Hitachi monitor PTV 51m200 no video, no audio
I have a 51m200 hitachi tv and have no video, no audio. I have on screen display and can switch from one input to another, magic focus works fine as do all of the customer controls, but no matter what input I go into I have no pix, and no audio
  • 121 Answers
it sounds like your blue convergence ic is getting weak you need to replace the ic's STK392-110 and you should replace both because when 1 is bad the other will go real soon. They are inexspensive at the sight I posted and you will also get free tech online support if you purchase them there.
Posted on Apr 13, 2008
  • 8617 Answers
SOURCE: Magic Focus does not fix the blue 57UWX20B Hitachi
you need to replace the convergence ICs they are STK392-110 you can get replacements at the following link and they send instalation instructions with pictures so you can do the repair yourself. You need to replace both IC they are both STK392-110 they are located on the large heat sink on the far right side of your Tvs' chassis Heres the link for replacement ICs
Posted on May 20, 2008
  • 203 Answers
SOURCE: hitachi tv magic focus does not work
Your problem is the convergence circuit. This is very common in CRT projection sets like yours. There are a couple of IC's that need to be changed and possibly some resistors. A good repair shop will run you $400-$500 to do the repair.
Posted on Oct 28, 2008
  • 5138 Answers
SOURCE: hitachi 61udx10b
Replace Both of your STK ICs they are your convergence ics they are big black ICs will have Part# on them for example STK392-110, if they are 110s use 180s, if 020s use 040s other wise replace with exact same number. To get Parts call Electronix 1-800-223-3205
Posted on Dec 30, 2008
SOURCE: magic focus 4 error
Error 4 is listed as an overflow in the convergence section.
To fix:
1. Check the placement of the sensor
2. perform an Adjustment check of th H/V size & centering
3. Conv. amp. gain check, check these resistors:
R041, part # 0790024R, RES.CHIP 1/16W 100 OHM
R046, part # AQ00164R, RES.CHIP 1/16W 75 OHM TAPE
R050, part # 0790059R, RES.CHIP 1/16W 47K OHM
R058, part # 0790054R, RES.CHIP 1/16W 18K OHM
R062, part # 0790047R, RES.CHIP 1/16W 5.6K OHM
Posted on May 15, 2010
We have to push the on button on our TV from 20-100 times to get it to turn on. Have changed batteries and restarted to no avail.
"He said our TV has a problem". Brilliant! To be more specific, he could have suggested switch failure or a failing power supply.
Apr 26, 2017 | Samsung Televison & Video
Every time we play a DVD it says VIDEO in to upper right hand corner and I don't know how to make it go away.
"Video" is displayed on the monitor(TV) usually because you have the DVD player plugged in by a single RCA cable (three with audio). TV remote or DVD player should have a "display" button. Try tapping that to clear. Or, go through the "Input" keys on TV remote and select the video source vs. letting it auto detect. Hope this helps.
Jun 29, 2010 | Hitachi CMT-2195 21" TV
Don't have manuel and don't know how to Set up Hitachi VCR
Such a simple job. First check if the cables are connecred properly
1. Audio OUT from VCR to AUDIO IN of TV.
2. Video OUT from VCR to VIDEO IN of TV
Then switch the TV ON. Select 'Video' on the TV/Video
selection button on the TV's remote control.
Your TV screen will show a display like 'Video' or 'AV'
Play a cassette and you should be able to see the picture...
Happy Viewing.
Apr 01, 2009 | Televison & Video
Connecting PC to television
Hi and welcome to FixYa,
Initially, try the lowest possible Screen Resolution in the PC's Display Properties. You could also try lowering the Screen refresh Rates. This is especially so if the PC connects to the TV using composite (yellow) video out or S-Video. In some video cards/settings, it may be necessary to enable twin/dual view in the display properties.
Good luck and Thank you for using FixYa. Happy New Year.
Jan 01, 2009 | Hitachi SuperScan Elite 802 21" CRT...
Use bigscreen tv for computer moniter
You can order from the dealer the VGA cable adabtor to go between the computer and the TV. Make sure that the display card in the computer is complient to drive the TV monitor. You will have to look in the specs for both to see if this is so.
You will find that the pictures on a TV set will be very poor compared to a dedicated computer monitor. TV sets are really optimized for TV videos and not for computer applications.
Jerry G.
Apr 20, 2008 | Hitachi 57F500 57" Rear Projection...
No Display
for the HD15 connection you need to set your TV to PC mode
the only thing I can think that you may be doing wrong is that you need to "ACTIVATE" the external outputs on the laptop,as they are not on by default.
To switch video output mode  LCD / CRT (monitor/PC mode) /TV mode plus some dual modes LCD + CRT / LCD + TV
I have found that the overlays used for video playback do not work in the dual modes,  (and I have found that CRT monitor mode is best for connecting to a large TV)
so switch your TV to PC input,  connect your HD15 cable and SWITCH output mode on your laptop (usually Fn F5) press until you get an output,
you will also need to connect audio, so get a phono -> 3.5mm jack plug and plug that in also, and you are ready to rock and roll
Oct 11, 2007 | Hitachi CMP205SXU 25 in. Plasma Television
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
