Question about OKI C9500dn Led Printer
Oki c9500 blotches
Hi
Our c9500 prints blotchy marks on every page, equally spaced every 3 inches or so horizontally across an a4 (portrait) sheet.
We've printed a full page of each colour, and it appears on all, so it's not the cartridges or drums and also changed the fuser unit.
The printer has been cleaned up in all areas as well. Any ideas?
Thanks
Dan
  • cjmcma Mar 15, 2009
    I have the same problem with mine, ever find a solution?
flopez
  • 161 Answers
SOURCE: Oki C9500 makes VERY LOUD clunking noises but prints fine...
The sound is most probably from one (or more) of the drum units. You can check by taking them out and trying to run the visible gears by hand. If you have spare drums, change them one at a time until you find the defective one.
Posted on Sep 26, 2007
  • 32 Answers
SOURCE: Oki C9500 Printing Problem
Check the LED Head and LED Connection. The LED heads are interchangeable, BLK, Cyan, Magenta, Yellow.
Posted on Feb 15, 2008
ginko
  • 19396 Answers
SOURCE: oki c9500 fuser
If you need replacement here you find some offers:
Okidata Fuser Unit 120 for C9300 C9500 ... $189.72 - pcRUSH OKI 41946101 Fuser Unit 120V ... $160.83 - PROVANTAGE Okidata C9300, C9500 Fuser Unit ...
Posted on Aug 08, 2008
SOURCE: OKI C9500
We had this issue and removing the optional hard disk fixed it for us, I'm guessing it was on the way out and wasn't really being used so it will not be missed.
Posted on Nov 19, 2008
  • 105 Answers
SOURCE: Oki C3100 - v poor print quality
Hi Errol
The way to identifiy your problem is to send a full colour print to your printer and open the top just as the paper starts to come out . if you then remove your toner / drums for all the colours you can see the transfer belt if the quality of the image that you can see on the transfer belt is good and clear your problem is with the transfer form the tranferbelt to the paper and not any toner /drum issue and the most likley cause is the transfer belt itself "but before you relpace it remove it and clean around the electrical contact points and generally make sure the internals of the printer is free of loose toner .
Regards Alan (Alstech)
Posted on May 13, 2009
Prints blotches and marks down the left edge
Hi
That sounds like classic wear and tear issues. All those rollers and gears have very close tolerances and any variation out of the rang and the paper grabing and jamming starts. And that could be cause of the toner leaking. You must have a lot of miles on that ol girl and you got your moneys worth out of her. They dont make them like that anymore and I dont think you could find the parts even though that was back when they supplied parts. I asked an engineer once "couldn't they make that one gear out of metal like the rest of them?" He replied "well sure, but there wouldn't be any money in that..." You beat the system on that one. Time to start your research on a replacement I'm afraid.
Jun 18, 2017 | OKIPAGE 12i Led Printer
Black dots/blotches on the sides of printed sheets - whats is the cause and how t to fix it
If you have random blotches on both sides of the sheet, your printer probably needs cleaning, especially in the fuser section. If the fuser is difficult to get at, here's a good cheat developed for HP LaserJet 6 printers: Use a basic graphics program such as Microsoft Paint to draw three solid black rectangles about 2.5" top to bottom, going all the way across the paper (the space in between is not critical - the key is that you go as close to edge-to-edge as you can get). Print out this sheet.
Put the sheet back in the paper tray so it will print on the blank side (usually printed side up). Open up a quick text processor (Notepad in Windows). Type a single space, then print (some text editors won't print a document with no data in it). Dirt in the fuser will get stuck to the black areas on your cleaning sheet. Test your work by printing another copy of " ". Repeat with a new cleaning sheet if necessary.
May 02, 2011 | Brother HL 2140 Laser Printer
At college we have a w7200, how can we print across the paper rather than down it, for example a panoramic image across the width of the paper and say 20cm high
Try selecting LANDSCAPE as opposed to PORTRAIT by using the proper print menu in your application rather than the simple print icon from most tool-bars.
You can usually find it in the FILE menus
Apr 20, 2010 | Canon imagePROGRAF W7200 InkJet Printer
How to clean an OKI B4100 (new toner, blotchy printing)
Open the cover, remove the cartridge and vacuum carefully the interior. Clean the leds when the cover is open and it should work.
Apr 04, 2010 | OKI B4100 Laser Printer
I have a Oki C9500 laser, the magenta print is streaky
I have the same problem with my OKI c3100, please help
Jan 13, 2010 | OKI C9500dxn Led Printer
Problem printing multiple pages on one sheet!
This is not the fault of the printer but the fault of word.
The way I did it successfully was as follow:
File > Page Setup > Layout = Landscape (sounds like you have already done this)
In the print dialoge, instead of OK, click Properties. On the layout tab, select landscape and below that select pages per sheet = 4 and then click ok... Then click OK to print.
May 22, 2008 | HP LaserJet 2200 Printer
Feb 15, 2008 | OKI C9500dxn Led Printer
Printing 2 pages on landscape document
Usually if you see the page in the Publisher window is already landscape, it will go landscape in the Printpreview and also in the print out. I just try to imagine what is your problem.
If I am not mistaken, this is what you did:
You have two "small" pages (maybe A5??) and you want to print it in one page of A4. Of course the A4 should be landscape.
Publisher does not have the facility to set 2 pages A5 in one A4 like in Microsoft Word.
The easiest way is just create a new page with A4, then copy the 2 pages (or you called it flyers) and paste it in that A4 landscape page.
Publisher can do print 2 pages A5 in one sheet A4 but the arrangement is as booklet. You can see the choices in File --> Page Setup --> tab "Layout" --> scroll the Publication type.
I do print 2 pages A5 in one sheet with many variations using addition software named "Clickbook".
Let me know if I m wrong in interpret your problem.
Feb 10, 2008 | Adobe Photoshop 7.0 for PC
Horizontal streaks on pages
Streaks at 2.82 inch intervals: Horizontal marks at this interval are the result of a mark on the fusing roller of the printer. In some cases, these marks can be cleared up by running a cleaning page through the unit. Laser Printer Cleaning sheets can be purchased at your local printer/office supply store. If the marks persist, this can indicate a more serious problem with the fusing roller that would require service attention.
Streaks at 3.74 inch intervals: Horizontal marks at this interval are the result of a mark on the image drum of the printer. There is no way to repair a damaged photosensitive image drum, so in the case that it is scratched or otherwise damaged, the entire CRU (toner/drum cartridge) would require replacement to clear up these marks.
Dec 03, 2007 | GCC Technologies Elite 12/1200N Laser...
OKI C9500dn Led Printer Logo
47 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
