Question about Acer Extensa 4620 Notebook
Acer extensa 4620 no power or video
I was replacing my monitor when I saw a blue power on for a second because I forgot to remove the battery. I think the wxga connector made contact with the screen connector. Now I don't get power on light or anything. What do you think is the likely cause and can I repair it? If it is a board fuse where is it located so I can replace that in the power circuit or did I fry the video and power section on the board. I can't believe I made such a stupid error.
  • Majic Touch Feb 11, 2009
    I replaced the mb and am going to send this one in for troubleshooting possibly.
    Problem Solver:
  • 9 Answers
You more then likely fried the motherboard with that move. There is no internal fuse that you are able to replace or reset. Replace the motherboard, nothing else that can really be said but that.
Posted on Jan 12, 2009
No display in acer extensa 4620
Hi There,
Check the below link that might help you to diagnose the issue:-
http://laptopturn.com/acer-extensa-4620-wont-turn-on-wont-boot-no-display-black-screen-problems/
Hope this will hep to diagnose the issue if it is VGA cable that is faulty of something else.
Jan 27, 2018 | Acer Extensa 4620 Notebook
I turn on my lop top and light stay green but donot see any activiti on screen. no fan noise. i open the back and saw that the fan goes off affter a few seconds when i started up. i also try to get video ...
Welcome to Fixya
Sounds like the problem here is the Video card already. If you already tried using an external monitor then same thing happened then the Video card is the culprit. Worst case scenario would be the motherboard.
Oct 24, 2011 | Acer Extensa 4620 Notebook
I had a acer company laptop model extensa 4620 . probbem a bios password and c; access dinied . bacause i am not remeber bios password. so ple, sowl my pro.
You can reset the bios password fairly easy. You will need to unplug the laptop from power and remove the battery pack. Then you will need to turn it around and you will see a cover plate. Remove the plarte and inside you will see a little flat battery. Just remove it and replace after 2-3 mins. Then close up and replace battery and restart. Should have cleared the bios.
Hope it helps
Jul 23, 2011 | Acer Extensa 4620 Notebook
Hi I can't open my acer 4620 . press on the power but the light only on for a few seconds and then went off again
hi sounds to me you might need a new battery ,or try remove the battery and plug the charger in then it will work without the battery ,check to see if theres power comin out of the power supply with a multimetre should read about 18-19volts hope this helps you goodluck
Mar 25, 2011 | Acer Extensa 4620 Notebook
New acer extensa battery price
try this link
http://www.batteryuniverse.com/Laptops/Acer/Extensa-4620/CONIS71_Acer_Extensa_4620_Laptop_Battery
Feb 24, 2010 | Acer Extensa 4620 Notebook
ACER EXTENSA 4620-4605 model screen problem
If you wiggle the screen and it comes back, then it is not your Video card. Probably just a loose connection with your LCD cable to the LCD screen. Although you may also need a new screen/cable.
The weird thing is that it "fades" out... which would indicate a bad screen to me.. but securing the cable is alot cheaper to try first.
Completely rule out your graphics card by connecting your laptop to an external monitor... if it works fine for a long period of time then your card is fine.
Good Luck.
Sep 06, 2009 | Acer Extensa 4620 Notebook
Blue screen in extensa 4620
The Blue Dump or Blue screen problem is related with RAM.
1. Try by Cleaning the RAM and RAM slot
2. Try changing RAM
3. Also try changing HDD cable
Mar 10, 2009 | Acer Extensa 4620 Notebook
Bios password on acer extensa 4620
ok on all desktops there is a jumper on the motherboard conecting 2 out of three pins and on the motherboard it says psswd. power off and unplug it then remove the door on the back where the ram goes ill bet thats where ull find it. take the jumper off and put it on the other pins. boot it up and password should be dissabled go int bios and make sure. u can leave it like this or turn off and replace the jumper. hope this helps.
P.S. if the jumper isnot by the ram check behind any other doors the laptop might have
Jan 24, 2009 | Acer Extensa 4620 Notebook
Acer Extensa 4620 Notebook Logo
222 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
