Question about Kitchen Appliances - Others
Experimental set up for wireless transmission
Is it possible to transmitt the power without wires?
if it so
please list the experimental setup for that..............
and tell experimental setup and operation for that;;;;;
  • 75 Answers
No.
Posted on Dec 31, 2008
Soda stream won't carbonate
See our list of the best soda maker reviews for 2016. Read our best soda maker machine reviews and tips for maximum performance without wasting time. Top Ranked Home Soda Maker
Dec 26, 2011 | Kitchen Appliances - Others
Head unit assembly of Ionic Breeze model S1830
The caps would seem to me, to be a protection cap,
which would go on to of the spring,to protect from
the electrical current.Hard to say, since I can't see
the setup.See if you can Google a diagram or pdf.
Good luck.
Mar 31, 2010 | Kitchen Appliances - Others
Wired doorbell. Trying to connect to pre-existing one.
Unfortunately, we live in a time of need security alert and services, such as wireless door bell system. Theft and robbery, at an all-time high, it is very important to protect their family and their property. There are some equipment can provide high levels of protection and some can low cost.
Jan 01, 2010 | Kitchen Appliances - Others
Sharp SPC 373 transmittting temp 179 for a month
Unfortunately I have the same Sharp atomic clock with the same bad remote temp transmitter and having the same 179 result displayed. Can't find a replacement anywhere.
Sep 28, 2009 | Kitchen Appliances - Others
I need to connect two switches to one power source in a two gang box. There are two different light sets.
The proper way to wire two switches in a 2 gang switch box to control each light separately is as follows:
  1. Make sure you have the power turned off at the breaker for this box.
  2. Take the HOT (common, black wire) FEED wire and add (2) pieces of black wires to it with a wire nut.
  3. Now you can put one of each of these black wires to the bottom screw of each light switch to provide power to both switches separately
  4. Connect each separate wire to the (2) different lights to the top screw of each switch.
  5. Twist all the bare ground wires together, leaving at least 7-8 inches at the ends untwisted for at least 2-3 of these wires.
  6. Take (2) of these ground wires and connect them to the ground screws on each separate switch. If it is a metal box these area in, connect one ground wire to the box with a green grounding screw also, if not, cut off the extra ground lead near the twisted bunch.
  7. Now twist all white (netural) wires together and install them all under one wire nut.
  8. Make sure the bare wires are not near or touching the HOT screws and fasten the switches to the box.
You now have an approved and legal wiring for (2) separate light switches using the one power source (FEED) already in the box.
Sep 17, 2009 | Kitchen Appliances - Others
GDO - Do I need a new Logic Board or is it something simpler?
No, the problem is the photoelectric eyes. Check that they are properly aligned.
Aug 02, 2009 | Kitchen Appliances - Others
Hampton Bay Ceiling Fan, Model 68068. When installed, without connecting the final plug, the fan doesn't operate (like it has no power); but as soon as the last white connection is made, the fan comes on,...
Hello, W/D here. It sounds like you have bypassed your on/off switch.
The white wire is the common wire, which returns the power to ground, and completing the circuit. By connecting this wire, you have completed a circuit, indicating that power was constantly on to the fan.
Gain access to your wiring in the ceiling (trip the breaker first, please).
If you have tied your hot wires to a twisted bundle of black wires, you have tied to the hot thru line. Look for a single black wire. What normally happens with the ceiling wiring is that the circuit hot wire goes to your ceiling box. Another wire connects to this one. It passes on to the next device on the circuit. Yet another wire ties to the bundle. It is your switch hot wire. It goes to the switch, and returns to the ceiling box. The return wire from the switch is the one you're looking for.
Regards, --W/D--
Jul 20, 2009 | Kitchen Appliances - Others
Baby monoitor reciever piking up no sound or delayed sound - link light flashing
A delay may be caused by interference from other radio sources. I heard of one case where a woman's cell phone call overpowered the transmit power of her baby monitor.
Other things that can cause interference or other receiver problems:
1. monitor in contact or close proximity to running appliances or their cords. (induced electromagnetic field)
2. neighbor with baby monitor on same channel ('cross-talk')
3. distance between transmitter and receiver too far (the strength of a radio signal fall dramatically over larger distances. think of how often you lose cell phone coverage)
4. reduced power: low battery strength or cooked power supply
5. transmitter or receiver insulated from signal (if your monitor was transmitting/receiving through any metal obstruction)
May 07, 2009 | Kitchen Appliances - Others
WIRING A HEAT N GLOW FIREPLACE
If you are in the UK and you are talking about a wall switch, you would need a 20 amp double pole switch possibly with a flex outlet hole (for a heater up to 3kW rating) wiring should be straightforward Live IN/OUT, Neutral IN/OUT, Ground IN/OUT. NB Make sure the power is off before starting work.
If it is a bespoke heater mounted switch refer to the original supplier/manufacturer if possible.
Oct 22, 2008 | Kitchen Appliances - Others
Thermastat and furnace
you should have 24 volts between yellow and white wires at the stat when the stat is set to heat and set as hot as it will go. burners should light first then 3 to 5 minutes later the fan motor should fire up. if burner doesn't light check the wires going into the top of the gas valve see if you have 24 volts arriving there from the stat. if you do then the gasvalve is probably bad. you can bypass the action of the stat by jumping red to white on 90 percent of the stats made and in a few seconds the gas valve should click open gas flow to main burner where pilot ignites it. another easy check you can do is flip stat fan switch to on. fan should come on at once. if not then you have either no high voltage to unit or no low voltage ( as in a bad transformer). if the fan comes on you know you have high volts and low volts...by cover i assume you mean the decorative cover but there second cover with the mercury bulbs and all is still there. if you have only the bare subbase then new stat time. sounds like an old furnace if it has a standing pilot, it should be checked for cracked heat exchanger by a pro with a n electronic carbon monoxide detector. NOT a diy item due to the real danger of co poisoning.
Oct 02, 2008 | Kitchen Appliances - Others
Kitchen Appliances - Others Logo
102 people viewed this question
Top Kitchen Appliances - Others Experts
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
