After installing a new colour cartridge on the x4650 lexmark printer it still shows empty how do i re set the ink monitor
  • Anonymous Dec 08, 2008
    Please can somebody give us a step by step guide to re setting the ink monitor on my lexmark x4650 i av had cartridge re filled but wont print colour do i ne a chip re setter?if so were can i get 1 please help me out:(
  • dougiet70 Dec 08, 2008
    iv'e had the cartridge re filled but still shows empty do i need a chip
    re setter as still thinks empty cartridge in,surely must be a way to re set the ink monitor ...please any help welcome this doing my nutt in surely cant after buy new cart each time???
  • 19,396 Answers
You need to start the replace ink procedure from the printer software tools.
Posted on Dec 08, 2008
Colour setup for x4650
Make sure the color ink level is substantial for printing, otherwise, replace it with a new cartridge. Try to clean the cartridge nozzle - from the printer operator panel, press the Setup button > Maintenance > Clean Cartridge > press OK. Your printer will then print a test page forcing ink through the cartridge nozzles and clean them. Then try to print your file again to verify that the print quality has improved.
Nov 10, 2011 | Lexmark X4650 InkJet Printer
I've just installed both cartridges in my lexmark X4650 printer but they show as empty on the maintenance page
Note that a refilled cartridge will not be able to report its ink level. Check if correct ink level is displayed on your printer operator panel. Press Setup button > Maintenance > Ink Level - check your black and color ink levels. If ink levels are correct, then the problem could be on your computer.
The Print Spooler service on your computer may be disabled. To enable the Print Spooler service, follow the steps below:
  1. Browse to Start -> Run... and type in "NET STOP SPOOLER" (this will stop the print spooler service)
  2. Type in "NET START SPOOLER" (this will restart the print spooler service)
Try to check your ink levels again.
Jun 25, 2011 | Lexmark X4650 InkJet Printer
Ink levels indicator show "ink
You cannot. It is an unsolved bug my Lexmark. Try reinstalling the application, but I cannot guarantee that it will work.
If you have further questions or need further assistance, just leave a comment. Thank you for using FixYa. Cheers
Jan 28, 2011 | Lexmark X4650 InkJet Printer
Cannot find opening to install new ink cartridges
Hi
Please open the lid which is located on top of the printer. Also see this picture of Lexmark X4650 Printer showing the open lid and cartridges. Just remove the cartridges and install new ones
After downloading the drivers save them and install them. Hope this helps...
Daniel
Dec 29, 2010 | Lexmark X4650 InkJet Printer
Lexmark Pro 705 won't let me print after refilled
If you refill the regular lexmark 100 ink cartridges, you will not be able to use it because there is a rfid chip that track the ink usage. you will need to buy the 100a type which will let you print if the ink level is empty. since you have refill the 100 ink cartridge, you can swap the 100a chip to your 100 cartridge.
Apr 19, 2010 | Lexmark X4650 InkJet Printer
Lexmark x4650 cartridge problem
maybe your ink is empty. you need to change you cartridge
Feb 25, 2010 | Lexmark X4650 InkJet Printer
Where do you insert the ink cartridges on lexmark x4650
These are the instructions for X2500 Printer
1.Press the "Power" button to turn on your Lexmark X2500 3-in-1 printer.
2.Open the top portion of the printer to reveal the ink cartridges.
3.Lift the gray plastic cover on the left. Remove the empty black #28 ink cartridge. Next, lift the purple plastic cover on the right and remove the empty color #29 ink cartridge.
4.Remove the new black #28 ink refill cartridge from its packaging. Tear the protective strip of paper from the cartridge's sensor. Now, remove the new color #29 ink refill cartridge from its packaging and tear the protective strip of paper from the cartridge's sensor.
5.Turn the cartridges so that you can read the label. This is the way the cartridges should face when being put into the printer.
6.Slide the black #28 cartridge into the slot on the left side and push it down. Slide the color #29 cartridge into the slot on the right side and push down.
7.Push the gray plastic cover down over the #28 cartridge until it clicks closed. Push the purple plastic cover down over the #29 cartridge until it clicks closed.
8.Close the top portion of the printer. Your new ink cartridges are installed, and your printer is ready to use.
Oct 25, 2009 | Lexmark X2500 All-In-One Printer
Won't Print x4650
Hi
Here are a few possibilities...
1. Try cleaning the contacts on the inkjet cartridge and where they make contact inside the printer. (use cotton wool and Alchol) if that does not work...
2. Pull out power cable from printer wait 1 MINUTE then insert cable and switch back on again. (some printers reset to factory settings)
3. Remove printer cable from computer... Uninstall Printer driver from computer... Switch off both printer and computer. Wait 1 minute... Reconnect cables and switch on printer and computer... Allow computer to find printer reinstall driver.
4. Try installing old cartridge to see if printer rejects that?
5. You may have a faulty inkjet cartridge (return it to store if so)
You may find more help here...
How to Clean, Fix, Repair, Unclog, Dry, Clogged Print Heads on CANON, EPSON, HP, Lexmark, Dell, Olivetti etc…
Good Luck!
Tinteiros Magic Inkjet Flush Kits (Ebay)
Sep 11, 2009 | Lexmark X4650 InkJet Printer
No coloured ink showing
Try to remove and reinstall Ink Cartridges while printer is ON. Be sure the it is lock in place on the cartridge holder. If same issue, power off the printer and unplug and replug the power adapter. Check if the error has gone.
Jun 18, 2009 | Lexmark P4350 All-In-One InkJet Printer
Reset Lexmark 36 Black cartridge?
I managed to get it working, just damage the connection point (where the chip is). I used a knife to break part of the connection and now I can fill the cartridges myself for a fraction of the price :)
Mar 05, 2009 | Lexmark X4650 InkJet Printer
166 people viewed this question
jasbo
jasbo
