Question about Panasonic PT-53WX42 53" Rear Projection Television
Panasonic 53wx42 my set has no pic or sound and the red light stays on does not blink any ideas i have some electronic experance
  • lucked Dec 29, 2008
    also i rtemoved the board and in doing so i damaged the small board that stands up next to the last set of connecters in the back any one know where i can get a new one
  • Panasonic Master
  • 5,138 Answers
Replace your STKs 392-110s There is 2 of them use the STK382-180s better ics.
Posted on Dec 25, 2008
Power would not stay on red led flashes
I do not think we will get a response from person asking but you are correct, number of blinks indicates where problem is, the two most common are either a sequence of 3 blinks or one of 5 blinks.
Hard to help unless blink count is known.
SD TECH
Oct 23, 2011 | Panasonic PT-53WX42 53" Rear Projection...
Panasonic pt53wx42f
This sounds like a main power board issue. After you unplug it, it will work? Are you planning on trying to service it or having it serviced?
Thanks,
Lee
Jul 13, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Hello, I have a 53-inch Panasonic PT-53WX42F TV, and it refuses to turn on. No picture, no sound. All it does is the tiny red power light blinks 3 times repeatedly. Can I fix this myself? What parts do I...
Thats a convergence failure when the led blinks 3 times. Your model uses the PT47WX42 convergence repair kit available from www.tvrepairworld.com the kit contains the parts and the CD with instructions for the repair.
Jul 16, 2010 | Panasonic PT-53WX42 53" Rear Projection...
Tv will not turn on. red light on front of tv next to on/off button blinks
COUNT THE BLINKS.
3 BLINKS AND A PAUSE AND 3 BLINKS IS MOST COMMON.
5 BLINKS AND A PAUSE AND 5 BLINKS IS ALSO COMMON.
let me know the error code (blinks) and I will tell you what it means.
SD TECH
Jun 10, 2010 | Panasonic PT-53WX42 53" Rear Projection...
Panasonic PT-53WX42 53 in. Rear Projection Television turns on and then shuts off and then a red light starts to flash. Any help would be appreciated.
Most of these Panasonic sets have a error code---unplug the set for a minute----plug it back in and turn it on---does the red power light blink in a sequence---3 blinks, a pause and three blinks?
If it is 3,3 that is short protection and usually means one of the two convergence chips is bad.
Let me know what you find and I will be happy to help.
Regards, SD TECH
Oct 10, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Power lite blinks 10 times. no pic no sound. cant turn on or off
red light flashes 4 times then stays on for about 5 seconds then flashes 4 times again any idea what this means and how i can fix it tv is about 4 years old and only just started doing this
May 10, 2009 | Panasonic Viera TH-50PZ80U Plasma TV
Replaced stks and still no pic no sound
Remove conector P807, if set stays on the replacment IC's are bad. also check D428=5035a and Q371=2sa9335.
Jan 05, 2009 | Toshiba 50H81 50" Rear Projection...
Panasonic PT-53WX42 - When I turn the TV on, the red light comes on but, no sound or picture.
Does the light blink? If it is blinking a 3 code, the IC's need to be replaced. Those three lamps as you called them are not lamps, they are the three picture tubes.
Jan 08, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Panasonic PT-53WX42 53" Rear Projection Television Logo
42 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
