Question about SanDisk Sansa e250 MP3 Player
My Sandisk is mest up Help Please
One day i was listening my sansa and the battery when low so i wanted to charge the battery but when i try to connect to the computer it only froze into the sandisk sing and it dose not connect into the computer. Also when i try to turn it on it freezes in the sandisk sing .But when i press the menu or record button it lets me in the menu but the menu dosnt look right it dose not show how much the power of the battery. and when i try to change the USB mode it freezes. When i try to turn off by pressing the menu sing and it freezes on the only way to turn it off is to take out the battery or hold the menu sign. I have try everything even removing the battery and putting it over and over.and i try reseting the sansa but at the end it dose the same thing Please help me
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 26, 2008
SOURCE:
My sansa Express won't charge or connect to my computer!
try leaving it in the computer charging over night... if that doesnt work, call custumer care!
Jul 22, 2009 | SanDisk Sansa MP3 Player
Refresh Database???
Try removing the battery and then it should work when you reinstall the battery. I've had this happen a couple of times.
Jan 20, 2009 | SanDisk Sansa e250 MP3 Player
Battery can't charge
You all need to get the latest firmware upgrade from Sansa's website.
Apr 13, 2008 | SanDisk Sansa Clip MP3 Player
Sansa e250 PLEASE HELP!
The battery has come disconnected from the charging contacts in the back.
Remove the 4 screws, remove the battery from the back and re-insert it.
Best of Luck.
Oct 26, 2007 | SanDisk Sansa e250 MP3 Player
Sansa e250 2Gb - No Charge - My PC no recognize my mp3
if you plug it in to the computer mabe the drive cant charge it in some computers some drives dont charge the mp3s it happened to me but try to connect it to different arias and if that doesnt work buy the wall charger hope it helps.
Jul 03, 2007 | SanDisk Sansa e250 MP3 Player
Help me
Hello : Try to charge it from other PC, some USB PC ports have not enought USB current to charge the battery fully.
Apr 18, 2007 | SanDisk Sansa e250 MP3 Player
It wont turn all the way on.
I have this same EXACT problem. Call the support system and they may be able to replace it or send you an email. Although I never got the email.... Sorry, and hope this helps.
Apr 02, 2007 | SanDisk Sansa e250 MP3 Player
Help me please! My mp3 player shut off.
press the power button for 15 seconds and let go. leave it plugged in the battery should be charging.
Dec 27, 2006 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
37 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Gyula Lacz
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
