
Try to use a tested okay charger on your phone.
Try your charger on another phone to see if it would charge the phone.
If it does not work,then it is the charger.
All you have to do is to replace the charger.
Test if it is the charging port;
Try to use a tested okay charger on your phone,
If it does not charge the phone,
Then it is the charging port that has a fault.
To fix the charging port;
  1. get the appropriate screwdriver,
  2. remove the back cover, the battery and the sim,
  3. Then you will remove the stickers, you will find some screws at the angles of the phone, unscrew them,
  4. Run an object like a credit card around the line across the phone and apply a little force to separate the stainless part of the phone,
  5. You will have access to the panel of the phone,
  6. Try to locate the charging port of the phone,
  7. Disconnect it and replace it with the new you got for it,
  8. Reverse the process to reassemble the phone.
Take care
Jun 21, 2010 | Cell Phones
Every time i plug in my charger my phone wont charge and it turns on and turn off.........
Hi! kindly try to drain the power charges of the phone by disconnecting the battery from the phone unit. Connect back battery and make sure that the charger is connected properly on the charging port of the phone. Please make sure you are connecting to a stable power outlet.
Jun 09, 2010 | Computers & Internet
Sir,i want mot e398 flashing software(ufsx sarasoft)
Try to flashing using P2KTools http://www.megaupload.com/?d=AYFRDFPZ , make sure your phone is backed up and the battery is fully charged before flashing, press power, * and # key at the same time to enter boot loader mode,plug your USB cable in,start P2KTools click phone icon and choose flash mode and then click flash file button and browse firmware file, click flash phone to start flashing,you can find firmware here: http://www.e398mod.com/content/category/7/13/30/
note: if your phone won't charging try to modif your USB cable as charger while transfering data,find out here: http://www.e398mod.com/content/view/111/25/
Mar 30, 2009 | Motorola Mobility E398 Cellular Phone
Correct procedure for charging battery
read da manual which cms wid da battery on hw lng 2 charge it wen newly purchased. charge wen battery is cmpltly drained.smtimz it may refuse 2 chrg so get a universal charger nd alwz use it 2 crg
Sep 06, 2007 | LG enV VX9900 Cellular Phone
Motorola Mobility RAZR V3 Logo
178 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
