Changing power supplies.
I changed out an m863g motherboard. The power comes on and shuts down in seconds. Is it beacause the 300w power supply initially used in this system has been changed to a 500w? Or does that really matter?
  • Anonymous Dec 09, 2008
    I have the same problem with 3 power supplies 1 300w, 1 was 400w and
    1was 500w. It did not matter the system still shuts down after 5
    seconds.
    Any sollution?
  • maciej_lis Dec 16, 2008
    My problem is almost the same but i think i caused it my self. I went into the bios and changed an option in PC Health line. There was an option saying that bios/motherboard can monitor CPUfan speed in case of any failure- I enabled it. I saved changes and restarted my PC - from that moment my PC starts for a few seconds during which bios gives 3 identical signals and the PC shuts down (power off).
    Hardware: Maiboard - Spacewalker AK12a, Bios - Phoenix. I tried to reset Bios but it doesn't change a anything. Please help me!!! :)
  • 107 Answers
Yes and no I do not now the min power for that one but I would say it would be a good ideal one way or another cause 300w will not cut it for when you hook up you cd/hard drive/motherboard but I can not say that it is something else that is causing the issue so what would be best is for you test it with another power supple and if it does not work we will take it form there
Posted on Dec 08, 2008
OC failure after changing power supply
oc failure computer.
oc failure boot.
oc failure error.
oc failure bios.
oc pc failure.
oc power failure.
your description don't have so many details.
GOOGLE IT.
Jun 11, 2013 | Gigabyte Computers & Internet
I WOULD LIKE TO KNOW IF I CAN USE A 300W POWER SUPPLY UNIT FOR THIS ASUS K8V*MX
The wattage rating is the maximum power draw that the power supply can supply. If the system only requires 200W, only 200W will be delivered by the power supply. It is recommended that the power supply rating be higher than what you expect to draw so that you never draw more than 80% of the total capacity. In other words, if you expect to draw 240W total, use a 300W power supply.
So, yes it is fine.
Dan
Jan 13, 2010 | ASUS K8V-MX Motherboard
My Bondi Blue Imac suddenly quit running the other day while I was typing a paper. It made a sizzling static type of sound, and then shut down. I cannot get it to stay on more than 40 seconds and then it...
It is most likely your power supply. You can try buying one and changing it out. But it sounds like its the power supply, and don't keep trying to turn it on, if the supply comes through weak or bad-sine it can harm the motherboard.
Dec 17, 2009 | Apple iMac M6709LL/B Desktop
Hello !I m trying to repair atx psu-300watt.In the beginning i changed the filter capacitors in first circle,one diod fr 107 and a resistor.Now i only have voltage on lilac cable(standby) 7volts.Would you...
These switching power supplies MUST HAVE A LOAD on them to work properly.
Often, without load, they spike up to overvoltage and OFTEN they will immediately shut themselves down.
If you found a shorted diode, likely there may have been a second one that is defective as well. A bad diode will often unbalance the regulation of the unit.
Oct 17, 2009 | E-Machines REXUS SPE-300 ATX 300W P4 Power...
Motherboard shuts off
You may want to try using another power supply rated at 300W plus. Also make sure your RAM is unbuffered and non-ECC. To set the switch correctly, you need to goto look at the exact model number of the CPU. Because CPU with similar marketing name could have different front side bus speed.
One more thing to look for, make sure there is no metal standoff sticking out of the bottom of the case shorting out the mother board. But my first guess is the power supply.
Sep 02, 2009 | ASUS A7V400-MX Motherboard
HARD DRIVE LIGHT COMES ON AT START BUT WILL NOT INITIALIZE THE MONITOR . THEN AFTER A MINUTE OR SO THE HARD DRIVE SHUTS OFF . THINK THIS A POWER SUPPLY PROBLEM . AFTER THE INITIAL SHUTDOWN WHEN RESTARTING...
It is a little hard to tell, I dont think its a psu problem.
I have seen something similar when a cpu/motherboard went faulty. (Older machine could not get either cpu or motherboard to test)
Also worth checking your ram is seated correctly.
Jul 01, 2009 | Gateway GT5428 PC Desktop
ASUS P5GL-MX performance
Install new power system!
Thanks,]
Melcom Smit
Oct 04, 2008 | Computers & Internet
From 300w psu i change it to 450w will that be ok?
Ivy My field is in home appliances. I do fix my own computers and have replaced a few power supplys. The only thing I could say to you is go back and recheck your connections. They should only fit on the bord one way. The other connections for the hard drive and cd drives and so on really dont matter. so good luck and I think if you recheck it all the computer will work.
Jul 11, 2007 | Jackson 25 in. TempStar HH Free-standing...
Computers & Internet Logo
329 people viewed this question
David Payne
David Payne
