Question about LG KU990 Viewty
My lg ku990 is having freezing problems and also i cant see sound
I cant see all my sounds and images in my phone[memory card].i need help please im a big lg fan ok.
  • 275 Answers
You might want to check the length of the name of your files ...example songs cannot have a name that is more than 20 characters in name bc it will not display in your phone . Also the more files you have the slower it its to display them, keep that in mind
Posted on Dec 08, 2008
Lg viewty phone keeps freezing when i click on my
hi
my hunch is that the my files is located on the Memory card and the memory card is faulty try removing your memory card and accessing your 'My Files' if this works then you may have to replace your memory card
cheers
pls rate if this works
Jul 13, 2009 | LG KU990 Viewty
Invalid access to memory location with LG KU990
Disconnect he phone from the USB.
Open your phone menu.
Open the phone settings.
Open te USB connectivity.
Change te settings to Mass storage.
Connect the phone to the USB port.
If windows reconize the phone as a removable drive the you can
drag and drop your files in the explorer. When you saved the files on your pc then format the card in Fat 32 in a card reader from your laptop or pc or by a extern card reader.
Whe the format is done you can drop the files back.
Set the settings in USB connectivity back in Data service when
you are done.
Swich of the phone and put the card back in the slot.
Now the phone will reconize your memmory card.
hope this will help.
May 27, 2009 | LG KU990 Viewty
Please help, i cant activate use of my memory card on the lg viewty
If its a new card, have you formatted it in the phone? (go to Menu, Settings, Phone Settings, Memory Manager, External Memory then click on the Format button).
To activate its use, go to Menu, Settings, Phone Settings, Memory Manager, Primary Storage Setting and select External Memory.
Apr 16, 2009 | LG KU990 Viewty
My lg viewty freezes and just shows lg on the screen. normally when i used the camera, also removes homescreen image
OK, there can just be a couple of reasons why your Viewty is actually acting like this and this is the biggest one: You have to much junk on your memory card and that's why your phone freezes up when you want to go to your documents. Known issue to me that when you have memory card problems, the homescreen wallpapper gets removed, thats when the SD card is not being detected or it has some corrupted files that are affecting your phone when you try to access them and makes your phone shutt off... Big Advise and this will defenetly get rid of your problem: Clean your Memory Card, also and why not clean your internet History, Cookies and Cache. Good Luck, and please treat your Viewty nice, this phone is awesome and deserves better care.
Mar 09, 2009 | LG KU990 Viewty
Transferring data
its easy, just follow:
1. if you don't use memory card, skip the previous step and just install the LG PC SUiTE in the CD that comes with the Viewty, then connect your phone with the computer and in the LG PC SUiTE choose CONTENTS and there you find everything in your phone, just copy & past anything, this also works if you have memory card, but if you have memory card, the below method is faster and easier dealing with data:
2. if you are using memory card, copy all the things from your folders (images, sounds, videos...etc. ) from your phone to memory card.. then on your viewty, go to menu --> settings (fourth) tab --> phone settings --> connectivity --> USB connection mode --> then choose (Mass Storage) and then connect your phone with the computer and, here you go, you're all set and you find your memory card on pc :-)
regards
Jan 24, 2009 | LG KU990 Viewty
No sd card found in the phone
Have you tried using another memory card, or maybe using that same memory card on another phone and see if it works, because it could be either one othe them that could be malfuncioning, hopfully it is the memory card and not your phone.
But just in case if you find out it was the phone, try to reset settings to reset it back to factory settings and hopefully that will help, also check if the memory card slot is clean..Good luck
Dec 11, 2008 | LG KU990 Viewty
My LG KU990 can not see my micro sd card even thought it's in the phonr
when you go into my files on he phone scroll right to the bottom and it should say external memory or memory card.
i hope this was help...
Dec 01, 2008 | LG KU990 Viewty
LG KU990 - Memory Full
the phone;s firmware need to be reflash on the phone, so take it to a mobile center to have it done.
Aug 19, 2008 | LG KU990 Viewty
Clearing phone memory
Yes, you do need a sim card in to empty it, as the sim card makes the phone work. You can clear memory by simply deleting things like, sounds, music and photos!
Aug 14, 2008 | LG KU990 Viewty
LG Prada Cant get music on to the phone
If you have a memory card in the phone, you need to move all files to that... then you will be able to download things through bluetooth and move them also to the memory card.
Oct 13, 2007 | LG Prada KE850 Cellular Phone
LG KU990 Viewty Logo
83 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
