Envision 19" Widescreen Flat-Panel TFT-LCD Monitor
Problem for Envision 19" Widescreen Flat-Panel TFT-LCD Monitor
The blue light is blinking and the monitor is black
By william_stid on Dec 08, 2008
the on light is blinking but the monitor will stays black
Same Problem
Jan 02, 2009
-   I have the same problem and I just keep turning the off/on switch off and on until the screen finally comes on. I don't know what else to do.♠♠ -   jwalkbu
Best Solution
posted on Apr 22, 2009
Very Helpful)
ginko
Rank: Guru  Computer Hardware  Expert
Rating: 89%, 5267 votes
The monitor is probably on protection.
To start unplug monitor from power and from computer and test computer with different monitor to find out if it is monitor or computer fault.
If it is computer fault and no video signal , then test:
  • Video cable.
  • Video adapter on PC (sometimes integrated on motherboard)
  • Motherboard.
If it is monitor fault , then the monitor is on protection.
When on protection you keep having a flashing led on front of the monitor , and monitor turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occurr are a blown capacitor on power board, faulty inverter board, faulty input board, or a fault on LCD Digital Controller board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing statebecause of the video cable.
Try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on May 22, 2009
Not Rated)
stoneheaded
Rank: Guru
Rating: 90%, 627 votes
You can call these telephone numbers for customer support. Customer Service : 1-888-838-6388. Parts : 1-800-343-5777. Their customer support website is www.envisiondisplay.com. You are having a problem with the main control board malfunctioning. Go to the website or call them for help with your problem. I hope this information helps you with your problem.
Was this helpful?
Yes
No
Popular Solutions for Envision 19" Widescreen
Questions and Unsolved Problems for Envision 19" Widescreen
Do you recommend Envision 19" Widescreen Flat-Panel TFT-LCD Monitor?
Answer
Answer
I have a MAG 700p, it comes on fine then goes black.....after a minute or so....help!
Answer
have a soyo monito dylm2c86 and it isn't working properly with windows 7
Answer
attempting to connect2026w monitor to a Toshiba laptop as a second monitor, It's now showing lots of... (More)
Answer
Need to purcahse a power supply part# 6693006610 where can one be purchased
Describe your Monitors problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Monitor Experts
Top Computer & Laptop Repairmen
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
