Question about Sony Network Walkman NW-A3000 MP3 Player
Formatting problem i have had the mp3 player for a while and it has been fine, but the other day it froze up. so i pressed the reset button and when it started. it said no media libary found etc, wasnt a too bothered by this since i thought i could put the tracks back on it. but when i tried to do this it said that i had to delete all the tracks when i try to do this it comes up with a message could not delete all tracks error code 000066d7 and i even tried to format it from my computer but that doesnt even work.what can i do? or is it just broke?
  • alex minns Jul 31, 2007
    hi klaproosje
    No unfotunately i was not able to fix my the player, i tried everything i could think of but none if it worked. i still got the same error code.
    try googling the error code because i did this and it tells you what the error code means. didn't help me though.
    Sorry i cant help.
    Tango12
  • carlos_d7 Jun 20, 2008
    TENGO UN REPRODUSTOR NW-003 LO FORMATEE DESDE MI PC, AHORA NO SE PUEDE AGREGAR MUSICA, MARCA CODIGO DE ERROR 000066d7
  • 82 Answers
I wud suggest u to initialize it from the device itself so that it can avoid other issues. and upgrade the firmware as well as the software. Go to sony web site and downlaod Sonic Stage 4.3 try sync
Posted on Jul 13, 2009
Error: 000066d7...for this error u can check http://support.sony-europe.com/dna/wm/nwvp/nwvp.aspx?site=odw_en_GB&sc=DNA&m=NW-A806
here u have a software which resolves your problem
SonicStage CP Security Update Program this is the name
Posted on Aug 08, 2008
  • 8,596 Answers
There are two ways to format an Mp3 player - one on the computer itself, and one in Windows Media Player. Both methods will end up erasing all the songs on the player, but the player will be "good as new" after that. Sometimes reformatting in this manner will override the player's native formatting and cause problems - this can be reversed in most cases by updating the player's firmware. Firmware upgrades are available from most manufacturers' websites.
WARNING: The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes, format it to FAT or FAT32. - Connect player to computer, double-click my computer, right click on icon of mp3 player and select format. This only applies to Windows-based computers.
You can also format the player in Windows Media Player itself:
Connect your Mp3 player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "name of Mp3 player here 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
-Tha Mp3 Doctor
Posted on Jul 06, 2008
2 Suggested Answers
SOURCE:
SOURCE: formatting problem
I don't know why but,I have this problem on my Vista laptop but everything works just fine on my XP PC. I think Sonic stage may have been affected by a Vista update as this only started not to work a week or two ago.
Posted on Dec 26, 2007
Dropped two days ago, seemed fine. all of a sudden started freaking out. screen looks like TV static, then freezes on start up screen.
I suggest you to backup all the songs in the Walkman Player to the Computer and Format the Player.
Connect the Player to the Computer to charge it until FULL message is displayed.
Reset the Walkman Player. To reset it by pressing the RESET button with a small pin or similar object. You can also Format the Player if the Format option is available by accessing the Home Menu.
To Format the Player; press and hold the BACK/HOME button, select Settings-->Common Settings-->Format-->YES.
WARNING: There is a risk of data loss. If the memory is formatted, all files including the Operation Guide (If applicable to your model) stored in the player will be deleted. Be sure to verify the files stored in memory prior to formatting and export necessary files to the hard disk of your computer or other device.
Once the Format completes, reset the Player by pressing the Reset button located at the bottom of the Player using a sharp pointed object. Now you can transfer the required songs and files to the Player using the supplied Software or by dragging and dropping the songs through Windows Explorer. This will resolve the issue.
Good Luck!
May 05, 2011 | Sony Walkman NWZ-S616F MP3 Player
My Transcend T.sonic 610 MP3 Player battery is fine it is 3V but still the system is not switching on. I conncted to my PC things were fine. I had to change the PC so removed the MP3 Player and connected...
Hi
To resolve this issue, format the player using the computer. Also scan the player for any viruses using antivirus program. Even after performing the format the issue is not resolved then you would need to press the Reset button to restore it to its default settings. The reset program will erase all of the settings on the T.sonic. The reset button is on the right side of player. Keep that button pressed for at least 5-10 seconds.
Hope this helps...
Daniel
Sep 10, 2010 | Transcend T.sonic 610 MP3 Player
My Zen mp3 player wont work.
If you can try to open the files on your computer by search files option, then opne them and save the lot to a secured folder. Then completely format the device, erasing all the date stored. reset teh device once again and now put back antivirus scanned files back from your PC saved folder. Please check all the files for any error befroe you reload. I hope this will help you out. Good day
Jul 05, 2010 | Creative Labs Zen Digital Media Player
My Zen will not do anything,it's froze.
If a reset does not work using the reset hole, then try this: First, back up all of your music and do this: Turn off the player and disconnect it from the computer. Then press and hold the play/puse button and turn it on simultaneously. The player should be in recovery mode. Scroll down and select format (all) and let it format. Then reload all of music back onto your player and it should work like new. Hope this helps!
May 16, 2009 | Creative Labs Zen V MP3 Player
Transcend tsonic 850 freezing up
If your MP3 player still has warranty, take it back to the store or get it repair. Try to avg scan all the files on your MP3 player and your laptop as well. There might be a possible virus or a corrupted file that is causing your T.Sonic to froze.
May 02, 2009 | Transcend T-Sonic 850 Digital Media...
My zen mozaic totally froze, I can't even turn it off. The battery indicator show that it is half charged. I was just trying to rewind a bit, and the whole thing froze. What do I do now?
See if this works. If a reset does not work using the reset hole, then try this: First, back up all of your music and do this: Turn off the player and disconnect it from the computer. Then press and hold the play/puse button and turn it on simultaneously. The player should be in recovery mode. Scroll down and select format (all) and let it format. Then reload all of music back onto your player and it should work like new. Hope this helps!
Apr 16, 2009 | Creative Labs Zen Touch MP3 Player
Resetting my MP3 player
Press and hold the power button fo r 30 seconds that is the reset button for you MP3 player
Feb 11, 2009 | SanDisk Sansa e250 MP3 Player
Creative Zen V Plus Frozen on the product title screen
this helped me as after it rebuilds the libary then it always froze on a song let the battery run out!
this worked for me straight away and i had tried loads of other ideas this actually came from the tech guys !!!
  1. Detach the player from the PC if it is connected, and turn off the player.
  2. Press and hold the Play button while powering on the player.
  3. When the player displays the Creative logo, release the Play button
  4. Select Format (All) and select Yes to format the player.
  5. After the player has finished formatting, select Reboot.
  6. Re-transfer the tracks to the player.
Feb 16, 2008 | Creative Labs ZEN V Plus MP3 Player
My Zen V Plus
It happened to me too. Reinstall the software (Creative media explorer e.t.c.)
Sep 05, 2007 | Creative Labs ZEN V Plus MP3 Player
Sony Network Walkman NW-A3000 MP3 Player Logo
1,809 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
