Question about HP Compaq Presario F750US
Need a laptop below range if 30,000 - HP Compaq Presario F750US
  • 1 more comment
  • kokerkoker4 May 11, 2010
    iuhiuh
  • Eric Mitchell
    Eric Mitchell May 11, 2010
    This makes close to no sense but I'm guessing that you are looking for a laptop for under $300 USD
  • Lalit Varadpande
    Lalit Varadpande May 11, 2010
    what specifications are u looking for?any brand in particular?
Out of range 90.0khz/60hz
does the dock havae a power button? if so, place laptop on dock while cosed and turn on through the dock.
Feb 06, 2013 | LG W1943SS 19" Monitor
I need any info on the canon 300mm f/1.4 L USM lens. I trying to buy a used one but can't find any reference to it on any web sites
There is a Canon 200mm F2 lens, and a Canon 300mm F2.8 lens, but no 300mm F1.4 that's a normal, production lens. In the back room at Canon, Inc. maybe, but not for the general public. If they DID make one, you could expect to pay MAJOR money for it- in the range of $20,000-$30,000.
Jul 01, 2009 | Cameras
Was told I need a fan belt. How do I know for sure if I do or don't.
There could be several fanbelts. If it's a serpentine belt, there's only one.
Belts need changing when they start developing cracks, cuts or there is obvious damage. This could hapen in the 30,000 - 60,000 mile range.
The price varies widely. I would guess the average to be $100 - $300.
May 12, 2009 | 2000 Suzuki Grand Vitara
Tune Up
Tune ups - every 30,000 miles
radiator flush - every 10,000 miles.(varies from climate to climate)
trans fluid change - every 9,000 miles.
Feb 25, 2009 | 2007 Mitsubishi Galant SE Sedan
Problem,buying laptop
There are many laptops on the market that could suite your need. What size screen would you like? What operating system do you perfer? (XP Pro,Home, Vista...) How much storage would you like? (100GB, 200GB..) My company sells many brands of notebooks and may be able to help you in your qwest. I would be more than happy to give you a free quote. Please email to info@c2sit.com. Thanks
Jan 27, 2009 | Dell Vostro 1500 Notebook
I want to buy laptops in range of 25,000to 30,000 thousand in latest configuration
Sure I will check it out for you. Any specifications? Large screen, small screen, Windows, Mac, Linux?
Dec 28, 2008 | HP Compaq Presario F750US
Laminate specifications
A typical laminate trimmer is equipped with a 1/4-inch collet. The motor runs in the 20,000-30,000 rpm range – faster than most routers to compensate for the fact that the bits are smaller in diameter.
Aug 27, 2008 | AMANA TOOL 3400 DOUBLE EDGE LAMINATE...
Tune up
At 60,000 you should have all the major things done if you haven't already:
oil change(every 3000)
air filter change(every 15,000)
coolant flush(every 30,000)
spark plugs and wires(every 30,000)
transmission fluid & filter change(every 30,000)
brakes (as needed)
PCV valve (every 20,000)
You can wait until about 75000 miles to do your timing belt.
Hope this helps
Jun 22, 2008 | 2004 Chevrolet Aveo
PROCOM QL300TYLA
The QL300 has a range of 20,000 to 30,000 btus. That shouldn't be too big for your 300 square foot room with high ceilings and a loft. It has a thermostat, so it will shut off when the room gets warm. 1 pound of propane contains about 21,000 btus, so you will be burning 1 to 1.5 pounds each hour that the stove is running.
Jan 17, 2008 | Procom QL300TYLA Heater
HP Compaq Presario F750US Logo
105 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
