Question about Dell Inspiron 6000 Notebook
Dark monitor on dell inspiron 6000
My monitor is dark. I can see the desktop vaguely, and it gets better when I shine a flash light on it, but the brightness that I am used to is definitely gone.
I tried holding down the Fn button and hitting the up and down arrows, but it doesn't change. I tried the pressing up on the power chord where it enters the laptop and hitting the power button, but to no avail (read that somewhere on line).
Are there other things I can try to bring back the desktop the way it used to be?
Thanks, Scott
  • scottspiegle Dec 08, 2008
    I was told once that monitors have a lot of power circulating in them even after you turn the computer off and that it could be dangerous to open up a monitor to do repair work.
    Is there truth to that? Also, how hard is it to replace those parts if you have never done that?
    -Scott
  • 107 Answers
Chances are that you back light is out AKA new inverter board time.
Here is more info on it http://www.laptoprepair101.com/laptop/2007/01/31/replace-screen-inverter-fix-backlight/
And here is a link to a replacement
http://www.google.com/products?hl=en&safe=off&client=firefox-a&rls=org.mozilla:en-US:official&hs=cK0&resnum=0&q=inspiron%206000%20inverter&um=1&ie=UTF-8&sa=N&tab=wf
Posted on Dec 08, 2008
  • Eric Mitchell
    Eric Mitchell Dec 09, 2008
    And if you take the battery out and upluge and wait a few minutes it is perfectly safe
  • 148 Answers
So, you have a Dead backlight inverter or the backlights bulbs are burned....
Try to find the backlight bulbs and inverter parts in Ebay..that match´s with your laptop model...
install it and turn the backlight on again!
Good Luck!
My dell inspiron 6000 its display is very dark though its working.cause i can see my windows desktop.is thers something wrong with my lcd?
Sounds like the back light is bad. The display will have to be replaced because replacing the back light itself is very difficult and the bulb itself is extremely fragile.If you have tried turning up the brightness with you keyboard with no luck it's the backlight
Oct 12, 2011 | Dell Inspiron 6000 Notebook
Dell inspiron 6000 screen splitting
This is a generic problem in most of Dell Laptops ( mostly inspiron ). It is caused due to a fatal fault or breakage in the Hinge Assembly. You need a new Hinge Assembly. Is it splitting more on decreasing the angle of the monitor. If yes, Hinge assembly is the only culprit. If you are under Warrenty then Dell will be liable for it and replace it free. If not under Warrenty, I approx. costs 300$. Thank you Sir, Have a nice day.
Sep 18, 2009 | Dell Inspiron 6000 Notebook
Dark/black screen on laptop
take this into geek squad to get monitor fixed because what has happened is that the back light behind the lcd has burnt out.
May 24, 2009 | Dell Inspiron 6000 Notebook
Dark screen ,fn does not work
I would suggest connecting the laptop to an external monitor, just to make sure that it is all running correctly.
If you can see a very dim image on the screen then the backlight is out. This can be a light problem or the inverter that powers the backlight could be bad. The inverter is not real dificult to change and also is not very expensive. If it is the backlight tho, it is easier to just change out the entire screen.
Hope this helps
May 02, 2009 | Dell Inspiron 6000 Notebook
Loss of light on screen Dell Inspiron E1705
Check your backlight settings, Power Settings, etc.....
You may have Vista (vista has other power settings such as a custom sleep mode which can fail sometimes to work properly with some hardware/monitor configurations).
So Disable any unconventional Hibrid Hibernation options k!
Apr 20, 2009 | Dell Inspiron E1705, Intel Core 2 Duo...
I have a dell inspiron 6000 the screen goes black
the lcd screen may be causing this. Try to connect the laptop to an external monitor and have both working at the same time by toggling Fn F8 on the keyboard. Wait until it goes black on the LCD. post back what happens. If the external monitor wont go out when the lcd does, the lcd may have to be replaced. If the monitor goes out too, it's a video card issue which may be resolved by reinstalling the driver.
Jan 31, 2009 | Dell Inspiron 6000 Notebook
Dell battery lights flashing 4amber 1 green
Hi
Do this update and this will get you the help in your battery.
Download this file to the desktop and then run this file. Make sure you plug the charger while the file is being ran. If this does not work. Let me know we can run a diagnostics on the battery as well as your charger and check that as well.
http://tinyurl.com/6r97vt
Thankyou
Rakesh
Dell Laptop Expert
Jan 02, 2009 | Dell Inspiron 6000 Notebook
The monitor in my computer turns dark when i turn the laptop on
The make and model do not matter. Your backlight is going and will have to be replaced. A good computer shop will be able to do it.
Dec 23, 2008 | Dell Inspiron 6000 Notebook
Monitor is very dark
I have to assume you have tried through existing means to change brightness and contrast.
These are generally provided for the user.
LCD screens are backlit via a fluorescent lamp. This is a high voltage device so the problem could come from either a failing lamp or the inverter circuit that drives it.
Access to the lamp varies greatly and to even check it may well be a job for a technician.
Mar 29, 2008 | Dell Inspiron 6000 Notebook
Laptop back light
the cost to replace the lcd would exceed the value of the laptop. Be cheeper to get a new one.
Jan 28, 2008 | Dell Inspiron 6000 Notebook
Dell Inspiron 6000 Notebook Logo
950 people viewed this question
Alun Cox
