Can you hear the motor running? If the motor is runningand machine is full of water, but not pumping water around, you have one of the following problems:
-a blockage in the filters or sump preventing enough water getting to motor impellor,
-blocked jets in spray arms themselves,
-or I have had cases where the impellor has broken off the motor, hence motor runs but doesn't pump any water around. Check for blockages first, wouldn't suggest you take motor out and disassemble unless qualified or confident to do so (it's not an easy job if you haven' done it before!!)
check to make sure you are getting enough water entering the dishwasher. If you add a liter of water, does the water arm turn then? If so, you may have a faulty water valve that is not allowing enough water to enter to turn the spray arm. Hope that solves it :)
if the arm is rotating freely when you give it a push by hand, then the problem is blockage in the jets in the arm - the arm only rotates with water coming out of angled jets at the end. take arm out, spray water in centre hole and whatever is blocking the jets should become visible. prize out with a paperclip or similiar
Could be a a couple different issues.. Not filling with enough water or food chopper broke or food chopper filter screen clogged.
Check water level: Run the DW and wait for the main wash to start (water will fill. pause then complete fill) The water should be no more than 1/4 inch below the heating element. If not there..replace water inlet valve.
Inspect food chopper: 1. Remove lower spray arm and rear water supply tube to upper spray arm. 2. Remove torx screws that secure the sump cover. 3. Remove primary filter 4. Remove food chopper cover to expose the chopper assembly. Inspect for breakage or blockage.
If you need further assistance, let me know Regards, reg501
Could be a a couple different issues.. Not filling with enough water or food chopper brokeen or food chopper filter screen clogged.
Inspect food chopper: Remove lower spray arm and rear water supply tube to upper spray arm. Remove torx screws that secure the sump cover. Remove the rounded cover on the left side to expose the chopper assembly. Inspect for breakage of blockage. There may be an additional plastic screen to remove first.
there is a blockage but may not be obvious. arm turns only by water spraying out of the angled jets at the end of the arm. take arm off, run water thro the centre hole and this is udually enough to force the debris to the jets. clean out and check
arms should turn freely. spray arms are only rotated by water spraying out from angled jets at end. check for blockage in spray arms - sweet corn and rice are the worst offenders. take spray arms off and run water in centre hole and see it runs out of all the jets freely
