Question about SanDisk Sansa e250 MP3 Player
HELP!!!!!!!!! my sansa wont bring up the menu insted it keeps shwing its name then reseting it self ppplllzz help me
  • eric wade Feb 25, 2007
    so wat do i do
  • 3 Answers
Same here and taking out the batery is same like pushing the off button
Posted on Apr 25, 2007
OMG SAMEEE! if i take out the battery it wont even turn on.. then i realised that it wasnt pushed in properly...
Posted on Feb 26, 2007
I'm having the same exact problem, don't take out the battery bacause if you do, well mine did, it won't turn on at all
Posted on Feb 25, 2007
SOURCE:
My sansa san disk mp3 player wont turn off when not connected to pc. when it is connected it keeps going from saying connected, disconnected and writing all in seconds. when it is connected to the pc it...
First lets try resetting your player, to reset the player: 1. Press and hold the Power/Menu button for approximately 20 seconds. 2. Release the Power/Menu button. 3. Press the Power/Menu button again to turn on the player. NOTE: Resetting will turn the player off while it is frozen.
Next; if that does not help click on this link and down load the Updater program and update the players firmware.
http://kb.sandisk.com/app/answers/detail/a_id/156
Oct 16, 2010 | SanDisk Sansa e260 MP3 Player
It wont turn on
First you mat try to reset the player see this tip posted here for this self help - Sansa Mp3 player frozen? How to reset and...
If that does not help you, you may need to do a firmware update, go to the SanDisk site -- >>>
http://kb.sandisk.com/app/answers/detail/a_id/278 <<<---copy this address into a new window or tab.
Apr 26, 2010 | SanDisk Sansa Fuze MP3 Player
When i turn on my sansa its said sandisk , then raspody sansa then it shut down by itsself , the turn on by its self and its repeats over and over again.
Reset All
NOTE: THIS IS AN ADVANCED OPERATION AND RESTORES ALL SETTINGS
TO THE FACTORY DEFAULTS. NORMAL USERS ARE NOT RECOMMENDED
TO PERFORM THIS OPERATION!
If your device freezes up press the Menu button and hold for 15 seconds.
This is like a power down of the device. Once you perform the reset, the adjustments you made during last operation
will be gone.....IF that doesn't work try to recover...download the update software and install then lock your sansa hold in the rec key on the left at the same time push the menu/power button this will take you to recovery mode then connect to the computer Star the update software if it doesn't start automatic goto /start /all programs /Sandisk/sansa updater/ sansa updater and start it up manually... follow instructions on the updater and the sansa hope this works.... Please rate
Jun 01, 2009 | SanDisk Sansa e250 MP3 Player
My mp3 frozen on the welcome screen and restart and freeze again
First reset the Sansa e260. The way you do this is you hold down the power (menu) button for 15-25 seconds. This usually solves it.
Good Luck,
Fixer Guy
Feb 02, 2009 | SanDisk Sansa e260 MP3 Player
Sansa e250 Menu won't show!!!! please help!!
http://www.sansa.com/support/sansa_e200/faqs
STEP 1 – Reset the device
  1. Press the Power button and hold it for approximately 10 seconds.
  2. Release the Power button once the device is powered down.
  3. Turn the device back on.
STEP 2 – Download and Install the Sansa Firmware Updater
I hope that helps. If not, please post a comment with an update to your problem.
Jan 01, 2009 | SanDisk Sansa e250 MP3 Player
SANSA E200 NOT SHOWING THE MENU SCREEN
Try to format the SANSA E200.
You can do this by simply holding down the Power/Menu button for about 15 seconds. After the reset, any changes you have made to the e200 during its last use will be lost.
PLEASE RESET USING THE RESET PIN PRESENT IN THE SIDE.
AND FORMAT THE PLAYER . if this dosen't work your player is faulty
Nov 21, 2008 | Computers & Internet
Reset
Format your Sansa through Windows Media Player (WMP). To do, connect Sansa, open WMP, and click the SYNC tab. On the newer version of WMP (and I think the older versions too), there is a little drop menu arrow right below SYNC tab. Click it and you will see your MP3 player on drop menu. Bring pointy thing to it WITHOUT clicking and another sub menu will pop up with option to format. Formatting the player will lose all your data but should reset it.
Apr 05, 2008 | SanDisk Sansa m230 MP3 Player
NEED HELP RIGHT AWAY
You should reformat your disk so that the error goes away, in the menu please find the format the disk, or connect the stuff to the computer then format it using the computer. (all files will be deleted during formatting)
If this not work you can replace the disk of your stuff.
may this help! regards, melnavz
Feb 06, 2008 | SanDisk Sansa e250 MP3 Player
Plzzz help=i formatted by accident now it wont...
i guess that you have to reformat it into FAT32 file system using the disk manager in windows (if you're using windows). select my computer using the right key of your mouse, select MANAGEMENT. then select the sub-menu DISK MANAGER. you'll see two logically connected partitions (Sansa_e250 & another partition that is the system partition). try formating the Sansa_e250 partition into FAT32 insted of the default FAT file system!! that helped me after a bug (sansa didn't let me delete songs from is root/music) hope that helps.. p.s. that actually worked for Sansa_c240 p.s.2 if you're a linux user try fdisk (login as root)
Mar 14, 2007 | SanDisk Sansa e250 MP3 Player
Refreshing Database
I love you!! thanks this helped me :)
Jan 28, 2007 | SanDisk Sansa e270 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
22 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Gyula Lacz
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
