Question about Brother IntelliFax-2820 Laser Fax
Fax Machine keeps jamming
Our fax keeps jamming about every other time it receives a fax. Is there a way to stop that from happening?
    Problem Solver:
  • 18 Answers
Depending on where the jam is, it could be the rollers at the exit. I have found that these rollers become sticky and cause intermitted jams. I suggest using methylated spirits to clean the black rollers where the paper would come out. You might have a few problems getting to them from the front so I would open up the back and see if you can get to them from there and clean the little grey rollers while you are there wont do any harm. :)
Careful you don't pop the black rollers out of position or you will get constant jams.
:) Good Luck
Posted on Dec 09, 2008
The fax is received by the other party but we receive an error code J72. There is no jam
Dear
If you are sending the fax using ADF, there may be the document jam, Open the ADF cover check the path for any foreign objects.
Also you can send from platen glass without document jam.
Also this may happen to the other end fax machine, better you do a test copy from ADF and Platen glass. and confirm your fax machine is ok.
Thanks.
Mar 05, 2015 | Panasonic PanaFax UF-8000 Laser Fax
Why is my fax machine jamming all the time
Dear
If paper jam always,check the thermal ribbon correctly installed (the ink coating face upward and should above the print head)
If document jam always, check the ADF roller (white roller clean it)
Thanks.
Feb 26, 2015 | Panasonic KX FP215 - Fax / copier - B/W -...
Panasonic kx-ft77 paper jammed and fax im memory
I have a problem with the fax machine in question is panasonic kx ft77 . When receiving a fax error expel warm up and stop receiving the document. Or does anyone know what the problem is and how to fix it ? Thanks in advance
Aug 16, 2013 | Panasonic KX-FHD331 Plain Paper Thermal...
I AM RECEIVING PAPER JAM AT MY BROTHERS INTELLIFAX-2820 THERE IS NO PAPER JAM AT ALL( I CHECKED IT COMPLETELY). AND FAX MACHINE KEEPS RUNING UNTIL I PUSH THE STOP KEY AND GIVES THE PAPER JAM MESSAGE.
Where is the paper jam?Jou can take the cartridge out and look if the sensor actuator is in it's plase.if you open the back door look for small pease of paper that might stay behind or a paper that did not go through otherwise take the paper tray out and look in the botom of the machine for sensors or peases of paper
Jun 13, 2011 | Brother IntelliFax-2820 Laser Fax
I need assistance with fax error codes # 322 and # 358. What do they mean?
Error code 322- There was a communication error with the receiving fax machine due to poor telephone line conditions.
Solution
Set the receiving machine to receive at a slower transmission speed
If the session fails after sending several pages of a large document, resend the document as several smaller documents.
Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
Error code 358--
The remote user pressed the Stop key,
The remote machine encountered a system problem such as no paper or a paper jam.
Try
Configure the local fax machine to use a slower reception speed.
Disable ECM mode on your machine.
Try sending a fax to another location.
Mar 03, 2010 | HP Officejet Pro L7680 All-In-One Printer
Can't fax or copy on brother mfc3240c machine
Sounds like you may have a small obstruction in the scanner feed. This would inhibit making copies and sending faxes. Lift this section up slightly to inspect for small pieces of paper or dust. Blowing it out with compressed air would also be a good idea.
Aug 20, 2009 | Office Equipment & Supplies
Panasonic UF-490 Fax machine is sending more than one fax
You might have a job stuck in memory. Message window should say 00%. Try this press Function key press 7 key press monitor key slowly 4 times press * key press 6 key scroll down to ALL JOB CLEAR press SET wait for reboot Good Luck
Jun 05, 2009 | Panasonic Panafax UF-490 Plain Paper Laser...
Clearing an error
well, one of two things have happened, 1. you haven't removed all of the jammed paper, maybe you left a small piece of a piece of paper or you may bent or broken your paper jam sensor. go through the paper path very carefully and check both things.
mikey
Mar 14, 2008 | Sharp UX-B20 Plain Paper Inkjet Fax
Paper tray pickup failure
If it's not working all the time then the lifting mechanism is bad.
if it is and jams then the tire is slipping and causing the jam.
clean tire with alcohol and try is it really smooth or does it feel rough? if smooth then replace
Dec 03, 2007 | Canon CFX-L4000 Plain Paper Laser Fax
Brother IntelliFax-2820 Laser Fax Logo
426 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
