Question about HP Photosmart C7180 All-In-One InkJet Printer
Scan cannot be performed
Error message
"The scan cannot be performed because another program or computer is using the networked device."
I have tried disabling security and no other programmes ae running.I have also tried reinstalling the software,
  • micheleb24 Apr 07, 2009
    i am still getting the sam error message. i have an hp 6150 AIO
    This is what the hosts file currently has
    127.0.0.1 localhost
    192.168.1.101 HP9A1E72
    HP9A1E72 is the host name of the printer
I also had the same problem with HP Officejet 6310 and after trying all the solutions that I could find on the web, I was almost giving up. Then I found this on HP's IT Resource Center website (author J.Eqbal) and tried it and finally it scanned without the error message.
This error happens only in Network connections.
Get the Ip address of the Printer and open the EWS page by typing i.e http://192.168.1.102...where 192.168.x.x.x is the IP address of the Printer.
On the EWS page click on Network and get the host name and copy it.
go to the following location C:\Windows\System32\drivers\etc...inside etc you will find the host file open it using notepad.
Underneath 127.0.0.1 local host
there might be the Ip address and host name ..which will be different from the current host name...change the Ip address and host name ..save the file.
Try to scan...it will definitely work.
Posted on Mar 19, 2009
  • John Helsley Feb 23, 2012
    This worked for me, when everything else failed. Only problem (small) was having to remove "Read Only" from the properties of the "Hosts" file before saving.
  • marylindacr Oct 21, 2014
    followed instructions got to host on my note pad. It don't have any numbers listed at all in the local host. When I type in the ip address of my printer it won't accept it.?
As @teswede mentioned above, try this. It worked when everything else failed, or didn't worked consistantly.
There is something you need to do first, before this will work.
You need to go into your router and reserve one specific
IP address for your wireless printer. Then turn off your printer and restart it.
your printer should now be using the new IP address you reserved for it.
After doing the above, you should now know the printer's IP address and host name.
((NOTE: Just for common knowledge, you can go into your printer's EWS page to get this
by typing http://192.168.x.x ...where 192.168.x.x is the IP address of the
Printer.
On the EWS page click on Network and get the host name and copy it.))
Now, go to the following location C:\Windows\System32\drivers\etc
Inside \etc you will find the "hosts" file. Click on properties and make sure that
the file does not have "Read Only" set.
Open "hosts" using notepad.
Underneath 127.0.0.1 local host,
insert 192.168.1.254 HP97D4C3
(where of course this would be your printer's IP address and hosts name)
Reboot
Posted on Feb 23, 2012
    got into hosts in word pad. there is no number period with the example (127.0.0.1) it just says local host and will not except what I enter
I had the same problem - could not scan from the C7280 front panel to my computer - and finally fixed it by changing my WIndows Firewall settings in the Control Panel. I used Advanced Settings and under Inbound Rules I added added a New Rule. On the Scope tab look for the Remote IP address and add the address of the printer (you can get this by printing a network settings page from the Setup menu on the printer). Kind of complicated but now it works fine for me on Windows 7 Professional 64 Bit. Good luck!
Posted on Apr 13, 2010
    Problem Solver:
  • 19 Answers
    The above website you suggest only rarely works for most people. It might work once, but the problem will just come back.
"Connection with Computer Failed" When I Try to Scan
If the primitive (as you call it) Windows Scan program is working then there is no problem with the machine. It can connect to the computer.
I suspect that the other (non primitive) scanning software is not configured correctly. It may be using a wrong driver. You may have installed some other device that is able to scan (such as a program that capture screens from calculators) and it has been set as default driver. Check the configuration of your scanning software.
Jan 23, 2014 | Lexmark OfficeEdge Pro5500 4-in-1 Inkjet...
HP Photosmart c7250. WhenI try to scan to computer I get a message on the Photosmart screen - "no scan option" refer to device documentation to troubleshoot
have you tried to reinstall the software, first uninstall it from add or remove programs and then resintall it from the cd or we can get them from the internet.
Jul 15, 2008 | Computers & Internet
I have a HP Deskjet 2480 and I just just installed it. When I try to scan I get the following error message: "The scan cannot be performed because another program or computer is using the networked...
This problem is related to Firewall settings. If I guess right, you've installed the Outpost Firewall with the Hp Software. Look at the right-side of the taskbar, you'll see a light-blue icon of Outpost Firewall. Right-click the icon and select "Disable". Now, open "My Computer" > double-click C:\ drive > Program Files > Agnitum > Outpost Firewall > locate and open "machine.ini" > Notepad will open up, now locate the line in the notepad text "EnableContentHandler=True", now replace the "True" with "False", and save the file.
Now re-enable the Outpost Firewall from the Taskbar. You'll be able to scan now.
Good luck.
Thanks for using FixYa.
Aug 15, 2010 | HP Office Equipment & Supplies
Scanner not working
Hi Jkey !
As per the information you have provided, I understand that you are receiving an error "No scan option refer to the documentation" on the printer, when you try to print from the front panel of the printer (I mean from the printer's side).
However, plz provide me the proper error message so that I can assist you in the best possible way. If you are unable to scan from the printer's side, then try to scan from the computer and check if it is working or not. It should work when you try to scan from the computer, if not there may be a communication issue between the two devices.
To check the communication perform the below steps:
IF the printer is connected via USB cable, then perform below steps:
Useful scripts For Windows XP:
To isolate the issue I suggest you to try scanning from the Windows Image acquisition(WIA) wizard on the computer.
Follow the below steps to Scan using WIA
1.Verify that the all-in-one product power is turned on and the printer cable is properly connected.
2.Click Start then Click All Programs then Click Accessories then Click Scanner and Camera Wizard.
3.Follow the Scanner and Camera Wizard instructions to scan images to the computer.
If you are able to scan fine using the above steps, please write back to me along with the exact error message.
With Regards
Mike.
Jun 27, 2009 | HP Photosmart 2575 All-In-One Printer,...
I have a hp 6310v on a wireless network. It
refer to hp.com then on the search box type: no scan options. there is a step by step methods there that you can perform.
Mar 05, 2009 | HP Officejet 6310 All-In-One InkJet...
I have a HP photosmart C7100 All-in-One.I can print photos & print "e"mails without any problems but I can't scan into my computor.One of the error messages is(The scan cannot be performed...
its probably due to your software firewall. https://support.hp.com/us-en/document/c01806655 the link here is for the same error and shows steps to diagnose the issue and to try the scanner webpage. These days any network attached device(like your scanner) has an IP address and will present a webpage with Menus to you if you type in the IP address into a web browser. you just need to know the IP of the scanner/printer. you find that out by printing its network status sheet. you do that by holding in buttons and turning the printer on whilst holding in the right buttons until a sheet is printed. anyway have a look at the link. and check/change your firewall settings to unblock the scanner application.
Dec 13, 2017 | Office Equipment & Supplies
I have a c4830 and i am unable to get it to scan to my laptop i am getting an error message which reads ( the scan cannot be performed because another program or computer is using the networked HP imaging...
Your firewall is blocking the printer from doing it scanning. Try to turn off your firewall or try to add an exceptions in your firewall for the printer software
Nov 28, 2008 | HP Office Equipment & Supplies
Scanning error
I'm not sure if this is the cause every time it happens, but if there are no other programs running, and it's still coming back with the same error, try deleting the printer *NOT UNINSTALLING THE SOFTWARE* and then adding it again.
Generally if the printer stalls while performing some task, it continues to think that it's still doing whatever it was trying to do. Deleting it and adding it again should get rid of whatever program was using it.
Jul 05, 2008 | HP PSC 1510 All-In-One InkJet Printer
Not networked properly
Solution To resolve the issue, follow the steps in the solutions below in the order presented. Solution one: Scan from the EWS (Embedded Web Server) Verify that the product can scan and is connected to your network by scanning from the embedded Web server (EWS) on the product. Use the following steps to scan from the EWS:
  1. Print a Network Configuration Page from the product. NOTE: See the product documentation, User Guide, or online resources for information on how to print the Network Configuration Page.
  2. Locate the IP address.
    • Check in the Wired section if the product is connected with an Ethernet cable
    • Check in the Wireless section if the product is connected using a wireless network connection.
  3. Make a note of the IP address found in the appropriate section (wired or wireless); for example, 192.168.1.1.
  4. Open the Web browser.
  5. Type the IP address into the address bar of the Web browser (such as http://192.168.1.1) . Then press Enter . The EWS for the product opens. If it does not open, STOP and click here to check the network connection between the computer and the product (c00047176) (in English).
  6. If the EWS page opened, find the Scan on option.
  7. Click Scan to perform a scanning operation.
  8. If you can scan from the EWS and not from the HP Director/Solution Center or from the product front panel, then continue to Solution two.
Solution two: Check the personal firewall settings When the firewall program is re-enabled after installing the All-in-One software over the network, it may block HP programs or ports required for scanning. If you see pop-up screens asking you to permit access to the network when you try to scan, you should permit access. NOTE: Firewall programs may also block the scanning operation even if they were enabled while installing the All-in-One software. Firewall programs do not always provide messages when blocking access. Follow Step one to allow access to HP program files and ports needed for scanning. Step one: Add programs to the firewall exception list
  1. Open the firewall program.
  2. Add the following files to the Highly Trusted programs list:
    • hpqkygrp.exe , located in the C:\program files\HP\digital imaging\bin directory.
    • hpqscnvw.exe , located in the C:\program files\HP\digital imaging\bin directory.
    • hpqste08.exe , located in the C:\program files\HP\digital imaging\bin directory.
    • hpzipm12.exe , located in the C:\windows\system32 directory.
    • hpzinw12.exe , located in the C:\windows\system32 directory.
    • hpqtra08.exe , located in the C:\program files\HP\digital imaging\bin directory.
    • hpqthb08.exe , located in the C:\program files\HP\digital imaging\bin directory.
  3. If these files are already added, check whether full access has been granted to them.
  4. Open the following ports on the firewall utility by following the instructions provided by the manufacturer:
    • UDP ports: 161, 427 and 137
    • TCP ports: 9220, 9500 and 9290
Step two: Restart devices on the network After making the changes to your firewall application, turn off the All-in-One, the computer you made the firewall changes on, and your router, and then turn on these devices in the following order:
  1. Router
  2. HP All-in-One device
  3. Computer
Apr 20, 2008 | HP Photosmart C5180 All-In-One InkJet...
Fax device I/O error
installed samsung scx-4521f multi function printer. can't fax from smarThru program. get message : Fax device I/O error
Jan 11, 2008 | Samsung CLX 3160fn All-In-One Printer
HP Photosmart C7180 All-In-One InkJet Printer Logo
4,478 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
